POV-Ray : Newsgroups : povray.binaries.images : And now for something completely different (my IRTC, take 7) Server Time
10 Jun 2026 18:24:32 EDT (-0400)
  And now for something completely different (my IRTC, take 7) (Message 20 to 29 of 49)
Subject: Re: And now for something completely different (my IRTC, take 7)
Date: 16 Apr 2001 15:09:48
Message: <3adb437c@news.povray.org>
Is it ? ... wow ...
Anyway you should try to reverse the bumps ...
From the pattern itself I think its a crackle-pattern with some
turbulence, but I maybe wrong, again ...
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro
m(a,b,i)#local d=(b-a)
/8;#local
e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d
,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan
Walzer
Date: 16 Apr 2001 19:23:13
Message: <3ADB7E0D.9AB537CE@spiritone.com>
This take looks much better, but it just needs some fog in the background to get
rid of the horizon line, which is a bit distracting.
Josh
Date: 17 Apr 2001 00:34:18
Message: <3ADBC6E4.775A0D5D@faricy.net>
I really like how you can see a lot more detail, but the mood _is_ lost.  IMO the
moss looks much better in this lighting tho.
Perhaps there is some way you could reach a mid-light-level compromise...
Date: 17 Apr 2001 07:00:42
Message: <3adc225a@news.povray.org>
Try to make the water a bit more still!
"Geoff Wedig" <wed### [at] darwincwruedu> wrote in message
news:3AD### [at] darwincwruedu...
> Ok, was playing around with the lighting and water effects on my IRTC
> and came up with this.  Totally different mood, and I'm not sure which
version
> I'll submit.  I've got a bunch of things I want to add, if this one (hey,
you
> can see more, so more there must be!)
> So what do people think?
> Geoff
Date: 17 Apr 2001 07:31:10
Message: <3adc297e@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
> Is it ? ... wow ...
It's a Ridged MF.  I'm still getting the hang of using rmf.  Any good
tutorials out there that show what the numbers actually do?  The
descriptions in the MPov docs don't really tell me much, and they're slow to
render, so I'm loathe to experiment much.
On a different topic (the original one, actually)  Why do you think the
bumps need reversed?
Geoff
Date: 17 Apr 2001 07:35:11
Message: <3adc2a6f@news.povray.org>
> e
Yeah, the mood is totally different.  I like the mood of the original, but
the mood of this one isn't bad, just... different.  Have to go with
different characters though.  The figure throwing something away just
doesn't work on a bright, sunny day.
I've tried, but I didn't get much of anywhere.  I tried using the water in
the dark, but the lighting was all screwed up by the water's ior and such.
Making the dark version too much brighter messes up the mood as well, but
maybe I can put some point sources (torches or something) to bring out some
of the details.
Hmmmm.
Geoff
Date: 17 Apr 2001 08:07:23
Message: <3adc31fb@news.povray.org>
Abe <bul### [at] taconicnet> wrote:
> A couple things I would mention.
> - In daylight this castle looks a little too clean.
Yeah.  Need to scum it up a bit more.
> - The green growth around the water line is not dark or scumy enough.
Well, since the water is a new thing, I hadn't gotten to retexturing
anything for the new pic, but you're right.
> - The person needs better texturing.
Well, the person is probably being removed, if I go with this version.  A
sad man throwing away things doesn't fit this mood.
> ... and please let the sky and clouds do justice to your work on the
> castle!
That would require developing good, fast clouds, and I don't know how (good
*or* fast, I know), and I'd rather work on details on the castle itself.
> I would be intrigued by some mysterious corresponding glow down under
> the water (does this mean a sunset for dimmer ambient lighting to afford
> appropriate contrast?).
Not necessarily.  The glow shows under the water, it just wasn't appealing.
That and the render time goes up a *lot* when doing it.
Geoff
Date: 17 Apr 2001 08:08:20
Message: <3adc3234@news.povray.org>
Yep.  On the list of 'things to be done'
However, you seem to be in the minority of those who think this is better.
Geoff
Date: 17 Apr 2001 08:10:03
Message: <3adc329a@news.povray.org>
More still?  I thought the water was a bit *too* still.  It looks a little
flat.  Needs to have some rolling waves, I thought.
Geoff
Date: 17 Apr 2001 08:46:30
Message: <3adc3b26@news.povray.org>
I'd give it a stormy sky and then of course the whirlpool. Maybe something
glowing under water to add to the mystery...
Nekar Xenos
version
you
> Geoff
