POV-Ray : Newsgroups : povray.binaries.images : Motion_blur in PovRay 3.5 Server Time
22 Jul 2026 21:16:30 EDT (-0400)
  Motion_blur in PovRay 3.5 (Message 1 to 10 of 13)
Subject: Motion_blur in PovRay 3.5
Date: 2 Nov 2001 08:35:48
Message: <3BE2A162.5A9592F@contal.sk>
Can you help me, please. How to do motion_blur in PovRay 3.5 fot these
propellers. With "transmit all" I was not very succesfull
Thanks
Jozef Gatial
Download 'xf5u-povray35.jpg' (115 KB)
Preview of image 'xf5u-povray35.jpg'
Subject: Re: Motion_blur in PovRay 3.5
Date: 2 Nov 2001 09:27:23
Message: <3be2ad4b$1@news.povray.org>
3BE### [at] contalsk...
One way would be to make multiple, rotated copies of the propeller with a
transparent texture and a high enough max_trace_level.
#declare i=0;
#declare nc = 20; // number of copies
#declare maxr=15; // max angle of rotation
#while (i<nc)
    // propeller centered in <0,0,..> and oriented along z
    object{Propeller rotate z*i*maxr/nc}
    #declare i=i+1;
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 2 Nov 2001 09:43:09
Message: <3be2b0fc@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
: One way would be to make multiple, rotated copies of the propeller with a
: transparent texture and a high enough max_trace_level.
  The problem with that is that then you'll see inside the propeller.
Date: 2 Nov 2001 10:09:10
Message: <3BE2B750.A1E4AE80@contal.sk>
> #declare i=0;
> #while (i<nc)
>     #declare i=i+1;
> #end
> G.
I tried it. I'm not sure how high was my max_trace_level but space
between single copies was very dark. Maybe problem was I used for them
union and/or merge. I will try it and on Monday send to you result to
compare with MegaPov's picture. Thank you very much
Jozef Gatial
Date: 2 Nov 2001 10:16:46
Message: <3be2b8de@news.povray.org>
"Jozef Gatial" <gat### [at] contalsk> wrote in message
news:3BE2B750.A1E4AE80@contal.sk...
> > #declare i=0;
> > #while (i<nc)
> >     #declare i=i+1;
> > #end
> > G.
> Jozef Gatial
I would use something like a media filled sphere-sweep with a stretched out
sphere the same size as a prop.
- Nekar
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 2 Nov 2001 11:07:48
Message: <3be2c4d4@news.povray.org>
thats a great model. did you create it.. if so in what?
-darrell
Date: 2 Nov 2001 11:29:03
Message: <3BE2CAD5.E1A35065@reading.ac.uk>
Could you use a completely clear interior_texture, perhaps?
Just a thought ...
	Mike Andrews.
Date: 2 Nov 2001 15:30:16
Message: <3be30258$1@news.povray.org>
Here a small example (image below) :
#global_settings{max_trace_level 41}
background{rgb 1}
light_source {-z*10000 1 rotate x*25 rotate y*30}
#declare Propeller=sphere{0,0.5 translate y*0.5
 texture{
  pigment{
   gradient y
   poly_wave 0.5
   color_map{
    [0 rgbf <1,1,1,0.94>][0.95 rgbf <1,1,1,1>][1 rgbf <1,1,0.9,1>]
  finish{ambient 0 diffuse 0}
 scale <0.5,5,0.1>
 rotate -y*15
#declare i=0;
#declare maxr=30; // max angle of rotation
union{
    #while (i<nc)
        object{Propeller rotate z*maxr*((i/nc))}
        object{Propeller rotate z*i*maxr/nc rotate z*120}
        object{Propeller rotate z*i*maxr/nc rotate z*240}
        #declare i=i+1;
    difference{
     sphere{0,1}
     plane{z,0 inverse}
     texture{
      pigment{spiral1 1 color_map{[0.3 rgb 1][0.3 rgb 0]} scale <1,1,0.8>}
      finish{ambient 0 diffuse 1}
      scale <0.8,0.8,1.5>
      translate z*0.3
    rotate y*45
    translate z*10
G.
- Posters
Download 'propeller.jpg' (4 KB)
Preview of image 'propeller.jpg'
Date: 2 Nov 2001 17:10:58
Message: <3be319f2$1@news.povray.org>
Shouldn't that union be a merge? In a *real* motion blur, you wouldn't see
much of the object surfaces anyway..
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3be30258$1@news.povray.org...
> background{rgb 1}
>  texture{
>   pigment{
>    gradient y
>    poly_wave 0.5
>    color_map{
>  scale <0.5,5,0.1>
>  rotate -y*15
> #declare i=0;
> union{
>     #while (i<nc)
>         #declare i=i+1;
>     #end
>     difference{
>      sphere{0,1}
>      plane{z,0 inverse}
>      texture{
>       scale <0.8,0.8,1.5>
>       translate z*0.3
>     rotate y*45
>     translate z*10
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 2 Nov 2001 21:21:56
Message: <Xns914DD94A1336Bmrartchesapeakenet@204.213.191.226>
Jozef Gatial scribis news:3BE### [at] contalsk:
> Thanks
> Jozef Gatial
> --------------C283478265B164EFBEC96AF6
> Attachment saved: C:\MY DOWNLOADS\XNEWS\attachments\XF5U-PovRay35.jpg
> --------------C283478265B164EFBEC96AF6--
Hay, a flying pancake. Once tried to make a wood model ot this thing.
Never finished it. But what you have here is very impressive. When you have
the motioin blur worked out is will be excelant.
