POV-Ray : Newsgroups : povray.binaries.images : IRTC Work in Progress (about 125k) Server Time
10 Jun 2026 03:29:31 EDT (-0400)
  IRTC Work in Progress (about 125k) (Message 21 to 30 of 33)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: IRTC Work in Progress (about 125k)
Date: 19 Mar 2001 17:52:22
Message: <3AB68D5E.7804E272@post3.tele.dk>
>> when I drop the lighting so the fog is less bright,
>> the picture becomes completely dark elsewhere.
Hi again!  :o)  Just like to mention that if media is your main source
to light up the walls, you can increase the brightness of radiosity in
the global settings.
It may also help to lower the density of media, rather than decreasing
the light sources. Well, this sounds logical to me but don't ask me how;
media is a slow effect I rarely use.  :o}
And the smoke: There exsists an include file for this, maybe you would
be interested in trying it. I don't know if it's flexible enough or the
speed of rendering, but...
http://www.studenter.hb.se/~arch/smokegen/index.htm
Hugo
Date: 19 Mar 2001 20:32:30
Message: <3AB6B19F.7449FF63@spiritone.com>
Wow. The towers look very good. The brick pattern in enviable.
The sky needs a little work. It is very grainy that is a bit distraction. Also,
it is not clear what spell is being cast or what it is being cast at.
I can't wait to see how you did those bricks...
Josh
Geoff Wedig wrote:
> Well, I may not be HE Day, but that's all the more reason for me to ask for
> other people's thoughts.  So here's my current IRTC WIP.  Sorry about the size
> of the image for those with smallish monitors, but I needed to go that big
> (1024x768) to get the detail I wanted. ;)
> So thoughts?  Criticisms (constructive, of course)?
> Geoff
Date: 19 Mar 2001 20:45:05
Message: <slrn9bd6h0.krg.steve@zero-pps.localdomain>
Nice work.
 11:39pm  up 46 days,  1:22,  2 users,  load average: 1.61, 1.36, 1.20
Date: 19 Mar 2001 23:56:16
Message: <3ab6e2f0@news.povray.org>
This picture really does a great job of creating a mood. I especially like
the stone pattern. It has some regularity to it, but also an element of
randomness. I would vary the texture of the stone walls a little though, but
that's just my preference. Is each stone a separate object that can be
individually textured? If so, it might be interesting to vary each one a
little in color and/or surface texture.
The stairway is a nice touch as well.
I can't tell what the brown things are hanging out of the window... Maybe
some pipes?
Dave
"Geoff Wedig" <wed### [at] darwincwruedu> wrote in message
news:3AB### [at] darwincwruedu...
for
size
> Geoff
Date: 20 Mar 2001 00:29:45
Message: <3AB6EA2F.780C83BC@faricy.net>
You have the mood down well. The stone looks kinda plasticy to me though... hmm...
Date: 20 Mar 2001 00:41:18
Message: <3ab6ed7e@news.povray.org>
OK, I was so excited about adding my 2 cents that I didn't read the rest of
the posts first - I see that you already answered that question. I'm
convinced that adjusting the texture of those stones (slimy and wet in the
fog, dry and lighter higher up - or whatever you may have in mind...) is the
key to making this a really great picture.
"Dave Blandston" <gra### [at] earthlinknet> wrote in message
news:3ab6e2f0@news.povray.org...
Date: 20 Mar 2001 01:11:17
Message: <3ab6f485@news.povray.org>
Geoff Wedig <wed### [at] darwinepbicwruedu> wrote in message
news:3ab62a1c@news.povray.org...
> Does anyone have any data on how much longer adding a (say) granite
pigment
> to the iso takes?  The isos are deformed rounded boxes right now.
iirc adding a granite pigment function to my isosurface bricks multiplied
my render time by 5. I wasn't using radiosity however and had a lot of
lights
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Date: 20 Mar 2001 07:43:45
Message: <3ab75081@news.povray.org>
=Bob= <bob### [at] threestrandscom> wrote:
> Hi Geoff,
> Ok, here's why I think the openings don't look
> right. When I look at pictures of real castles,
> the distance between the openings (crenels)
> at the top of the turrets should be smaller than
> the material (merlons) between them, otherwise
> it's not sturdy. In some cases you have a single
> block there, so it looks cut-out, rather than built
> there. Maybe make the crenels smaller and make
> the blocks in the merlons small enough to have
> more than one. Take a look at this pic:
> http://www.castlewales.com/pembroke.html
> See how wide the merlons are?
I see what you're saying.  I based these on pics I had from my trip to
France, though.  Obviously these things varied.  However, it's really easy
to change this sort of parameter (my stone laying algorithm is really nice
that way) so I'll see what I can do.  It might knock the supports off,
though.  Right now there's a 121 correspondence between supports and
crennels (the second tower angle is off), and I like that symmetry.  Have to
see what I can do to change it.
> I wish I had some answers for you on the media.
> I'm still fuddling with it myself. Did you try the
> scattering? You might need to use some fog
> to help it too.
No problem.  Most media isn't too bad, but this is the first time I've
worked with scattering,  Upping the extinction and splitting the light in
two (one that reacts with media and one that doesn't) seems to be having
some effect, but it's not perfect yet.  Alas, it's also slowed down my image
badly.  It'd been going for 13 hours when I got up this morning and was only
half done, and all the important changes were in the bottom of the pic!
Arg.
Geoff
Date: 20 Mar 2001 07:44:55
Message: <3ab750c7@news.povray.org>
> That stones look impressive, maybe try to vary their texture individually
> to make them look more natural.
> I would also make the fog less bright and maybe add some background
> landscape between the towers.
> I would like to see some of your stone code, will you include it when you
> submit it?
I'm working on a doc for it.  Once that's done, it'll be posted here and put
on a website.  I doubt it'll be done by the IRTC submission deadline, but it
might.
Geoff
Date: 20 Mar 2001 07:46:41
Message: <3ab75131@news.povray.org>
13000+ isosurfaces.  Right now, they're just distorted rounded boxes.  :/
It's the same stone laying code from Door into Summer (posted here awhile
back) and The Summoning (IRTC Contrast round).
Geoff
