POV-Ray : Newsgroups : povray.binaries.images : WIP a bit closer... Server Time
14 May 2026 23:14:59 EDT (-0400)
  WIP a bit closer... (Message 1 to 8 of 8)
Subject: WIP a bit closer...
Date: 4 Jun 2002 04:11:08
Message: <3CFC7616.2020204@bellsouth.net>
Faboo.  Interior of tube is basically what I want, Poser model is
halfway decent (need to make unique ones for each chamber)...need to
touch up rest of it, make walls more complex, more pipes in an
organic-looking mess.  Trick is doing it by hand.
Stats:
Scene contains 483 frame level objects; 2 infinite.
Statistics for genomapnewc.pov, Resolution 800 x 600
Pixels:          600800   Samples:         4447200   Smpls/Pxl: 7.40
Rays:          57408282   Saved:          10247207   Max Level: 50/50
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                          913598433       879905280     96.31
Cone/Cylinder              86149052231      7044344293      8.18
CSG Intersection            3179449142      1980832164     62.30
CSG Merge                    130590215         4166836      3.19
CSG Union                   2948879319      1152180314     39.07
Mesh                         266731270        54878221     20.57
Plane                       1747477792       936281722     53.58
Sphere                       771731398       771645929     99.99
Torus                       3932559904        83891944      2.13
Torus Bound                 3932559904       104776191      2.66
Bounding Box               14808358995      7003860466     47.30
Light Buffer               26756948797     16022827082     59.88
Vista Buffer                  76162862        57321127     75.26
Roots tested:            104776191   eliminated:              657425
Calls to Noise:           36267965   Calls to DNoise:        3522570
Media Intervals:         198105863   Media Samples:       1006386925 (5.08)
Shadow Ray Tests:       1896938875   Succeeded:           1598518355
Reflected Rays:           27642815
Transmitted Rays:         25318267
Smallest Alloc:                 25 bytes   Largest:          4320024
Peak memory used:         63349224 bytes
Time For Parse:    0 hours  0 minutes   4.0 seconds (4 seconds)
Time For Trace:   15 hours 29 minutes  44.0 seconds (55784 seconds)
     Total Time:   15 hours 29 minutes  48.0 seconds (55788 seconds)
CPU time used: kernel 25.72 seconds, user 52416.31 seconds, total
52442.03 seconds
Render averaged 9.15 PPS over 480000 pixels
Tim Cook
Version: 3.12
Download '2002-06-03_genomapnewc.jpg' (58 KB)
Preview of image '2002-06-03_genomapnewc.jpg'
Subject: Re: WIP a bit closer...
Date: 4 Jun 2002 04:58:57
Message: <3CFC813E.D17FA3C6@gmx.de>
This does look promising.
What does this actually represent?
If this is something Borg-like, the lights are far too bright,
if this is like a sleeping chamber for long space travel, you
definetely need to use a little warmer light.
Perhaps some bubbles inside the tubes would look great, though
I don't know if they'd show up on this resolution. Or, you
could add some media to make the liquid a little more hazy,
fogged in different parts...
Very good, I hope to see some more of it...
Tim Nikias
Email: Tim### [at] gmxde
Date: 4 Jun 2002 07:16:24
Message: <3CFCA185.3040102@bellsouth.net>
Sort of a computer interface thing, somewhat similar to
the navigation chamber on Outlaw Star or the thing Rei
was in in NGE ep 17 (form, not function...possibly akin
to the Outlaw Star nav thing, tho I want the tangle of
pipes at the top from NGE)
If it's a sleeping chamber for LTST, why need light at all... -_-
> Or, you could add some media to make the liquid a little
> more hazy, fogged in different parts...
Actually, I AM using media...hold on, I'll see if I can
render in a reasonable amount of time the same scene without
the reflective/specularly highlit glass and surface texture
of the media...
...I'll post it when it's done. :b
Tim Cook
Version: 3.12
Date: 4 Jun 2002 07:26:47
Message: <3CFCA3F3.3090607@bellsouth.net>
Har et be, smaller, lesser quality.
The media isn't EXACTLY what I'm wanting, but I'm gonna play
around with the rest of the scene before slamming my head
repeatedly against media again...media's a pain to work with.
The settings that worked fine for my other scene didn't work
at all with this one, etc.
Tim Cook
Version: 3.12
Download 'junk.jpg' (25 KB)
Preview of image 'junk.jpg'
Date: 4 Jun 2002 08:09:21
Message: <3CFCADE0.F9E46570@gmx.de>
Hm. Perhaps you should try scattering media
lit from underneath/above...
In my opinion, the media should have more wisps and
layers, if you know what I mean. Something more foggy
at least.
But keep up the good work!
Tim Nikias
Date: 4 Jun 2002 10:02:29
Message: <3CFCCCF7.4030807@caltel.com>
The room is mothing to scream about yet, but those poser models are
expertly rendered! They don't have that 'plastic look' to them, plus the
light interaction with them seems to be very close to real. What media
settings did you use?
> Stats:
> 52442.03 seconds
Samuel Benge
sbe### [at] caltelcom
Date: 4 Jun 2002 10:37:56
Message: <3CFCD0C1.8030308@bellsouth.net>
Hmm might be simply the fact they're being lit full-tilt by 3
'spotlights' (ok point lights inside of hollowed spheres with
a hole for the light ^_^;)...usually people try subdued, even
lighting that reaches all parts evenly...tho I do have to give
major kudos to the poser model itself; I like its proportions
better than the default one's...it still can't pose worth crap
though, which is why the metal band in the middle's there;
moving the legs at all screws up the pelvic region.
Suggestions for room-filling?
> What media settings did you use?
Looksa somesin' lika zis:
#declare Water_Interior = material{
   texture{
     pigment{
       color rgbt <0.0, 0.5, 0.0, 0.8>
   interior{
     caustics 0.75
     media{
       samples 1,2
       variance 1.0/5.0
       ratio 0.071
       absorption rgb <0.75, 0.0, 0.0>
       emission rgb <0.0, 1.0, 0.8>
       scattering{
         4, rgb <0.642857, 0.857143, 0.785714> // rayleigh scattering
       density{
         cylindrical
Tim Cook
Version: 3.12
Date: 4 Jun 2002 14:50:44
Message: <3CFD1087.4080700@caltel.com>
Well, it needs some technologifying done to it. Maybe thin, flexible,
semi-transparent circuits coming from data storage units attached to the
walls. Gravity plating for the floors, air-recycling wall panels,
computer interfaces hanging from the ceiling, stuff like that.
<clip>
You mean you didn't use media for the humans? They look pretty good , like they did
have scattering media.
Samuel Benge
