The plate is decorated with an image map derived from Steven Abbots'
Knots3D program. The left stem is UVmapped bimap, the right stem is
procedural.
Download 'v10053.jpg' (23 KB)
Preview of image 'v10053.jpg'
Now, those look tasty!
Cheers!
Chip Shults
> procedural.
very impressive, but they dont look like real grapes :)
PGP Public Key
Version: 6.0.370 / Virus Database: 205 - Release Date: 05/06/2002
> procedural.
The stems look much better now, but the grapes still have that solid
look to them.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/ * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\( ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~ -/__\\__\\__\\__\\__\\*//* Steve */
I agree, the image is great but it doesn't look real.
"Rick [Kitty5]" <ric### [at] kitty5 com> wrote in message
news:3d0636f9@news.povray.org...
> > procedural.
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> POV-Ray News & Resources - http://Povray.co.uk
> TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
> PGP Public Key
> Checked by AVG anti-virus system (http://www.grisoft.com).
stems look a LOT better! still can't put my finger on whats wrong with the
grapes though.
Corey
schitzo.y0ru.net
blob{threshold#macro _(s,i,g)#if(s)sphere{20*(i-<5,1,-10>)16,1pigment
{rgb 9}}_(s-1i+g,g)#end#end.7_(4x,x)_(2,0y)_(5y*2x)_(5x*6x)_(3<6,
1>2*x)_(2<6,2>4*x)}
hi jim,
beautiful work! just awesome. the one thing i think that
is a lil off on the grapes is the same thing you run into with
teeth... they are translucent to a degree. you can see inside
a bit. like somebody said, they seem too "solid".
but thats just a tiny issue. the picture is beautiful as is.
miker
"Jim Charter" <jrc### [at] aol com> wrote in message
news:3D0### [at] aol com...
> procedural.
that is a sweet image... when you finish it and have a good composition,
(meaning the "art" of the scene is comeplted as well as the models,
etc.) I'd render a large image and submit it to the galelry of some
print 3d mags. Expect publication, and MENTION POV! :)
-peter
Modeling slave:
"Ballet pour ma fille."
http://www.applesnake.net
> procedural.
Really nice. Only the problem about that solid aspect... can't you apply
some kind of faked subsurface scattering? I think it's the only detail
missing: perfect for the rest!
Jaime Vives Piqueres
http://www.ignorancia.org
Thankyou...
believe it or not, the whole thing began when I wanted to play with the
"subscattering"
code others had posted:
#declare m_red_grape = material {
#declare Color= rgb <.50,.15,.11>;
#declare factor= 1.25;
texture { //create veining
pigment { radial frequency 80 turbulence .25
color_map {
[0.00 rgb Color/1 ]
[0.07 rgb Color/1 ]
[0.08 rgb Clear ]
[0.92 rgb Clear ]
[0.93 rgb Color/1 ]
[1.00 rgb Color/1 ]
finish { specular .05
diffuse .7
roughness .02
reflection 0
texture { //create darkening toward the end of grape
pigment { gradient y scale 14
color_map {
[0.0 rgb <.30,.1,.85>*Color transmit .10 ]
[1.0 rgb <.30,.2,.65>*Color transmit .70 ]
translate y*7
diffuse .7
roughness .02
reflection 0
texture { //bloom on skin of grape
pigment { dents scale 1.5 rotate 10 pigment_map {
[ 0 rgb Clear ]
[ .10 rgb Clear ]
[ .49 LightBlue transmit .97 ]
[ .51 LightBlue transmit .97 ]
[ .90 rgb Clear ][ 1 rgb Clear ] } }
diffuse .7
roughness .2
reflection 0
pigment { dents scale 1 pigment_map {
[ 0 rgb Clear ]
[ .10 rgb Clear ]
diffuse .7
roughness .2
reflection 0
pigment { dents scale .5 pigment_map {
[ 0 rgb Clear ]
[ .10 rgb Clear ]
[ .5 LightBlue transmit .99 ]
diffuse .7
roughness .2
reflection 0
interior {
media {
//scattering { 1, (1-Color)*factor extinction
1/factor }
scattering { 1, Color*factor extinction 1/factor }
absorption rgb (1-Color)*factor
emission Color*factor
intervals 1
samples 5
method 3
