POV-Ray : Newsgroups : povray.binaries.images : Strange Server Time
24 Dec 2025 16:17:53 EST (-0500)
  Strange (Message 1 to 7 of 7)
Subject: Strange
Date: 1 Jun 2002 09:22:32
Message: <3CF8CA8F.6000503@bellsouth.net>
The only difference between these two pictures is the first uses a cube
as the reflective surface, the second uses a plane.  Why does the plane
cause the media to not show up?
Tim Cook
Version: 3.12
Download 'testa.jpg' (26 KB) Download 'testb.jpg' (25 KB)
Preview of image 'testa.jpg'
Preview of image 'testb.jpg'
Subject: Re: Strange
Date: 1 Jun 2002 09:34:23
Message: <3cf8cd5f@news.povray.org>
What reflective surface? Did you try hollow?
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 1 Jun 2002 09:38:28
Message: <3CF8CE55.992CFAF5@US1.IBM.COM>
Tim,  Are you using the 'hollow on' option with the plane?
Date: 1 Jun 2002 09:43:48
Message: <3CF8CF90.2030009@bellsouth.net>
Nope.  Should I?
...how can a plane be hollow? ^_^;
Tim Cook
Version: 3.12
Date: 1 Jun 2002 09:45:43
Message: <3cf8d007$1@news.povray.org>
Planes have an inside and an outside.  The normal vector points in the
direction of the outside.  If your media is essesntailly inside the plane it
won't render, check the message window, it should say something about being
inside non-hollow objects. Either reverse the normal of the plane or, as
other said, add the "hollow" keyword.
-tgq
Date: 1 Jun 2002 09:59:14
Message: <3CF8D31E.6020302@videotron.ca>
> Nope.  Should I?
Because a plane in POV is not just an infintely thin surface.  It has an
  outside and an inside.  Like in the image below.
       ^ outside
         inside
Therefore, if you have media below your plane, you have to add "hollow
on" to your plane definition for it to show up.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 3 Jun 2002 13:09:24
Message: <jerry-98F607.10092403062002@netplex.aussie.org>
In article <3CF### [at] bellsouthnet>,
I discuss this a little bit on my d10 tutorial at
http://www.hoboes.com/NetLife/POV/Die10/
Planes are solid objects, too, they're just shy about it :*)
Jerry
http://www.hoboes.com/jerry/
"Give a man a fish and you feed him for a day. Teach him to fish, and you've
depleted the lake."--It Isn't Murder If They're Yankees
(http://www.hoboes.com/jerry/Murder/)
