POV-Ray : Newsgroups : povray.binaries.images : Difficult simple object Server Time
16 Jul 2026 02:59:27 EDT (-0400)
  Difficult simple object (Message 1 to 8 of 8)
Subject: Difficult simple object
Date: 14 Mar 2001 18:44:53
Message: <3AB00413.F914A59D@hotmail.com>
I'm trying to make three hemispheres with different colors, and have
their overlap be a mixed color.  The first image is something I made in
gimp that illustrates the effect I want.  The second image is one of my
better attempts to make it.  I'm sure I could make it with seven
different csgs, but that would make some of the more complicated stuff I
would like to do Much more complicated.  With the image I rendered uses
media, I had to vary the diameters of the hemispheres to avoid a
coincidence surface.  I thought that media wouldn't get that bug.  Any
ideas of how to do this simply.
Dan Johnson
http://www.geocities.com/zapob
Download 'colormerge.gif' (5 KB) Download 'spherical_triangle.jpg' (8 KB)
Preview of image 'colormerge.gif'
Preview of image 'spherical_triangle.jpg'
Subject: Re: Difficult simple object
Date: 14 Mar 2001 19:09:26
Message: <3ab00836$1@news.povray.org>
That's pretty hard to do using textures, as there's not really any way to
make the colour values add together (which is what I think you're after). I
suggest you use 3 different coloured light sources (red green and blue)
shining on a white sphere, that way the colours add up nicely.
'course, that'll mean anything else in the scene will get lit that way
too... :(
Tek
http://www.evilsuperbrain.com
Date: 14 Mar 2001 21:39:21
Message: <3ab02b59@news.povray.org>
looks great all the same, i have no suggestions as to how you could do this
better (if al all!)
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 15 Mar 2001 01:09:44
Message: <3AB05C07.35607BDE@yahoo.com.au>
Is this what you were after?
Done like this...
#declare XM = (15/20)*cos(degrees(60));
#declare ZM = (15/20)*sin(degrees(60));
#declare F1 =
function
        ceil((-((x-(15/20))^2 + y^2 + z^2) + (1^2)))
#declare F2 =
function
        ((ceil((-((x+(XM))^2 + y^2 + (z-(ZM))^2) + (1^2)))))
#declare F3 =
function
        ((ceil((-((x+(XM))^2 + y^2 + (z+(ZM))^2) + (1^2)))))
#declare RGBPig =
pigment
        function
                (if((F1),1,0) +
                if(F2,2,0) +
                if(F3,4,0))/7
        scale 20
        colour_map
                [0/7 rgb <0,0,0>]
                [1/7 rgb <1,0,0>]
                [2/7 rgb <0,1,0>]
                [3/7 rgb <1,1,0>]
                [4/7 rgb <0,0,1>]
                [5/7 rgb <1,0,1>]
                [6/7 rgb <0,1,1>]
                [7/7 rgb <1,1,1>]
difference
        union
                sphere
                        <15,0,0>
                        19.99
                sphere
                        <-20*XM,0,20*ZM>
                        19.99
                sphere
                        <-20*XM,0,-20*ZM>
                        19.99
        box
                <-50,0,-50>
                <50,50,50>
        texture { pigment {RGBPig} finish { diffuse 1}}
Download 'colouradd.png' (6 KB)
Preview of image 'colouradd.png'
Date: 15 Mar 2001 17:05:08
Message: <3AB13BEB.2067CE5B@yahoo.com.au>
Ewww, sorry for that terrible coding. Here is the three hemispheres thing you
wanted, this time done using standard pigments (and pigment_pattern).
#declare Spherical_Red_Pigment =
pigment
        spherical
        colour_map
                [0 rgb 0]
                [0 rgb <3,0,0>]
                [1 rgb <3,0,0>]
#declare Spherical_Green_Pigment =
pigment
        spherical
        colour_map
                [0 rgb 0]
                [0 rgb <0,3,0>]
                [1 rgb <0,3,0>]
#declare Spherical_Blue_Pigment =
pigment
        spherical
        colour_map
                [0 rgb 0]
                [0 rgb <0,0,3>]
                [1 rgb <0,0,3>]
#declare Hemispherical_Red_Pigment =
pigment
        pigment_pattern
                planar
                translate <0,1,0>
        pigment_map
                [0 colour rgb 0]
                [0 Spherical_Red_Pigment]
                [1 Spherical_Red_Pigment]
#declare Hemispherical_Green_Pigment =
pigment
        pigment_pattern
                planar
                translate <0,1,0>
                rotate <0,0,-90>
        pigment_map
                [0 colour rgb 0]
                [0 Spherical_Green_Pigment]
                [1 Spherical_Green_Pigment]
#declare Hemispherical_Blue_Pigment =
pigment
        pigment_pattern
                planar
                translate <0,1,0>
                rotate <-90,0,0>
        pigment_map
                [0 colour rgb 0]
                [0 Spherical_Blue_Pigment]
                [1 Spherical_Blue_Pigment]
#declare Combined_Hemisphere_Pigment =
pigment
        average
        pigment_map
                [1 Hemispherical_Red_Pigment]
                [1 Hemispherical_Green_Pigment]
                [1 Hemispherical_Blue_Pigment]
sphere
        <0,0,0>
        0.999
        texture
                pigment { Combined_Hemisphere_Pigment }
                finish
                        diffuse 1
        rotate <0,30,0>
        rotate <-30,0,0>
Download '3hemis.png' (11 KB)
Preview of image '3hemis.png'
Date: 16 Mar 2001 04:24:10
Message: <3AB1DD61.C8FB5684@hotmail.com>
All these people telling me it can't be done, and then you prove that not only
can it be done, but it can be done simply.  It would be nice if I had all the
docs together instead of one for povray official, and one for megapov features,
maybe I would have noticed pigment_pattern.  Do you know if a pattern like this
can be used on media?  Why are their three entry's in all of the color maps?
>         colour_map
>                 [0 rgb 0]
>                 [0 rgb <3,0,0>]
>                 [1 rgb <3,0,0>]
I would also like to mention you are my hero.
Dan Johnson
Date: 18 Mar 2001 19:01:16
Message: <3AB54B9F.838145FA@yahoo.com.au>
pigment_pattern should work with media. <3,0,0> is nessecary because you are
averaging three pigments. Each of the colours is divided by three then added
together (or all are added together, then divided by three, depending on which way
you see it). If you had <1,0,0> in the initial colours, you would get <1/3,0,0>
finally, which does not give nice full colours. Glad to help.
MJL
> >         colour_map
> >                 [0 rgb 0]
> >                 [0 rgb <3,0,0>]
> >                 [1 rgb <3,0,0>]
> Dan Johnson
Date: 18 Mar 2001 19:18:55
Message: <3AB54FC3.C12BD717@yahoo.com.au>
As for the three entries (sorry, misread as "3" entries), these make sure that the
spherical pattern gives a pigment that is a full colour inside the sphere, and no
colour outside it.
MJL
