POV-Ray : Newsgroups : povray.binaries.images : My contribution to the tradition... Server Time
22 Jul 2026 21:52:59 EDT (-0400)
  My contribution to the tradition... (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: My contribution to the tradition...
Date: 24 Nov 2001 07:32:15
Message: <3BFF934C.E2931CE5@gmx.de>
Xplo Eristotle wrote:
> My intent was to make this an early morning scene. Unfortunately, while
> the sky works well for this, the lighting itself seems strongly
> reminiscent of late afternoon! (At least, to me and a lot of other
> people who've seen it.) I have no idea how to fix this; quick tests in
> Photoshop to add brighter/dimmer/cooler light only made the lighting
> look strange. I suppose I should be happy that the lighting is
> convincing enough to suggest *any* particular time of day, but I would
> be happier with the one that I was aiming for. ;)
I think the clouds look good, but a bit too red.  Some media could be good
for morning atmosphere too.
> A couple notes on radiosity settings: first, the only light_source is a
> "sun" placed well outside the room, and the count for this image was
> only 100. I achieved this level of smoothness with a high error_bound
> and a low low_error_factor (1 and .1, respectively). More testing is
> needed to determine if this method can replace typical low error_bound
> radiosity settings in other situations, unless someone's already done
> some and I missed it, but I'll let someone with a faster computer than
> mine do that testing!
Hmm, it looks really quite accurate for error_bound 1, but i am not sure
if it's a very good method. What recursion_limit did you use? Have you
tried varying pretrace_end?
> Second, judging from the color bleed on the floor,
> it appears that radiosity "bounces" off of reflective surfaces; is this
> true?
Yes, somehow. Reflection is calculated for radiosity samples.
> Third, you can see the back of the room is full of artifacts; I
> don't know if this is because of poor lighting, or because the radiosity
> data in the reflected image is only a crude approximation.
I'm not sure, but such a scene seems a quite difficult setup for radiosity
in general.  How does it look with more conventional radiosity settings?
> I'll probably keep working on this; it would make a pretty cool scene
> with window glass, blinds, pictures on the walls, maybe a ceiling fan,
> and gods know what (a table, maybe?) in the middle, even if most of it
> would only be visible in the reflection. Okay, I'll shut up and let you
> see the pic now.. comments welcome as usual.
It looks nice, my submission for the 10best cover image contest has a
similar configuration (but a bit different lighting) and i was forced to
use fairly low radiosity settings because it was that slow.
Date: 24 Nov 2001 08:25:22
Message: <3bff9fc2$1@news.povray.org>
"Xplo Eristotle" <inq### [at] unforgettablecom> wrote in message
news:3BFF76A6.F83284F6@unforgettable.com...
Yellower sunlight for morning, yellow-orange for late afternoon pre-evening.
That's my thinking on it.  And of course both can actually be quite
orange-red too if the sun is at horizon.  The colors of sunlight is a rather
important thing to consider.
> mine do that testing! Second, judging from the color bleed on the floor,
> true? Third, you can see the back of the room is full of artifacts; I
You're probably forgetting about using higher max_trace_level.  I've used
error_bound 1 before and thought it did well depending on the scene.
The back wall isn't what distracts me, it's the edges of wall and floor.
bob h
Date: 24 Nov 2001 14:24:34
Message: <3bfff3f2@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message
news:3bff9fc2$1@news.povray.org...
pre-evening.
Actually I feel that the sunlight tends to be whiter/grayer in the morning
whilst the sun is very red.
Mick
Date: 24 Nov 2001 14:25:26
Message: <3bfff426$1@news.povray.org>
I also meant to say it is cooler in the mornings with less dust in the air.
Date: 24 Nov 2001 16:39:37
Message: <3C001407.3C54E029@unforgettable.com>
recursion_limit 2, and no. As I said, my computer is slow, which
discourages extensive testing. I'll probably do some spot testing (maybe
in that top corner) later, but the current settings are good enough to
work with.
Like any other room lit mostly by radiosity: lots of artifacts, even on
flat surfaces.
The radiosity is the only slow thing in my scene; without it, this image
would render in a couple of minutes, rather than several hours.
-Xplo
Date: 24 Nov 2001 16:42:32
Message: <3C0014B8.D5F39AFE@unforgettable.com>
What effect would that have? I only have one reflective object in the
scene. (Well, technically, three, but the other two aren't really
obvious.) AFAIK, max_trace_level has no direct effect on radiosity.
-Xplo
Date: 24 Nov 2001 17:18:25
Message: <3c001cb1$1@news.povray.org>
It does have. Try setting it to 2 and you'll see (your recursion limit will
be lowered to 1).
Max_trace_level 1 disables radiosity at all...
Jonathan.
"Xplo Eristotle" <inq### [at] unforgettablecom> ha scritto nel messaggio
news:3C0014B8.D5F39AFE@unforgettable.com...
used
> -Xplo
Date: 24 Nov 2001 21:53:01
Message: <3C005D7D.3F8D7C7A@unforgettable.com>
> be lowered to 1).
So, assuming I've left it at the default of 5, and have a
recursion_limit of 2, what effect would it have again to raise the max_trace_level?
-Xplo
Date: 25 Nov 2001 05:52:31
Message: <3c00cd6f@news.povray.org>
I wasn't referring particularly to your scene. But you can  be sure that a
max_trace_level of 5 in a radiosity scene with at least ONE reflecting
object isn't enough in most cases. I don't know why but it often causes
polka dots.
I would increase it to at least 10. It shouldn't be slower.
Jonathan.
news:3C005D7D.3F8D7C7A@unforgettable.com...
will
> > be lowered to 1).
max_trace_level?
> -Xplo
Date: 25 Nov 2001 22:59:41
Message: <3C01BE2D.EB49A5B0@unforgettable.com>
> polka dots.
To tell the truth, it's probably 20. (Almost) all of my scenes have that
set in the globals, unless I change it by hand.
-Xplo
