POV-Ray : Newsgroups : povray.binaries.images : Help I need it Server Time
23 Jun 2026 14:57:19 EDT (-0400)
  Help I need it (Message 1 to 10 of 19)
Subject: Help I need it
Date: 14 Mar 2002 18:08:30
Message: <3C912D56.1030405@gates.com>
Hi all I need some help making some shapes,
I'm trying to kane an octahedron without taking a box and cutting off
edges, as I later want to make a regular dodecahedron and an icosahedron.
I finally found the prisim and it makes good stuff for other things but
i'm still new and cant find how to make the shapes above thanks for the
help!
this is what I have to do ?  but remember i'm new!
#declare cutter =
box {
<2.1,2.1,2.1>
<-2.1,-2.1,-2.1>
pigment {Green}
translate  <0,3.5,0>
difference {
box {
<2,2,2>
<-2,-2,-2>
pigment {Green}
object {cutter  rotate x*45}
object {cutter  rotate x*-45}
object {cutter  rotate x*45 scale -1}
object {cutter  rotate x*-45 scale -1}
object {cutter  rotate z*45}
object {cutter  rotate z*-45}
object {cutter  rotate z*45 scale -1}
object {cutter  rotate z*-45 scale -1}
Download 'shapes for conn.bmp.dat' (226 KB)
Subject: Re: Help I need it
Date: 14 Mar 2002 18:50:05
Message: <3C91372C.2060503@gates.com>
did the pic work It didnt on my end when I tried to use it so here it is
again
srry all
> help!
> #declare cutter =
> box {
> <2.1,2.1,2.1>
> <-2.1,-2.1,-2.1>
> pigment {Green}
> translate  <0,3.5,0>
> difference {
> box {
> <2,2,2>
> <-2,-2,-2>
> pigment {Green}
Download 'tetrahedron.jpg' (18 KB)
Preview of image 'tetrahedron.jpg'
Date: 14 Mar 2002 19:23:05
Message: <3c913ee9$1@news.povray.org>
I could see the first pic no problem.
I confess I have no idea how your box approach is working. The way I'd suggest
doing a regular octahedron is with plane intersections like this:
intersection {
    plane { < 1, 1, 1>, 1 }
    plane { < 1, 1,-1>, 1 }
    plane { < 1,-1, 1>, 1 }
    plane { < 1,-1,-1>, 1 }
    plane { <-1, 1, 1>, 1 }
    plane { <-1, 1,-1>, 1 }
    plane { <-1,-1, 1>, 1 }
    plane { <-1,-1,-1>, 1 }
8 planes to describe an 8 sided solid :)
Hope this helps.
Tek
http://www.evilsuperbrain.com
Flaming Monarch <fla### [at] gatescom> wrote in message
news:3C9### [at] gatescom...
> again
> srry all
> > help!
> > #declare cutter =
> > box {
> > <2.1,2.1,2.1>
> > <-2.1,-2.1,-2.1>
> > pigment {Green}
> > translate  <0,3.5,0>
> > difference {
> > box {
> > <2,2,2>
> > <-2,-2,-2>
> > pigment {Green}
Date: 14 Mar 2002 20:20:17
Message: <3C914C51.5010808@gates.com>
My box aproach was made by using the difference of the cutters and a
main box
> intersection {
> Hope this helps.
> Tek
>>again
>>srry all
>>>help!
>>>#declare cutter =
>>>box {
>>><2.1,2.1,2.1>
>>><-2.1,-2.1,-2.1>
>>>pigment {Green}
>>>translate  <0,3.5,0>
>>>difference {
>>>box {
>>><2,2,2>
>>><-2,-2,-2>
>>>pigment {Green}
Date: 14 Mar 2002 20:26:38
Message: <3C914DCD.90202@gates.com>
Cool I never thought of that way with the intersecting planes and stuff.
it worked and the code was tonnes shorter here is the way it loooked
the blue one is yours and the green mine
> intersection {
> Hope this helps.
