POV-Ray : Newsgroups : povray.binaries.images : Platonic solids 140kbbu Server Time
25 Jun 2026 10:06:07 EDT (-0400)
  Platonic solids 140kbbu (Message 1 to 10 of 11)
Subject: Platonic solids 140kbbu
Date: 15 Mar 2002 22:52:41
Message: <3C92BEE6.32D29920@global2000.net>
I got coordinates for the Platonic solids from the web site mentioned in
p.g.:
http://astronomy.swin.edu.au/~pbourke/polyhedra/
The tetrahedron, octahedron and icosahedron could be converted directly.
The cube was easy to figure out with two triangles per face.  I used
three triangles per face for the dodecahedron.
After converting the coordinates, I souped things up with the ancient
Greek elements.
Brendan
Download 'brpolyhedra.png' (141 KB)
Preview of image 'brpolyhedra.png'
Subject: Re: Platonic solids 140kbbu
Date: 16 Mar 2002 00:24:57
Message: <3C92D7D3.94DCC74B@sw-tech.com>
> p.g.:
Hey, that's exactly where I got mine from.  :)
That sounds familiar, yes.
> Greek elements.
I basically used P and I, as in Paul Bourke's pages.  Wanna compare code?
Drop me an email.
I really like the texture on the cube and on the dodecahedron.
Deaken
Date: 16 Mar 2002 02:41:12
Message: <3c92f718@news.povray.org>
You know what I like about that shape second from the right? When you first
look at it, it seems like it has a top and bottom, and is taller than it is
wide. But if you rotate it around, you can see that any of the vertices can
be the top or bottom, and it is in fact symmetrical in more ways than it
first appeared.
I found this out a long time ago when I made one out of cardboard for the
heck of it. =)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 16 Mar 2002 12:07:57
Message: <3C937C50.D0181FB6@pandora.be>
Hello,
If you want to read something about how the coodinates of the vertices
of a dodecahedron and icosahedron can be obtained starting from a cube:
take a look at some of my pages.
http://cage.rug.ac.be/~hs/
In this way one can see how the golden number/golden section occur in
those two solids.
A number of pictures are produced using POVRAY.
But P. Bourke has done a very interesting work in publishing the data
for people who aren't very interested in the mathematics behind those
polyhdra, and like their beauty!
I agree that I don't have such nice textures! I'd liked to learn more
about the possibilies of POVRAY!
Herman Serras
> p.g.:
> Greek elements.
> Brendan
Herman Serras
Gent (Belgium)
Date: 16 Mar 2002 21:55:04
Message: <3C940336.FB3CF2DC@global2000.net>
I made the Platonic solids out of paper from a cutout and noticed that
effect with the octahedron.
I plan on making more sturdy models sometimes; large, sturdy and
colorful.
Brendan
> first appeared.
> heck of it. =)
Date: 16 Mar 2002 22:10:26
Message: <3C9406D2.3676E484@global2000.net>
Deaken wrote:
> > p.g.:
Herman's web site should help with getting coordinates for other
polyhedra.
> Drop me an email.
Sent.
> >  [Image]
Thanks, I thought that they were simplistic.
Brendan
Date: 16 Mar 2002 22:26:25
Message: <3C940A91.8241B0E0@global2000.net>
Herman Serras wrote:
> Hello,
> those two solids.
Interesting read and links.  My math teacher should like this.
The tetrahedron has a color map where I used "hot" colors including
2*<1,1,0> for bright yellow in a marble pattern.
The octahedron has a color map with a wrinkle pattern and blue colors
that I picked out with the pick o color program.
I put the pigment into my sky include file.  The cube or hexahedron has
a pigment map that uses stone and concrete pigments,
which I made for my museum, in a gradient y pattern.  The icosahedron
has a marble color map that uses deeper blues I chose
from the color picking program.  The dodecahedron has a granite pattern
with a little white and a lot of gray25 as rgb .25.  It
also has a low filter value of .15.
I intended the polyhedra to represent the ancient greek elements.
tetrahedron	fire
octahedron	air
cube		earth
icosahedron	water
dodecahedron	ether
The texture on the plane was first developed for my Venus celestial box
(sun and moon ones posted on December 31).
Brendan
Subject: Re: Platonic solids 140kbbu - the 4 regular non-convex solids
Date: 17 Mar 2002 03:15:25
Message: <3C945103.E0369F26@pandora.be>
Hello,
The 5 Platonic solids are the only possible CONVEX regular solids. If
one allows regular solids to be NON-CONVEX there exist (only) 4 more
types of regular solids. They are known as the Kepler-Poinsot solids.
On my website http://cage.rug.ac.be/~hs a page is devoted to those
solids. All images, some of them animated, were produced using POVRAY.
Although on the web one can find the coordinates of the vertices in a
numerical form and also the important data concerning the faces ex.
http://mac.povray.org/download/binaries/uniformia/uniform.html
I derived this data starting from the underlying dodecahedron or
icosahedron. The data expressed in an exact form better show the
appearance of the golden section in all of those solids.
The paper models of the solids are very nice!
Friendly greetings,
Herman
> > Hello,
> > those two solids.
> tetrahedron     fire
> octahedron      air
> cube            earth
> icosahedron     water
> dodecahedron    ether
> Brendan
Herman Serras
Gent (Belgium)
Date: 17 Mar 2002 04:42:03
Message: <3C946598.C383FF5@sw-tech.com>
Brendan Ryan wrote:
> Deaken wrote:
> > > p.g.:
> polyhedra.
I probably have that bookmarked somewhere.  I was all over the place looking
for coordinates I could actually use.
> > Drop me an email.
> Sent.
Thanks.  I'll dig up my code later and compare it (and, of course, shoot you
a copy).  From what I've seen, though, yours looks a lot simpler than mine.
I DO tend to overwork things.
Not mutually exclusive.  :)
Deaken
Date: 17 Mar 2002 04:54:44
Message: <3C946890.9EBDCD29@sw-tech.com>
Deaken wrote:
> > polyhedra.
I just went back and looked.  I have it bookmarked three times.
Yes, bookmarks sure keep ME organized and help me find things on the web.
Deaken
