POV-Ray : Newsgroups : povray.binaries.images : Yet another. Server Time
22 Jul 2026 23:25:31 EDT (-0400)
  Yet another. (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Yet another.
Date: 18 Nov 2001 09:24:10
Message: <3bf7c48a$1@news.povray.org>
Yes, that does seem to be the case; the 'roots' or whatever they are clearly
contact the plane underneath the waves.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Andrew" <ast### [at] hotmailcom> wrote in message
news:3bf7c404@news.povray.org...
> > 2) Your plane isn't.  A plane is a 2-dimensional entity,
> >    and your plane has the appearance of vertical variance,
> >    hence isn't strictly 2-d.
> But it could be a true plane underwater...
Date: 18 Nov 2001 12:15:40
Message: <3BF7ECBB.75C63809@gmx.de>
Kevin Wampler wrote:
> I realized that I have never done a reflective sphere over a checkered
> plane image, so I thought I'd give it a shot.  Comments/suggestions?
Neat, but i think some sky etc. around would not be bad.
Date: 18 Nov 2001 15:43:43
Message: <3bf81d7f@news.povray.org>
Original... :) I like.
Date: 18 Nov 2001 22:02:40
Message: <3BF8771D.D9627CCB@faricy.net>
"Timothy R. Cook" wrote:
> Comments:
It looks like a plane underwater to me, and besides, it could still be
2d if it only needs two variables for a parametric represnetation, ie,
has no volume, like a mesh.  Nyah nyah.  :)
Date: 18 Nov 2001 22:04:28
Message: <3BF87789.C40DF0C6@faricy.net>
Awesome idea.
Personally I would change the color of the branches a little.
Date: 18 Nov 2001 22:14:52
Message: <3BF8792D.A32C63E0@durham.ac.uk>
There is a hint or suggestion of sky in the top half of the reflection in
the sphere. it looks great. nice work!!
Date: 19 Nov 2001 03:06:51
Message: <3BF8BE9F.C4B03D43@u.arizona.edu>
> Nyah nyah ;)
I was going to mention that that's actually water over the checkered
plane, but then I remembered that the "plane" itself actually has a bump
under the plant, so I figured it wouldn't be a very good rebuttal.
	~Kevin Wampler~
Date: 19 Nov 2001 03:10:06
Message: <3BF8BF62.6B332ADF@u.arizona.edu>
Thanks!  There is a sky, generated by Chris Colefax's galaxy include
file.  I suppose that I could cove the camera so that you could see it,
but I rather like the effect of the current camera position.
	~Kevin Wampler~
Date: 19 Nov 2001 03:12:35
Message: <3BF8BFF7.49DF479B@u.arizona.edu>
David Fontaine wrote:
> Awesome idea.
Thanks!
I don't know about the overall color, but I do think that they could use
more color variation.  I suppose I might also want to use isosurfaces to
give them a very cracked bark as a surface.
	~Kevin Wampler~
Date: 27 Nov 2001 15:15:40
Message: <3C03F4C9.9F9527FA@saber.net>
Hey Kevin and Folks,
[snip]
At last a clever, novel and beautiful interpretation of a classic
Blessings,
          Brendan
Michael Brendan Hurley           ShadowDancerEnterprizes, LTD.
POV:  http://www.geocities.com/mbrendanh/index.html
HOME: http://www.saber.net/~mbhcgc/index.shtml
mbh### [at] sabernet
