POV-Ray : Newsgroups : povray.binaries.images : POV Coke Can Server Time
13 Jun 2026 09:14:48 EDT (-0400)
  POV Coke Can (Message 34 to 43 of 43)
Subject: Re: Final Render Of POV Can
Date: 11 Mar 2001 23:44:51
Message: <3aac5443$1@news.povray.org>
Is this what you are after.
Dave B
Yup . . . intended having it shine down onto the floor tho . . .
Got a snippet of code for the image_map portion?
Also don't understand how the .png and alpha channel thing works
so would appreciate any hints there.
TIA
Y
Date: 12 Mar 2001 00:34:31
Message: <3aac5fe7@news.povray.org>
"yooper" <Out### [at] huntelnet> wrote in message
news:3aac5443$1@news.povray.org...
You output a PNG or TGA having a Alpha Channel by using +UA on the
command-line or Output_Alpha=On in the INI.  Needs to be at least a 24 bit
image (default).  Any transmit in the pigments will be part of that, and in
PSP you can see it by going to the Selections or Masks menu (I still have
PSP 5 but I'm guessing it's the same) and Load from Alpha Channel... once
the image file is open.
Be aware that MegaPov 0.7 seems to break the Alpha Channel; also that filter
is not converted to it, only transmit.  Value can be 0 to 1 so it can vary
in transparency but color doesn't matter.
Bob H.
Date: 12 Mar 2001 00:49:05
Message: <3aac6351@news.povray.org>
news:3aac5442$1@news.povray.org...
> You have to (I believe and could be very wrong in this) manually add the
> alpha channel to the png to get transparency.
> How????  I have PSP6 but the help files don't seem to address this . . .
I can't seem to do it in PSP 5.  Supposed to be able to make a selection
(could be All of image) and then Save to Alpha Channel but I never use it so
I don't know how to go about it.  If I try, all I get is a blank.
Bob H.
Date: 12 Mar 2001 02:02:28
Message: <3aac7484@news.povray.org>
The Gimp does this.
Bye,
Pabs
Date: 12 Mar 2001 08:13:01
Message: <3aaccb5d$1@news.povray.org>
Bob H. wrote in message <3aac6351@news.povray.org>...
so
>Bob H.
In PSP 5,6, or 7 you make a mask from the image from the image itself. You
can then save it to the alpha channel just like a selection. You'll probably
want to delete the mask afterwards, and that's ok because it'll still be in
the alpha channel. While it is still a mask though, you can choose to edit
the mask as a separate bitmap. This will let you use the various
photo-retouch tools  ( i.e. smudge, darken, lighten, etc.) to gain more
control over the transparency. When you save the image, any file format
supporting alpha channel will have it. Hope that helps.
Batronyx ^"^
bat### [at] cadronhsacom
Date: 12 Mar 2001 12:13:44
Message: <3aad03c8@news.povray.org>
thanks Bob . . .
Date: 12 Mar 2001 12:13:45
Message: <3aad03c9@news.povray.org>
You can then save it to the alpha channel just like a selection.
I be thankin' you, sir . . .
Y
Date: 13 Mar 2001 14:17:03
Message: <3aae722f$1@news.povray.org>
yooper <Out### [at] huntelnet> wrote in message
I'm not sure. I use the gimp myself.
-The "D"
    A Thunderstorm is God's way of telling you that you spend too much time
on the
computer
Email address given is a spam catcher only
Date: 13 Mar 2001 20:23:38
Message: <3aaec81a$1@news.povray.org>
You're more than welcome.
Batronyx ^"^
yooper wrote in message <3aad03c9@news.povray.org>...
>Y
Subject: Re: Correct Font Version (Ooops)
Date: 16 Mar 2001 00:03:38
Message: <3AB19E1A.F57269BE@faricy.net>
This is nice. I like how you have tinted lights that blend to white.
