POV-Ray : Newsgroups : povray.binaries.images : PIP: deformation of tesselation [about 50Kbu] Server Time
25 Dec 2025 10:48:27 EST (-0500)
  PIP: deformation of tesselation [about 50Kbu] (Message 1 to 10 of 12)
Subject: PIP: deformation of tesselation [about 50Kbu]
Date: 22 Feb 2002 03:31:10
Message: <3C7601EF.F5AFF63E@atosorigin.com>
On my slow 180MHz Pentium-MMX Linux, with X-display while rendering.
toto is the box;
#declare Objiii = box { <-0.9,0.1,0.1>,<0.9,.9,.9> rotate <0,90,0> }
warp { cristal{ Objiii ,  50 },  { turbulence 0.4*<1,0.3,0.5> octaves 2 } }
toto.pov Statistics, Resolution 600 x 600
Pixels:          360600   Samples:          437944   Smpls/Pxl: 1.21
Rays:            437944   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                    56321           34047     60.45
Mesh                            550386           82517     14.99
Sphere                           12451            5458     43.84
Bounding Box                  27495693         6971608     25.36
Light Buffer                    286833          209700     73.11
Vista Buffer                   2482051         1890933     76.18
Calls to Noise:                  0   Calls to DNoise:         360010
Shadow Ray Tests:           502792   Succeeded:                 9883
Peak memory used:         12321265 bytes
Time For Parse:    0 hours  0 minutes  21.0 seconds (21 seconds)
Time For Trace:    0 hours  1 minutes   8.0 seconds (68 seconds)
    Total Time:    0 hours  1 minutes  29.0 seconds (89 seconds)
titi is the sphere;
#declare Objiii =  sphere { 0,0.9 }
warp {bourke{ Objiii  accuracy 70 precision 20},{ turbulence 0.4*<1,0.3,0.5> octaves 2
titi.pov Statistics, Resolution 600 x 600
Pixels:          360600   Samples:          434856   Smpls/Pxl: 1.21
Rays:            434856   Saved:                 0   Max Level: 1/5
Cone/Cylinder                    54091           33032     61.07
Mesh                            722007           94893     13.14
Sphere                           12534            5168     41.23
Bounding Box                  37141306        10171720     27.39
Light Buffer                    327659          274218     83.69
Vista Buffer                   2673871         2033081     76.04
Calls to Noise:                  0   Calls to DNoise:         277258
Shadow Ray Tests:           614952   Succeeded:                 6818
Peak memory used:         10907065 bytes
Time For Parse:    0 hours  0 minutes  18.0 seconds (18 seconds)
Time For Trace:    0 hours  1 minutes  27.0 seconds (87 seconds)
    Total Time:    0 hours  1 minutes  45.0 seconds (105 seconds)
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Download 'toto.jpg' (19 KB) Download 'titi.jpg' (21 KB)
Preview of image 'toto.jpg'
Preview of image 'titi.jpg'
Subject: Re: PIP: deformation of tesselation [about 50Kbu]
Date: 22 Feb 2002 03:49:38
Message: <i21c7uk4jone88b4k59to7bq03emrf7mbi@4ax.com>
Looks very interesting and promising.
Only things I want'to mention
> toto is the box;
> titi is the sphere;
2 }}
personaly I prefer another 'tesselate' keyword since
you can't use cristal or bourke in pigment{warp{}}
I mean
tesselate{
  OBJECT_ID | OBJECT
  METHOD {  METHOD_PARAMS }
  WARP { WARP_STATEMENT } | DISPLACEMENT{ PIGMENT | f_x(x,y,z),f_y(x,y,z),f_z(x,y,z) }
  OBJECT_MODS
in your example
tesselate{
  Objiii
  bourke{ accuracy 70 precision 20}
  warp{ turbulence 0.4*<1,0.3,0.5> octaves 2 }
  OBJECT
ABX
Subject: Re: deformation of tesselation [about 50Kbu]
Date: 22 Feb 2002 03:53:37
Message: <3c760711$1@news.povray.org>
Definetely cool!!!! It's time for a release! But about the deformation: Does
it simply move the vertices of the final tesselated object? In that case,
one can't apply much deformation before the triangles "collapse".
Deformation should be done before triangulation, AFAIK.
Date: 22 Feb 2002 03:58:57
Message: <702c7u8p6ovqroffnfrffa8mn24bh44386@4ax.com>
Not a problem, just do it with isosurface, and then tesselate it :-)
ABX
Date: 22 Feb 2002 07:43:10
Message: <3c763cde@news.povray.org>
Too cool... :b___
Date: 22 Feb 2002 09:16:08
Message: <1fkc7u00pfchlopedhmu2i4362qbe75nhh@4ax.com>
Definitely great!
Just one nit to pick... the correct spelling is "crystal" :)
Peter Popov ICQ : 15002700
Date: 22 Feb 2002 09:25:35
Message: <3C765500.10067431@atosorigin.com>
Peter Popov wrote:
> Definitely great!
Who said it was in english ?
Date: 22 Feb 2002 11:33:29
Message: <3c7672d9@news.povray.org>
Excellent work this could be very useful.
Mick
Date: 22 Feb 2002 16:34:06
Message: <3C76B8CE.C479F5B7@hotmail.com>
Nice !
Will it be possible to save the meshes to files ?
Tor Olav
Date: 22 Feb 2002 17:16:27
Message: <3C76C343.E6C0D514@gmx.de>
Hi there!
I may be a bit late on this one, but all I wanted is to ask for your
resources (PDF-Files, Books, HTML-Pages) because I had wanted
to do some tesselation algorithms of my own (I'm THAT kind a
guy). I haven't found much, but since you were pretty successful,
I thought I'd just ask...
You can email me too, if you want to.
Tim Nikias
