POV-Ray : Newsgroups : povray.binaries.images : WIP: Door into Summer Server Time
30 Jun 2026 07:35:12 EDT (-0400)
  WIP: Door into Summer (Message 29 to 38 of 38)
Subject: Re: WIP: Door into Summer
Date: 22 Feb 2001 14:41:48
Message: <3a956b79@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
> In article <3a955c4d@news.povray.org>, Geoff Wedig
> <wed### [at] darwinepbicwruedu> wrote:
>> Is the projected_through available now?
> It's been around since the Superpatch days, I think.
>> Last I heard, portals only did a pigment, no light through the portal
>> or photons or such.  Has it progressed, then?
> No, the projected_through feature has nothing to do with the portal
> patch, it is a light_source feature that allows you to "project" light
> through an object, making light shine through the object.
Ok, now I'm confused.  Does that mean light only exists after the object,
that the light rays don't exist in the space between light and object, but
come from the object?
>> One disadvantage that I noticed last night is that I can't use focal
>> blur (post process), because only the summer side gets blurred.  The
>> winter side is all at the mirror distance, rather than its 'true'
>> distance, so doesn't get appropriately blurred.  On the other hand, a
>> portal would have the opposite problem, with only the winter side
>> blurring.
> The ordinary focal blur should work fine, though...it would just make
> your scene even slower.
Yeah, and I've found that the sampling menthods don't give good results,
IMO.  But maybe for a final render with *lots* of samples...
Geoff
Date: 22 Feb 2001 15:58:27
Message: <chrishuff-28CF21.15573322022001@news.povray.org>
In article <3a956b79@news.povray.org>, Geoff Wedig
Exactly. All areas that would be in the shadow of the projected_through
object are illuminated. You would just use a copy of the portal object
as the projected_through object, and transform copies of the necessary
light_sources to appear through the portal object as if they were on the
other end.
You can almost eliminate the grainyness if you use the right settings,
but it is slow...
Christopher James Huff
Date: 23 Feb 2001 12:02:58
Message: <3a9697c2@news.povray.org>
> other end.
So with a portal object and the pass through, I could get such a light, but
that would only cast one way, and I'm not sure about the effects on
radiosity.
Anyway, when's the patch going to be available? ;)
> but it is slow...
Really slow.
Geoff
Date: 23 Feb 2001 13:24:19
Message: <chrishuff-718A8F.13232523022001@news.povray.org>
In article <3a9697c2@news.povray.org>, Geoff Wedig
> light, but that would only cast one way, and I'm not sure about the
> effects on radiosity.
Portal objects are all one-way...to get a 2-way effect you would need 2
portal objects, one for each end, and more copies of light sources with
pass_through set up for the second portal.
Two Weeks, or Real Soon Now. ;-)
I really don't know, I'm working on MegaPOVPlus 0.7 mod 0.1 now, and
I've got the particle stuff and some other patches integrated, but have
yet to even start the portal pigment stuff. It requires some new
information to be passed through a lot of functions, so it will be a bit
tedious to add...and there is a lot of other stuff which I might do.
Date: 23 Feb 2001 13:33:25
Message: <3a96acf2@news.povray.org>
I can wait.  My system doesn't require certain kinds of grotty math that I
would be happy to avoid, and I've managed to cut the time down
significantly, as well, so maybe no big deal.
Geoff
Date: 27 Feb 2001 13:07:03
Message: <3a9becc7@news.povray.org>
Maybe I'm missing something.  I did a search on the Pov docs and didn't find
any reference for pass_through.  I looked at the Megapov docs and only found
it for photons.  Can you do a pass through with normal light_sources?  If
so, I think I might have figured a way to make this image much easier, and
faster.
Geoff
Date: 27 Feb 2001 13:30:25
Message: <3a9bf241@news.povray.org>
Geoff Wedig <wed### [at] darwinepbicwruedu> wrote in message
news:3a9becc7@news.povray.org...
find
found
> faster.
From the megapov docs:
6.5. Projected through
Author: Ronald L. Parker
syntax:
light_source {
  projected_through {object {...}}
The light rays that pass through the projected_through object will be the
only light rays that contribute to the scene. Any objects between the light
and the projected through object will not cast shadows for this light. Also
any surface within the projected through object will not cast shadows. Any
textures or interiors on the object will be stripped and the object will not
show up in the scene. This is if the ambient value in the finish {} is set
to 0.
HTH
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 27 Feb 2001 13:40:53
Message: <3a9bf4b5@news.povray.org>
> find
> found
>> faster.
> syntax:
> light_source {
> to 0.
Ah.  Thanks.  I was looking for pass_through, per Chris's post, which is
photons.  I wonder if this should be made consistent... Not entirely sure
they do the same thing, though.
Geoff
Date: 27 Feb 2001 16:22:01
Message: <chrishuff-5C9527.16205027022001@news.povray.org>
In article <3a9bf4b5@news.povray.org>, Geoff Wedig
I meant projected_through. And they don't do the same thing,
pass_through behaves more like shadowless (or maybe I mean no_shadow?
Those two *do* need to be made more consistent...), while
projected_through does a fancy spot light.
Date: 27 Feb 2001 16:29:55
Message: <3a9c1c53@news.povray.org>
Yeah, that's kinda what I thought.  Now I just have to experiment to see if
my fancy method will work or not.
Geoff
