POV-Ray : Newsgroups : povray.binaries.images : Question about layered textures (19KB) Server Time
17 Jul 2026 05:50:56 EDT (-0400)
  Question about layered textures (19KB) (Message 1 to 3 of 3)
Subject: Question about layered textures (19KB)
Date: 26 Sep 2001 17:15:54
Message: <3BB24583.FE858816@hotmail.com>
I'm trying to understand layered textures better,
but I don't understand why the colors of the left
spheres in the attached image don't match the
colors of right spheres.
See my code below.
Can anyone please explain ?
And what do I have to do in order to make the
colors of the right spheres equal to the colors
of the left spheres (using subtractive color
mixing for the right ones and additive for the
left ones) ?
E.g.: Any changes to the finish {} part of the textures ?
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
#version 3.5;
#default {
    finish {
      ambient 0
      diffuse 1
// Red
sphere {
  2*<-1,  2,  0>, 2
  texture { pigment { color rgbt <1, 0, 0, 0.0> } }
// Green
sphere {
  2*<-1,  0,  0>, 2
  texture { pigment { color rgbt <0, 1, 0, 0.0> } }
// Blue
sphere {
  2*<-1, -2,  0>, 2
  texture { pigment { color rgbt <0, 0, 1, 0.0> } }
// White - Blue  - Green = Red
sphere {
  2*< 1,  2,  0>, 2
  texture { pigment { color rgbt <1, 0, 1, 0.0> } }
  texture { pigment { color rgbt <1, 1, 0, 0.5> } }
// White - Red   - Blue  = Green
sphere {
  2*< 1,  0,  0>, 2
  texture { pigment { color rgbt <1, 1, 0, 0.0> } }
  texture { pigment { color rgbt <0, 1, 1, 0.5> } }
// White - Green - Red   = Blue
sphere {
  2*< 1, -2,  0>, 2
  texture { pigment { color rgbt <0, 1, 1, 0.0> } }
  texture { pigment { color rgbt <1, 0, 1, 0.5> } }
// Red   + Green = Yellow
sphere {
  2*<-3,  2,  0>, 2
// Green + Blue  = Cyan
sphere {
  2*<-3,  0,  0>, 2
// Blue  + Red   = Magenta
sphere {
  2*<-3, -2,  0>, 2
// White - Blue  = Yellow
sphere {
  2*< 3,  2,  0>, 2
  texture { pigment { color rgbt <1, 1, 1, 0.0> } }
// White - Red   = Cyan
sphere {
  2*< 3,  0,  0>, 2
// White - Green = Magenta
sphere {
  2*< 3, -2,  0>, 2
background { color rgb <1, 1, 1>/2 }
light_source { 1000*<0, 5, -5> color rgb <1, 1, 1>*1.2 shadowless }
  location <0, 0, -14>
  look_at <0, 0, 0>
  orthographic
Download 'layered.jpg' (19 KB)
Preview of image 'layered.jpg'
Subject: Re: Question about layered textures (19KB)
Date: 26 Sep 2001 18:11:10
Message: <3BB25245.701@videotron.ca>
> See my code below.
> left ones) ?
Nope.
What happens is that when you put a color that has a non-zero transmit
component, it does a weighted average of the color and the color underneath.
for example:
is equivalent to:
     texture { pigment { color rgbt < 1, 0.5, 0.5, 0.0 > } }
That is:
#declare Weight = 0.5;
#declare Magenta = color rgb < 1, 0, 1 >;
#declare Yellow = color rgb < 1, 1, 0 >;
#declare Not_Red = Weight*Magenta + (1-Weight)*Yellow;
As you can see, the green and blue components of the final color are not
zero as a fraction of the orignal two colors is still present in the
final one.
Since layered textures are additive, to substract a color component,
you'd have to add a negative color, in other words,do the following:
    texture { pigment { color rgbt <1, -1, -1, 0.5> } }
As you can see, the second texture does not make physical sense.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 26 Sep 2001 21:01:18
Message: <3BB27A60.1574216D@hotmail.com>
Thank you very much Francois !
I think I understand rgbt better now,
but I have some more testing to do before
I'm sure about how it works.
Tor Olav
> > See my code below.
> > left ones) ?
> Nope.
> for example:
> is equivalent to:
> That is:
> final one.
> /*Francois Labreque*/#local a=x+y;#local b=x+a;#local c=a+b;#macro P(F//
> /*    flabreque    */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
> /*        @        */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