> Tek
>>again
>>srry all
>>>help!
>>>#declare cutter =
>>>box {
>>><2.1,2.1,2.1>
>>><-2.1,-2.1,-2.1>
>>>pigment {Green}
>>>translate  <0,3.5,0>
>>>difference {
>>>box {
>>><2,2,2>
>>><-2,-2,-2>
>>>pigment {Green}
Download 'two of em.jpg' (18 KB)
Preview of image 'two of em.jpg'
Date: 14 Mar 2002 22:36:39
Message: <chrishuff-1B7E91.22361914032002@netplex.aussie.org>
In article <3c913ee9$1@news.povray.org>, "Tek" <tek### [at] evilsuperbraincom>
> I'd suggest doing a regular octahedron is with plane intersections
> like this:
...snip...
Note that POV has no idea how to bound this, so it is completely
unbounded...POV will test against it for every ray traced. This isn't
much of a problem just for one, but if you use a large number of them
you should use an appropriate bounded_by statement.
You could also use an intersection of 2 or more boxes, which might be
faster and won't need manual bounding as badly...POV will be able to
come up with a bounding box, just not a perfect one.
Date: 14 Mar 2002 22:47:19
Message: <3c916ec7@news.povray.org>
The corners for the octahedron would be:
 Corner1 = <0,1,0>
Corner2 = <1,0,0>
Corner3 = <0,0,1>
Corner4 = <-1,0,0>
Corner5 = <0,0,-1>
Corner6 = <0,-1,0>
Just make triangles out of these. This will give you the fastest octahedron.
#mesh {
 triangle {Corner1, Corner2, Corner3}
 triangle {Corner1, Corner3, Corner4}
 triangle {Corner1, Corner4, Corner5}
 triangle {Corner1, Corner5, Corner2}
 triangle {Corner6, Corner2, Corner3}
 triangle {Corner6, Corner3, Corner4}
 triangle {Corner6, Corner4, Corner5}
 triangle {Corner6, Corner5, Corner2}
} /* end mesh */
 -Shay
 -Shay
"Flaming Monarch" <fla### [at] gatescom> wrote in message
Date: 14 Mar 2002 23:39:50
Message: <3c917b16$1@news.povray.org>
The simplest way to make an octahedron is the intersection of two
rectangular boxes.
object {intersection {
  object {box{<-2,-1,-1>, <2,1,1>} rotate 45*x}
  object {box{<-1,-1,-2>, <1,1,2>} rotate 45*z}
  pigment {color Green}
  finish {roughness .1 specular .1} }
    Note that since the diagonal aspect is sqrt(2) you can take the 2's
above to 1.414 or so with the same results.  If you make it smaller than
that, it will trim the equator very nicely.  Now, two more rectangular
solids can trim the remaining 8 edges with no trouble at all.  Two solids,
one octahedron.  Four solids, one trimmed octahedron.
    For a perfectly symmetrical octahedron, scale the z axis to 1.414, for
obvious reasons.
Cheers!
Chip Shults
Subject: Re: Help I need it- okay, here it is
Date: 14 Mar 2002 23:51:45
Message: <3c917de1@news.povray.org>
Oh, yes- once you scale the octahedron at 1.414*y, since it is perfectly
symmetrical, you can then use one more cube and trim it into a perfect
cuboctahedron like this:
// start of POV code
#declare octahedron = intersection {
  object {octahedron scale 1.414*y }
  object {box{-1, 1} rotate 45*y pigment {color Green} finish {roughness .1
specular .1} }
// end of POV code
  Note the attached image.
Cheers!
Chip Shults
Download 'Octahedr.jpg' (8 KB)
Preview of image 'Octahedr.jpg'
Date: 15 Mar 2002 01:43:23
Message: <hyu$jGAjcZk8Ew+c@econym.demon.co.uk>
>help!
#include "shapes2.inc"
object {Octahedron}
Mike Williams
Gentleman of Leisure
