POV-Ray : Newsgroups : povray.binaries.images : Civilization of sorts, or, Fun with crackle Server Time
22 Jul 2026 19:59:47 EDT (-0400)
  Civilization of sorts, or, Fun with crackle (Message 11 to 20 of 20)
Subject: Re: Civilization of sorts, or, Fun with crackle
Date: 8 Dec 2001 23:08:47
Message: <3C12E4AF.5A130A4@faricy.net>
"Kevin iggle@mtcn" wrote:
> Understated, but definately cool!
Thanks!
Date: 12 Dec 2001 20:51:25
Message: <3c180a3a.8577140@localhost>
On Fri, 07 Dec 2001 23:53:22 -0600, David Fontaine <dav### [at] faricynet>
wrote:
>This is a multi-part message in MIME format.
>--------------8A793892BEEF8EA0C9E51442
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>Sort of, not really, based on Incan, Aztec, and Mayan stuff.  Every
>object but the cloud pigment on the sky_sphere, which is not discernably
>reflected in the brass spheres anyway, uses crackle.  Also my first use
>of rad_def.inc in 3.5, and I was quite pleased.
>The surface normals got averaged out a bit when I resized it from
>1280x960.  The stonework looks less precise than I wanted, but I
>increased the beveling in the normal to make the cracks more visible.
>Everything looks better at 1280x960.
>Comments?
	Freakin cool!
Pete
Date: 13 Dec 2001 00:40:40
Message: <3C18403C.8C676413@faricy.net>
Pet### [at] nymaliasnetalmost wrote:
>         Freakin cool!
Thanks!
Subject: version 2
Date: 13 Dec 2001 01:05:54
Message: <3C184626.AEB03636@faricy.net>
Lowered the sun's position and tweaked the surface normals a bit.  The
blue/yellow contrast from the radiosity is more pronounced now.  Perhaps
a bit dark now though, could be adjusted.
http://davidf.faricy.net/renders/civilization.jpg
(resized from 1152x864)
Subject: Re: version 2
Date: 13 Dec 2001 14:31:11
Message: <3c1901ff@news.povray.org>
news:3C184626.AEB03636@faricy.net...
Much better, but I still think it should be lower. At this angle you get a
bad line diagonally through the center of the image where you can just see
the shadow which is kind of distarcting.
Kev
Date: 13 Dec 2001 19:41:08
Message: <3C194B8A.12E2EFDA@faricy.net>
(mumble mumble groan) Though, perhaps you are right...
Subject: version 3 (final?)
Date: 15 Dec 2001 22:44:34
Message: <3C1C1987.D7BDEEFD@faricy.net>
version 2 was:
http://davidf.faricy.net/renders/civilization_.jpg
I think it's very close to finished now.  Any comments?
Subject: Re: version 3 (final?)
Date: 16 Dec 2001 06:20:02
Message: <3c1c8362@news.povray.org>
news:3C1C1987.D7BDEEFD@faricy.net...
> version 2 was:
The chipped stone looks good.  What occured to me about the vines, or
vegetation, is that there isn't any thick ground cover on the lowest flat
areas.  Guess that could be explained by the predominant places for growth
being only on angled walls.  Would be great if there were a way to get the
smaller walls to have less greenery and the larger ones more.  Not sure if
slope texturing can vary in that way.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Date: 16 Dec 2001 16:12:43
Message: <3C1D0F22.CD6E5EDB@faricy.net>
I don't think that's possible.  Also, to get better contrast between the
vegetation in the high and low flat areas, I had to make the texture
depend to much on elevation and too little on slope, and couldn't get
realistic contrast between the walls and the flat areas.  I decided this
was an okay compromise.
Maybe I could have a look into combining two vine textures, one more
dependent on elevation and one more on slope.
Date: 17 Dec 2001 09:21:47
Message: <3C1DFEFC.B740FB87@namtar.qub.ac.uk>
Is there any chance I could get a copy of the code for that Christmas
tree in your gallery? I tried to replicate it, but very weird things
started to happen, so I abandoned that pretty fast...
signature{
  "Grey Knight"
  contact{ email "gre### [at] yahoocom" }
  site_of_week{ url "http://enphilistor.users4.50megs.com/" }
