POV-Ray : Newsgroups : povray.binaries.images : How to speed up renderings with many light sources? Server Time
13 Jan 2026 16:17:05 EST (-0500)
  How to speed up renderings with many light sources? (Message 1 to 5 of 5)
Subject: How to speed up renderings with many light sources?
Date: 13 Oct 2001 19:25:57
Message: <3BC8BF65.7C9ED022@ndh.net>
Hi Tracers!
After a series of system crashes, I'm back at my megalomaniac
prehistoric colonist space ship project, still at the very first of 720
habitation modules... now I added parlor lights to each of the module's
16 floors, resulting in 4 x 16 = 64 area light sources plus the point
light of a nearby sun... and rendering speed got bogged down terribly!
On my AMD K6-II 400, at 400 x 300 resolution each line takes about 1 h
30 min! What do you suggest to accelerate rendering - should I refrain
from using area lights? Or is there any chance to speed it up and still
keep the area lights?
See you in Khyberspace -
http://www.geocities.com/electricafghan/index-e.html
Afghanistan Chronicle: http://www.ndh.net/home/bleimann/
Yadgar
Subject: Re: How to speed up renderings with many light sources?
Date: 13 Oct 2001 19:35:38
Message: <MPG.1632eeb24b69159d9896a0@news.povray.org>
In article <3BC8BF65.7C9ED022@ndh.net>, j.b### [at] ndhnet says...
Probably not every light affects the whole ship, right? So light_groups
should be a good idea...
Lutz-Peter
Date: 13 Oct 2001 19:58:46
Message: <3bc8d536@news.povray.org>
    You could write conditional statements to switch off area lights in
those modules that the camera is not close to. Putting area lights in each
module is a symptom of what I am talking about in a thread on
povray.general...
Date: 14 Oct 2001 01:12:30
Message: <3bc91ebd@news.povray.org>
1. If a light source doesn't produce visible soft shadows, then by all means
make it a point light.
  2. With all area lights you really need, use an adaptive value as small
as possible (start with 0 and see if there's any visible artifacts; if there
are, try with 1, and so on).
  3. Convert as many of your lights to spotlights as possible. Usually all
light sources in ceilings/walls can be converted to spotlights (use the
tightness value to get the proper fading; the default value might not be good
in many cases).
  4. If you are using pov3.5/megapov, use light_groups to limit the number of
objects which the light source has to be tested for. Usually a light source
only lits the room it is in (and sometimes attached rooms if there are
windows connecting them).
Date: 14 Oct 2001 10:46:38
Message: <3BC99FC6.63DC3287@ndh.net>
> Lutz-Peter
light_groups? Never heard of them (I'm still using 3.1g)...
On the other hand, of couse I put the raw light sources (upright neon
cylinders attached to the habitation module's inner parlor walls) all
together into a union (habitation_module_parlor_lamp_raw_ring_stack)... is
this what you mean?
Yadgar
