POV-Ray : Newsgroups : povray.binaries.images : double_illumination + radiosity (37.2kb jpg) Server Time
26 Mar 2026 14:54:00 EDT (-0400)
  double_illumination + radiosity (37.2kb jpg) (Message 1 to 10 of 22)
Subject: double_illumination + radiosity (37.2kb jpg)
Date: 21 Jun 2002 15:23:50
Message: <3D137D2C.3080506@caltel.com>
I'm glad that POV 3.5 now supports radiosity interaction with double
illumination. When MegaPOV came out with it's double_illumination
keyword, I tried a similar experiement with no apparent effects from the
radiosity.
This is just a simple test of this interaction involving a barn made
from wood beams and fiberglass panels. Sun shines past a tall box
casting partial light onto the barn, thus simulating scattered light inside.
Questions, Comments?
Samuel Benge
sbe### [at] caltelcom
Download 'cornell's_barn.jpg' (38 KB)
Preview of image 'cornell's_barn.jpg'
Subject: Re: double_illumination + radiosity (37.2kb jpg)
Date: 21 Jun 2002 15:35:06
Message: <3d137fea@news.povray.org>
> Comments?
Sweeeet!
-Peter
Date: 21 Jun 2002 15:46:35
Message: <3d13829b@news.povray.org>
I concur with Peter. I would never have thought of that.
Date: 21 Jun 2002 17:16:18
Message: <3d1397a2@news.povray.org>
Beautiful effect! I'm gonna have to think of a scene for this :)
Corey
schitzo.y0ru.net
blob{threshold#macro _(s,i,g)#if(s)sphere{20*(i-<5,1,-10>)16,1pigment
{rgb 9}}_(s-1i+g,g)#end#end.7_(4x,x)_(2,0y)_(5y*2x)_(5x*6x)_(3<6,
1>2*x)_(2<6,2>4*x)}
Subject: different lighting (37.6kb jpg)
Date: 21 Jun 2002 17:56:07
Message: <3D13A0DF.7080900@caltel.com>
Here's a second rendering of the same scene. I placed a blue light on
the other side of the building. It passes through a plane with a fuzzy
chain-link fence texture. Recursion_limit 2 was used with slightly lower
radiosity settings to try and compensate for the increased rendering
time. It took about 44 minutes to render.
Q's, C's?
Samuel Benge
Download 'cornell's_barn2.jpg' (38 KB)
Preview of image 'cornell's_barn2.jpg'
Subject: Re: different lighting (37.6kb jpg)
Date: 21 Jun 2002 18:24:28
Message: <3d13a79c$1@news.povray.org>
I don't know why or how you are able to continue posting images of higher
quality than most of us. These are some of the best radiosity scenes I've
seen in POV!
I'm especially impressed by the apparently small amount of time you need to
code these things. You must have a lot of experience.
Hugo
Date: 21 Jun 2002 18:49:03
Message: <3d13ad5f@news.povray.org>
> inside. Questions, Comments?
Nice idea and image....
...but that's just a cheap trick, you have to use media (^&
Date: 21 Jun 2002 19:32:00
Message: <3D13B76C.2020804@caltel.com>
Corey Woodworth wrote:
> Beautiful effect!
More kudos for the POV Team :)
Hmm, what about a room with a dirty or frosted window, where only part
of the light shines through directly, and the rest is scattered? Might
be a good effect for stained-glass windows.....
Samuel Benge
Date: 21 Jun 2002 19:33:57
Message: <3d13b7e5@news.povray.org>
Wow! This one is even greater!
I'm wishing for a wallpaper which I belive would be used for a looong time
:) (or until your next pic ;-) (How about a 1024 version for my little
desktop? ;)
What hardware do you use? (fast render?)
I just have to say it again, this is great work! :)
Keep it up!
-Peter
> Q's, C's?
> Samuel Benge
Date: 21 Jun 2002 19:50:57
Message: <3D13BBDC.2000305@caltel.com>
Thanks.
> desktop? ;)
I think I can render one next time I go on a hike (when I'm home, the
only things to do are done through the computer).
P4 1.6 ghz, 256 megs ram
> Keep it up!
I will! Someday I'll even finish a scene!
Samuel Benge
