POV-Ray : Newsgroups : povray.binaries.images : Black Seas Barracuda finished (link) Server Time
1 Mar 2026 06:30:59 EST (-0500)
  Black Seas Barracuda finished (link) (Message 11 to 17 of 17)
Subject: Re: Black Seas Barracuda finished (link)
Date: 8 Jul 2002 18:31:13
Message: <3D2A1411.5020503@faricy.net>
Timon Christl wrote:
 > As the other posters said, there is no image. I looked into the HTML
 > source generated by your PHP code, and found the reason: You are using
 > backslashes in the path to the image:
 > <img src=".\renders\blackseasbarracuda3.jpg">
 > but PHP (to be more exact, the underlying webserver) requires forward
 > slashes as path separators. The character sequence \r is actually a
 > single ASCII character (13 => Carriage return), the same is true for
 >  \b (which is 8 => Bell). Just change this and it will work.
Hmm, it appears you're right.  I thought I had used the backslash
elsewhere, but I looked through my files and I guess I didn't.  I'll
change that and you tell me if it works.
Probably some browsers change the backslash to a forward slash, as it
worked fine for me in both IE and Netscape.  That or certain browsers
don't like the backslash.  BTW, PHP has nothing to do with it, as it
merely generates the HTML.  PHP uses C-style escape sequences, but the
PHP code had a double-backslash, resulting in HTML with one backslash.
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
Date: 8 Jul 2002 18:33:55
Message: <3D2A14B3.7070509@faricy.net>
Rafal 'Raf256' Maj wrote:
>>http://davidf.faricy.net/renders/blackseasbarracuda3.jpg
> Opera 6.03 crashes every time after opening this link
That would be a client-side problem...
Date: 8 Jul 2002 18:38:17
Message: <3D2A15B9.2010100@faricy.net>
David Fontaine wrote:
> http://davidf.faricy.net/image.php?pic=blackseasbarracuda3.jpg
The above link should work now.  :)
Date: 11 Jul 2002 23:35:09
Message: <3D2E4FCD.7090805@faricy.net>
Hello?  Is someone going to tell me if image.php works now?  :|
Date: 12 Jul 2002 16:15:43
Message: <3D2F3995.5090903@netscape.net>
Works for me :)
-Roz
Date: 12 Jul 2002 21:46:43
Message: <3D2F87E4.70307@faricy.net>
Roz wrote:
> Works for me :)
Good!  :)
Date: 12 Jul 2002 22:15:58
Message: <3D2F8E16.A1C361CC@applesnake.net>
hehe
first one worked
second works
works
working still
-peter
Modeling slave:
"Ballet pour ma fille."
http://www.applesnake.net
