POV-Ray : Newsgroups : povray.binaries.images : POV Coke Can Server Time
15 Jun 2026 08:53:35 EDT (-0400)
  POV Coke Can (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Final Render Of POV Can
Date: 11 Mar 2001 15:29:33
Message: <3aabe02d@news.povray.org>
Is this what you are after.
Dave B
"yooper" <Out### [at] huntelnet> wrote in message
news:3aabbed2$1@news.povray.org...
> If anybody has any good ideas I
> would
> > love to hear them. I just want to get my teeth stuck into something new.
> > Happy Rendering
> > Dave B
> Lookin' good . . .
> Here's an idea that I haven't had much time to explore . . .
> I want to use an image file to create a stained-glass window
> with light shining thru it and thru some media into a dark
> room . . . rays streaming thru it all.
> I started but ran into trouble getting the .png format to be
> transparent.  I think I have that figured out . . . changing it
> to 256 colors . . . but haven't had time to get back to it.
> And I know nothing about media . . .
> Also . . . I suffer from the same affliction that you have . . .
> I keep getting new ideas along the way and easily get diverted
> in other directions.  Whata ya gonna do . . . ;)
> So . . . if that's something you would like to explore . . .
> have at it and enjoy. . .
> Y
> POVaholic
Download 'stain_window.jpg' (18 KB)
Preview of image 'stain_window.jpg'
Date: 11 Mar 2001 18:06:51
Message: <3aac050b@news.povray.org>
Dave B wrote:
> I have sorted a couple of things that you brought up in earlier
> posts but I dont think I am going to do any more.
> <SNIP>
Oh yes, I like that very much, time to call it finished.
Dave B continued:
> <SNIP>
> If anybody has any good ideas I would love to hear them. I just
> <SNIP>
How about the IRTC Stills competition. Current theme is "Fortress".
Inspire any idea's ?
Duncan Gray
(warning: may contain traces of nut)
Date: 11 Mar 2001 23:44:50
Message: <3aac5442$1@news.povray.org>
You have to (I believe and could be very wrong in this) manually add the
alpha channel to the png to get transparency.
How????  I have PSP6 but the help files don't seem to address this . . .
Y
Date: 11 Mar 2001 23:44:51
Message: <3aac5443$1@news.povray.org>
Dave B
Yup . . . intended having it shine down onto the floor tho . . .
Got a snippet of code for the image_map portion?
Also don't understand how the .png and alpha channel thing works
so would appreciate any hints there.
TIA
Y
Date: 12 Mar 2001 00:34:31
Message: <3aac5fe7@news.povray.org>
news:3aac5443$1@news.povray.org...
You output a PNG or TGA having a Alpha Channel by using +UA on the
command-line or Output_Alpha=On in the INI.  Needs to be at least a 24 bit
image (default).  Any transmit in the pigments will be part of that, and in
PSP you can see it by going to the Selections or Masks menu (I still have
PSP 5 but I'm guessing it's the same) and Load from Alpha Channel... once
the image file is open.
Be aware that MegaPov 0.7 seems to break the Alpha Channel; also that filter
is not converted to it, only transmit.  Value can be 0 to 1 so it can vary
in transparency but color doesn't matter.
Bob H.
Date: 12 Mar 2001 00:49:05
Message: <3aac6351@news.povray.org>
news:3aac5442$1@news.povray.org...
I can't seem to do it in PSP 5.  Supposed to be able to make a selection
(could be All of image) and then Save to Alpha Channel but I never use it so
I don't know how to go about it.  If I try, all I get is a blank.
Bob H.
Date: 12 Mar 2001 02:02:28
Message: <3aac7484@news.povray.org>
The Gimp does this.
Bye,
Pabs
Date: 12 Mar 2001 08:13:01
Message: <3aaccb5d$1@news.povray.org>
Bob H. wrote in message <3aac6351@news.povray.org>...
so
>Bob H.
In PSP 5,6, or 7 you make a mask from the image from the image itself. You
can then save it to the alpha channel just like a selection. You'll probably
want to delete the mask afterwards, and that's ok because it'll still be in
the alpha channel. While it is still a mask though, you can choose to edit
the mask as a separate bitmap. This will let you use the various
photo-retouch tools  ( i.e. smudge, darken, lighten, etc.) to gain more
control over the transparency. When you save the image, any file format
supporting alpha channel will have it. Hope that helps.
Batronyx ^"^
bat### [at] cadronhsacom
Date: 12 Mar 2001 12:13:44
Message: <3aad03c8@news.povray.org>
thanks Bob . . .
Date: 12 Mar 2001 12:13:45
Message: <3aad03c9@news.povray.org>
You can then save it to the alpha channel just like a selection.
I be thankin' you, sir . . .
Y
