POV-Ray : Newsgroups : povray.binaries.images : And now for something completely different (my IRTC, take 7) Server Time
10 Jun 2026 15:05:35 EDT (-0400)
  And now for something completely different (my IRTC, take 7) (Message 11 to 20 of 49)
Subject: Re: And now for something completely different (my IRTC, take 7)
Date: 16 Apr 2001 10:40:34
Message: <3adb0462@news.povray.org>
> What does that phrase have to do with the Liberty Bell?
'And now for something completely different' is a famous sentence from the
Monty Python-series, which theme song was 'Liberty Bell' by a guy called
Sousa  (or am I wrong?)
It's a bit farfetched, I know, but that was the first thing that came to my
mind!
Bugs74
Date: 16 Apr 2001 10:48:10
Message: <3adb062a@news.povray.org>
> mind!
Ah, I knew the MP reference, and the tune, but not its name, so didn't see
the connection.
Geoff
Date: 16 Apr 2001 11:00:56
Message: <3adb0928@news.povray.org>
This might look cool if you kept the water and tried to light the entire
image with torches.
Geoff Wedig <wed### [at] darwincwruedu> wrote in message
news:3AD### [at] darwincwruedu...
> Ok, was playing around with the lighting and water effects on my IRTC
> and came up with this.  Totally different mood, and I'm not sure which
version
> I'll submit.  I've got a bunch of things I want to add, if this one (hey,
you
> can see more, so more there must be!)
> So what do people think?
> Geoff
Date: 16 Apr 2001 11:42:39
Message: <3adb12ef@news.povray.org>
> image with torches.
Well, the original was underlit, and it'd look funny through the water.  But
I might try it anyway.
Geoff
Date: 16 Apr 2001 13:19:18
Message: <3adb2996@news.povray.org>
Nice pic ... Details are more visible, but the mood is lost ...
If you continue this pic, try to invert the normals of the water
(bump_size -1)... it'll give a slightly better effect ...
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro
m(a,b,i)#local d=(b-a)
/8;#local
e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d
,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan
Walzer
"Geoff Wedig" <wed### [at] darwincwruedu> schrieb im Newsbeitrag
IRTC image
which version
(hey, you
> Geoff
Date: 16 Apr 2001 13:50:30
Message: <3ADB30F9.F644C9DD@taconic.net>
A couple things I would mention.
- In daylight this castle looks a little too clean.
- The green growth around the water line is not dark or scumy enough.
- The person needs better texturing.
... and please let the sky and clouds do justice to your work on the
castle!
I would be intrigued by some mysterious corresponding glow down under
the water (does this mean a sunset for dimmer ambient lighting to afford
appropriate contrast?).
Abe
Geoff Wedig wrote:
> Ok, was playing around with the lighting and water effects on my IRTC image
> and came up with this.  Totally different mood, and I'm not sure which version
> I'll submit.  I've got a bunch of things I want to add, if this one (hey, you
> Geoff
Date: 16 Apr 2001 14:10:10
Message: <3adb3582@news.povray.org>
I don't want to compete with this one, but a spiral pigment function
combined with the inside of a cone might also help. I just tried to force
the build-in function helix2 to a cone shape but the necessary gradient
and/or accuracy was far to much to give working results.
Just my 2 Pfennige,
Marc-Hendrik
Ken schrieb in Nachricht <3ADAFBD6.4E0804D3@pacbell.net>...
>This should come close -
Date: 16 Apr 2001 14:55:58
Message: <3adb403e@news.povray.org>
Well, Ken's vortex works pretty well when combined with the ridged MF that
I'm using for the basic water.  However, I'm having a little bit of a
problem controlling it.  Which numbers to change to get certain effects is
not really clear.  I'm getting the hang of it slowly, but...
Geoff
Date: 16 Apr 2001 14:56:27
Message: <3adb405b@news.povray.org>
The water is an iso, not a normal.
Geoff
Date: 16 Apr 2001 15:09:48
Message: <3adb437c@news.povray.org>
Is it ? ... wow ...
Anyway you should try to reverse the bumps ...
From the pattern itself I think its a crackle-pattern with some
turbulence, but I maybe wrong, again ...
/8;#local
,i-1)#else
Walzer
