POV-Ray : Newsgroups : povray.binaries.images : Off-topic picture of roots (79KB) Server Time
9 Jun 2026 17:01:51 EDT (-0400)
  Off-topic picture of roots (79KB) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Off-topic picture of roots (79KB)
Date: 4 May 2001 04:04:33
Message: <3AF262AF.3B56D8D@gmx.de>
Tor Olav Kristensen wrote:
> Christoph: Do you have any suggestions for good web
> sites about L-systems ?
There are quite some useful links on the LParser homepage:
http://www.xs4all.nl/~ljlapre/lparser.htm
Another package i recently mentioned, but that is quite difficult to use
is GROGRA:
http://www.uni-forst.gwdg.de/~wkurth/grogra.html
A simple online lsystem program (in german) is availabe at:
http://www.uni-koblenz.de/~grulich/lsystem.html
A general introduction is at:
http://www.csu.edu.au/complex_systems/tutorial2.html
Date: 4 May 2001 20:44:56
Message: <3af34d08$3@news.povray.org>
yooper: Interesting idea to leave blobs components
along a flock trail. I'll give this a thought (or two).
I was thinking about how roots often grow around one another . . .
and then I flashed on how the flocking algorithum employs a
collision detection function ( just what Christoph suggested be used
with an l-system algorithm).  Of course, this brings to mind your
Antiblobs . . . they also *avoid* the other components space.
I was thinking about this all night at work . . . (these things alwayz
bug me until I find a resolution ;) and I wondered if you had yet
expanded your Antiblob macro to include AntiCylinders ?  I have
no experience with them and I may be wrong but . . . doesn't POVray
or MegaPOV allow cylinders to be affected by the blob thing?
If so, then it might be possible to use tapered, curved Antiblob
cylinders to simulate growth that would have that avoid feature.
Y
got tonz of ideas . . .
& no time to follow up on any of 'em.  sad, ain't it   ;(
but I'm happy to give them away . . . as long as someone can use them ;)
Date: 7 May 2001 03:52:46
Message: <3af6544e@news.povray.org>
Started thinking about placing blobs along a trail . . .
I did a blob made up of 60 spheres . . . shifting each by 0.5
along the X axis and allowing each to randomly shift a small
amount in the Y and Z axis.
The top blob is only that ... with Strength and Radius set to 1.0
and threshold at 0.2.
For the next 3 I just varied the Strength as a funtion of the count
so that it began at ~  0.4 and ended at  0.9 for the 2nd from the
top,  1.6 for the strength of the 3rd down and  2.2 for the last.
This gave it a bit of taper . . . next I had planned on having 3
or 4 intertwine but I got sidetracked . . . started playing with
textures and ended up with an icicle sort of thing.  ;)
Some lay a good ice texture on me and I'll keep playing at it.
Back to the roots tomorrow ;)
Y
Download 'root2.jpg' (49 KB) Download 'ice.jpg' (46 KB)
Preview of image 'root2.jpg'
Preview of image 'ice.jpg'
Date: 14 May 2001 20:45:26
Message: <3B007C2A.D0199EFE@online.no>
> Y
Thank you for sharing more of these ideas of
yours yooper !
I have not yet made any "cylinder antiblobs",
but maybe it will produce exiting results.
(The math wouldn't bee too difficult I think
And yes: IIRC one can use cylinder
components within blobs.
But unfortunately at the moment I don't have
much time for POV-experimenting either.
BTW: Are you working during the night ??
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no/t-o-k/tokpicts.html
http://www.crosswinds.net/~tok
Date: 14 May 2001 21:02:31
Message: <3B00802B.EDBCD269@online.no>
David Fontaine wrote:
> Cool photo!
Thanks David.
> Yeah, that would take some pretty intense POVing.
And if one could work out the POV code,
I suspect it would take several eternities
to render...
Best regards,
Tor Olav
Date: 14 May 2001 21:04:57
Message: <3B0080BE.6B47DB15@online.no>
> is GROGRA:
Thank you very much for your links Christoph.
I've started reading now.
Best regards,
Tor Olav
Date: 14 May 2001 22:43:59
Message: <3B009886.2947EB33@pacbell.net>
> The photo below shows the roots of a little
> "bushy" tree I found.
> I find this quite fascinating and I wish
> that I could come up with a noisy pattern
> for an iso that would produce such images.
You could fake it fairly easy with a HF object but creating the base
image may be a challenge :)
Date: 15 May 2001 02:18:52
Message: <3b00ca4c$1@news.povray.org>
Ken wrote in message <3B009886.2947EB33@pacbell.net>...
>Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Indeed. Heightfields work great! See my post below. Creating the image isn't
actually all that difficult, but it is still takes some work.
Batronyx ^"^
bat### [at] cadronhsacom
http://www.batronyx.com
Bhuddist monk to hotdog vendor:
     "Make me one with everything."
Date: 17 May 2001 03:10:28
Message: <3b037964@news.povray.org>
I think you should take a look at Kevin Wamplers sig...
#version unofficial MegaPov 0.6;camera{location-z*8direction z*2look_at 0}
light_source{<-2,5,-2>*1e3 rgb 1}%K=text{ttf"cyrvetic.ttf""KEVIN".25,0
translate-1.5*x scale 1.5}%G=pigment{rgb<.8,.6,.4>}%R=seed(0);#macro B()<rand(
R)-.5,rand(R)-.5,rand(R)-.5>#end#macro A(C)%T=0;%V=<0,1,0>;#while(T<250)%S=0;%
P=B();%U=trace(K,C,P)-C;#while(S<15)%P1=B();%W=trace(K,C,P1)-C;#if(vlength(W)
<vlength(U))%P=P1;%U=trace(K,C,P)-C;#end%S=S+1;#end%V=V+P;%V=V/vlength(V);%D=(
250-T)/1e4;union{cylinder{C,C+V*.03,D}sphere{C,D}triangle{C,C+B()*D*10,C+B()*D
*4 pigment{rgb<0,.7,0>}}pigment{G}no_shadow}%C=C+V*.03;%T=T+1;#end#end%N=0;
#while(N<35)A(<(rand(R)-.5)*3, 0, rand(R)/4>*1.7)%N=N+1;#end  // Kevin Wampler
Nekar
#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);blob{#while((K-N).
x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(vlength(N-K)<vlength(
X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N,1,1 scale.02}sphere{
<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1 scale.01 }#end
pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}// Nekar Xenos
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3AF08D55.6B22895D@hotmail.com...
> Hope this is not too off-topic.
> Best regards,
> Tor Olav
Date: 25 Nov 2001 21:12:04
Message: <3C01A6B5.1E813192@pobox.com>
yooper wrote:
>   I'm wondering if one calculated the positions of the objects
> using a "flocking" algorithm as used in some ALife progs . . .
> and placed spheres or blobs (or Antiblobs !!!) along each trail,
> if the traces of their intertwining routes would look come anywhere
> close to your pattern.
Unfortunately there's nothing to keep the trails from intersecting.
Anton Sherwood  --  http://www.ogre.nu/ (online again, Nov.19)
