POV-Ray : Newsgroups : povray.binaries.images : is there a way to make a laser Server Time
18 Jul 2026 07:42:53 EDT (-0400)
  is there a way to make a laser (Message 11 to 14 of 14)
Subject: Re: is there a way to make a laser
Date: 23 May 2002 00:45:30
Message: <3CEC73CF.F75C3AC5@gmx.de>
I am not really firm in stuff regarding functions. For all
I know, eval_pigment will return you only the rgb-component,
and this wouldn't be slope-dependant. If this is correct, it would
be of no use for the thing we're trying to achieve.
Also, we couldn't do a trace against a union/merge, since we
wouldn't know, which objecs of that union/merge we are
actually hitting. We need to look at the different objects
one by one, check, which is the nearest (first) intersection,
look for the reflection-variables in already mentioned array,
and calculate the actual reflection-values from there.
It in fact we do have a slope-independant pigment, we might
use eval_pigment after all in case we want to calculate the
influence of the color on the reflected laserbeam.
All this together would be one major project, as you need a
very intuitive use of pigments/reflections/arrays for users to
quickly set everything, e.g. by calling macros at the appropriate
places.
Batronyx wrote:
> "Tim Nikias" <tim### [at] gmxde> wrote in message
> news:3CEC3A25.46062591@gmx.de...
> > I think he was referring to the amount of reflection, as
> > reflection .4 or even in version 3.5 reflection{.2,.7} would
> > be something far different from 100% mirror-like reflection...
> > AFAIK it is not possible to return those, unless you use
> > trace on objects, of which you have set the reflection inside
> > an array. A macro could trace the object, check the reflection
> > in the array, and return intersection point, surface normal, and
> > reflection value.
> Yeah, that makes more sense upon re-reading. <DOH!> Thanks for setting me
> straight.
> Let me see if I follow you correctly here; you might not need an array for a
> single simple object with an explicit reflection value set in the texture, but
> an array would be handy for a union/merge object and/or complex texture mapped
> objects right?  If so, how might you get the values for variable reflection,
> and/or the interpolated values within a pigment_pattern or image_pattern? The
> eval_pigment() function in functions.inc ?
> Batronyx ^"^
Tim Nikias
Email: Tim### [at] gmxde
Date: 23 May 2002 07:16:37
Message: <3ceccf95@news.povray.org>
news:3CEC73CF.F75C3AC5@gmx.de...
<snip>
Yeh - IMHO it would be a nightmare to implement unless it was possible to return
the reflection component, etc. of a point.
Without this, any scene where you wanted to simulate a laser bouncing around
would require a very complex setup.
Date: 23 May 2002 19:22:22
Message: <3ced79ae@news.povray.org>
Why would a mirror have angle-dependant reflection?
Grim
> <snip>
> possible to return the reflection component, etc. of a point.
> around would require a very complex setup.
Date: 23 May 2002 20:13:41
Message: <3ced85b5@news.povray.org>
Actually, I was thinking of using the .gray value of the function as a mapping
parameter from which to approximate the interpolated values, but even this won't
work if we're talking blended/layered textures, since the color could be off and
skew the results.
I think that might depend on the object, but I have to agree it would be hard to
achieve consistency without the arrays.
Can't disagree here either.
> places.
Yep, it could get messy.
