POV-Ray : Newsgroups : povray.binaries.images : WIP: Door into Summer Server Time
30 Jun 2026 08:57:00 EDT (-0400)
  WIP: Door into Summer (Message 19 to 28 of 38)
Subject: Re: Door into Summer
Date: 21 Feb 2001 09:18:50
Message: <3a93ce49@news.povray.org>
Nekar Xenos <vir### [at] iconcoza> wrote:
>> I would like the fog to be on the winter side, but not the summer.  The
>> summer side should be almost preternaturally clear, IMO.  I'm considering
>> focal blur plus some 'hiding' of the horizon: trees or hills or something
>> off in the distance.
> You're right - fog in summer !?!
> I think the sky is too dark as well. Add a bit more green to it and let the
> sky fade to an even lighter blue toward the horizon.
It currently fades to a darker blue towards the horizon, but I must admit, I
couldn't remember which way it went. It should also be brighter 'sunwards',
but I'm not certain how to accomplish that.
Geoff
Date: 21 Feb 2001 11:15:31
Message: <3a93e9a3@news.povray.org>
Hi Goeff!
> (the clouds on a skysphere don't flatten
> towards the horizon, so it looked really fake)
You can flatten them by attaching a scale like <1,.2,1> to the
sky_sphere's pigment.
But you shouldn't look upwards then. There are strange circles of
clouds above you...
Just an idea
Nice picture, btw. And I can't imagine how you did it - not using the
portal_pigment.
cukk
Date: 21 Feb 2001 12:15:44
Message: <3a93f7c0@news.povray.org>
KalleK <kal### [at] gmxde> wrote:
> Hi Goeff!
> clouds above you...
> Just an idea
> portal_pigment.
Nope, though the pp discussion made me want to post this, since people were
wondering what sorts of things it could be good for.  It does
require Megapov.
Geoff
Subject: Re: WIP: Door into Summer
Date: 21 Feb 2001 15:24:08
Message: <3A9423E1.8A1C80CE@netscape.net>
Excellent!  Summer is a bit dark.  On the other hand, a bright summer day
probably isn't as bright as a bright winter day with the snow reflections.  How
did you do the brick wall/arch?
Cris Williams
Geoff Wedig wrote:
> Well, I just saw the thread on Chris Huff's portal patch, so I thought I'd
> post this.  This is one type of image that would be much easier to do with
> such a patch, I'd imagine (though the patch doesn't allow light to pass
> through)  It would certainly be faster than my method.
> Speaking of which, my method isn't a camera trick.  I can place the camera
> wherever I like and the scene doesn't go funky, up to and including the other
> side of the doorway.
> So what do folks think so far?  I'd like to increase the realism if possible,
> because, somewhat counterintuitively, the more real I can get this, the less
> real it'll seem.
> Geoff
Date: 22 Feb 2001 06:50:55
Message: <3a94fd1f@news.povray.org>
Actually it should get lighter toward the horizon. Lightness toward the sun
would be more of a 'cone' or lens-flare effect. The air and dust particles
in the air does actually give a slight 'fog' effect. That's why mountains
seem bluish in the distance.
Nekar
I
'sunwards',
> Geoff
Date: 22 Feb 2001 07:40:07
Message: <3a9508a6@news.povray.org>
Yeah, it's difficult to make the summer seem brighter, since the winter is
mostly white and light grey, so I settled for making it a lot more colorful.
The wall is from code that I designed called the ISW (Iso-stone Wall).
Originally, it started out as a port of the mur.inc to iso-surfaces, but I
found that mur.inc wasn't adequate for what I wanted to do.  So I rewrote it
from the ground up.  I built a lot more logic into the laying of stones, and
included a bunch of macros to allow me to make things like towers and tubes,
each with variable radius.  These are done by permutation functions to the
isosurface function.  I want to add a spherical and disc like as well, but
that's not done yet.  The arch is just a very short (one block long) half tube.
Incidentally, it's not just for stone.  I've made some really nice hardwood
floors with it and the isowood.inc just by re-defining a bunch of macros.
At some point, I need to write up a quick doc for it and then I'll release
it.  The code is pretty clean, but it's tricky to see what needs doing to
get the right effect without some guidance.
Geoff
Date: 22 Feb 2001 10:04:42
Message: <3a952a8a@news.povray.org>
Geoff
Great . . .
  Those stones are what draw me to this pic . . .
   Looking forward (my fav direction ;) to taking a look at it.
Thanks,
Y
Date: 22 Feb 2001 12:59:16
Message: <chrishuff-47E03C.12582122022001@news.povray.org>
> thought I'd post this.  This is one type of image that would be much
> easier to do with such a patch, I'd imagine (though the patch doesn't
> allow light to pass through)
Actually, it would be possible to simulate the effect of light shining
through the portal...just create another copy of the lights you want to
shine through the portal, transform them to where they would be on the
"other side" when seen through the portal, and use the projected_through
feature to make them shine through the portal.
This wouldn't be perfect...a shadow on the other side of the portal
wouldn't pass through it. It would work in most situations, though.
What was your method?
Christopher James Huff
Date: 22 Feb 2001 13:37:02
Message: <3a955c4d@news.povray.org>
Is the projected_through available now?  Last I heard, portals only did a
pigment, no light through the portal or photons or such.  Has it progressed,
then?
I was waiting for someone to ask. ;).  I created both scenes, then cut them
in half.  One half is set no_image and scaled <1,-1,1> (I use z as up.  More
intuitive for me) while the other is no_reflection.  Then I set up a perfect
mirror with a hole in it at the right place, and use light groups to get the
reflections lights to work right.
Only problem is that this makes essentially the entire picture one big
intersection.  Bounding goes out the window, and with all those isosurface
stone blocks, it slows to a crawl.  I've gotten away with a few things (the
tree, for instance doesn't pass the invisible wall so doesn't need to be
intersected), but for the most part, things get slow really quickly.
The advantage of doing all this is being able to set the camera up wherever
is convenient, and getting easy light pass through.  One disadvantage that I
noticed last night is that I can't use focal blur (post process), because
only the summer side gets blurred.  The winter side is all at the mirror
distance, rather than its 'true' distance, so doesn't get appropriately
blurred.  On the other hand, a portal would have the opposite problem, with
only the winter side blurring.
Geoff
Date: 22 Feb 2001 14:28:29
Message: <chrishuff-54D1B6.14273322022001@news.povray.org>
In article <3a955c4d@news.povray.org>, Geoff Wedig
It's been around since the Superpatch days, I think.
> Last I heard, portals only did a pigment, no light through the portal
> or photons or such.  Has it progressed, then?
No, the projected_through feature has nothing to do with the portal
patch, it is a light_source feature that allows you to "project" light
through an object, making light shine through the object.
> One disadvantage that I noticed last night is that I can't use focal
> blur (post process), because only the summer side gets blurred.  The
> winter side is all at the mirror distance, rather than its 'true'
> distance, so doesn't get appropriately blurred.  On the other hand, a
> portal would have the opposite problem, with only the winter side
> blurring.
The ordinary focal blur should work fine, though...it would just make
your scene even slower.
