POV-Ray : Newsgroups : povray.binaries.images : Took my slide caliper and started modeling... (800 x 600, 89 KB) Server Time
20 Nov 2024 00:16:59 EST (-0500)
  Took my slide caliper and started modeling... (800 x 600, 89 KB) (Message 1 to 6 of 6)
Subject: Took my slide caliper and started modeling... (800 x 600, 89 KB)
Date: 1 Nov 2001 12:03:43
Message: <3BE18E2F.48953854@ndh.net>
Hi tracers!
Here is my first attempt to exactly model everyday things...
Some time ago, I bought me a slide caliper solely for poving (...You
know you've been raytracing too much...), and when I disassembled a
defunct mouse, I was instantly inspired by these delicate small wheels
rotating between photoelectric elements when the mouse is pushed. So for
the first time, I made use of my new modelling equipment.
Any comments on the plastic textures (finish: specular 0.7, roughness
0.05, brilliance 0.5, ambient 0.1, diffuse 0.9) ?
Probably this scene will also be my stepping stone for my first
radiosity experiments... watch out!
See you in Khyberspace -
http://www.geocities.com/electricafghan/index-e.html
Afghanistan Chronicle: http://www.ndh.net/home/bleimann/
Yadgar
Download 'mousewheel04.jpg' (88 KB)
Preview of image 'mousewheel04.jpg'
Subject: Re: Took my slide caliper and started modeling... (800 x 600, 89 KB)
Date: 1 Nov 2001 13:19:10
Message: <3BE19267.DA61AB75@unforgettable.com>
Yadgar wrote:
> Hi tracers!
Looks fine, but you should probably avoid using ambient for non-glowing
objects, especially if you're intending to try radiosity later. If you
must have some kind of fill lighting, use a fill light, or global
ambient (simpler to adjust), or even use radiosity in the first place
(even extremely crude rad settings will generally produce results that
are at least as good as standard ambience, and have little effect on
render time).
-Xplo
Date: 1 Nov 2001 15:47:31
Message: <3be1b4e3@news.povray.org>
The texture is alright, but try less saturated pigment colors. It looks like
you've got things like rgb <1,0,0> in there, which is sort of ugly. Try more
subtle colors, like maybe rgb <.8,.4,.4>, or something, so they're not so
"hi, i'm RED"-ish.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Yadgar" <j.b### [at] ndhnet> wrote in message
news:3BE18E2F.48953854@ndh.net...
> Hi tracers!
> Yadgar
Date: 1 Nov 2001 17:02:22
Message: <3BE1C6D9.2394C896@hotmail.com>
Yadgar wrote:
> Hi tracers!
I usually try to do things in the opposite direction.  I ray trace
things that I want to build.  I'm looking forward to when rapid
prototyping machines get cheap.  I do really like how perfect it looks,
geometrically.
Dan Johnson
http://www.geocities.com/zapob
Date: 1 Nov 2001 20:59:04
Message: <3be1fde8@news.povray.org>
Oh, what wonders await. *sigh*
Date: 2 Nov 2001 13:10:42
Message: <3BE1E677.ADD8EDEB@ndh.net>
> "hi, i'm RED"-ish.
Yes, in fact my Red_Plastic texture has a rgb <1, 0, 0> pigment... and these
stark, trashy colours are absolutely intended, that's the way cheap plastic
parts usually look - just think of LEGO bricks!
See you in Khyberspace - http://www.geocities.com/electricafghan/index-e.html
Yadgar
