Samuel Benge
sbe### [at] caltelcom
Download 'tree.jpg' (88 KB)
Preview of image 'tree.jpg'
Samuel Benge wrote:
OOH! That is very effective, it just needs a "pine needle" texture to add
an extra level of detail.
How did you do it?
> Samuel Benge
Your connection failed because: Your EMAIL is now being delivered by the
USPS.
Okay, Netscape pulled a fast one here... I did have text with that image!
Anyways... playing with The Gimp I found the wonderful IFS Composer. I
decided to try any make leaves out of the resulting image. Isosurfaces
were too slow, so I tried intersecting a sphere with a height_field
created with the IFS image. Here is the result my efforts. The leaf
branches have too little detail, but I think it's a fairly good start.
It takes very little time to render when no aa and area_lights are used.
I used both here. Questions, comments?
Samuel Benge wrote:
Samuel Benge
Oh yeah, the reason I intersected a height_field with a sphere was to
avoid the extra-long render times associated with many partially
transparent objects. This scene contains 364 objects.
> Samuel Benge wrote:
Samuel Benge
Huow much memory does it take after parsing?
Peak memory was 2750445 bytes on the test I just made. What is that,
about 2.75 megs?
Samuel Benge
>What is that,
It's not much :-)
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Apache wrote:
> >What is that,
> It's not much :-)
If it's a mesh, and can be re-used without that being too obvious,
then this is by no means too much memory for a good model.
John
