POV-Ray : Newsgroups : povray.binaries.images : insect shader (50ko bu) Server Time
13 Jun 2026 15:23:46 EDT (-0400)
  insect shader (50ko bu) (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: insect shader (50ko bu)
Date: 15 Jan 2001 05:57:59
Message: <3a62d7b7@news.povray.org>
> yesterday, I started a POVMan shader to do an insect "shell" (not sure
> of the word).
> here is the first result.
> it needs more work to find the right colours and to make the surface
> finish more realistic.
All I saw was a solid black sphere - had to open it up and play with the
gamma to see anything :)
would it not be possible to achieve this effect in povray using the pillow
normal?
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 15 Jan 2001 06:08:15
Message: <3A62DA88.A5E3BDD5@xlstudio.com>
yes, it's dark but on my computer, it is good...
> normal?
I don't know "pillow normal"
          David
Date: 15 Jan 2001 09:10:54
Message: <3a6304ee@news.povray.org>
pillow
> > normal?
i ment quilted :)
#declare Material1 =
   material  // Material1
      texture
         pigment
            quilted
            control0 0.2
            control1 0.2
            color_map
               [ 0.0     rgbft <0.583333, 1.0, 0.583333, 0.0, 0.0> ]
               [ 0.5     rgbft <0.291667, 0.739567, 1.0, 0.0, 0.0> ]
               [ 1.0     rgbft <0.0, 0.0, 1.0, 0.0, 0.0> ]
            scale  0.2
         normal
            quilted , 0.548
            control0 0.2
            control1 0.2
            scale  0.2
         finish
            ambient 0.172633
            diffuse 0.2158
            brilliance 1.729
            phong 1.0
            phong_size 17.216667
            specular 0.3453
            roughness 0.060133
            metallic 1.0
PGP Public Key
Download 'untitled.jpg' (13 KB)
Preview of image 'untitled.jpg'
Date: 15 Jan 2001 09:31:49
Message: <3A630A3C.C24FC647@xlstudio.com>
> i ment quilted :)
ok !
but, the effect I want is a surface wich color changes with the incident
light !!
in my picture (I know, it's only a picture, an animation is in progress...)
the green tint is dependant of the light source direction.
as I said, I have to work on it to get the right colours and finish but,
the "spirit" is here !
      David
Date: 15 Jan 2001 11:01:59
Message: <chrishuff-E18E98.11032015012001@news.povray.org>
In article <3A62BC0D.C65F3E08@xlstudio.com>, gemelli david
> of the word).
"Exoskeleton", but people will look at you funny if you use words like
that too much... ;-)
> 2 questions:
> - I'm not sure of my shader version of the "metallic" keyword... I
> multiplied the specular by the surface colour...Am I right ?
That seems to be an approximation...looking at the source code, POV
seems to use some kind of Fresnel function for textures using
"metallic". This is for both phong and specular...and apparently phong
and specular are the only things affected by metallic, and the
calculations do use the surface color, though it is more complex than a
simple multiplication.
> - I'm using little spheres to do the big sphere. When I increase the
> radius of the spheres, the rendering time increase a lot ! Is it normal
When the spheres overlap more, POV has to solve for more spheres to get
the one that is in front of the others. If you have 4 spheres
overlapping in an area, all 4 will have to be computed to render that
area. When you increase the radius of the small spheres, you increase
the average number of spheres per pixel, and POV has to do more work to
render the image.
Christopher James Huff
Date: 15 Jan 2001 11:17:45
Message: <3A63230F.EDB180D@xlstudio.com>
yes, right !
ok, I'll play with it just to get the effect I want, if it is too
> render the image.
ok, thanks for this precision !
         David
Date: 15 Jan 2001 13:23:15
Message: <3a634013@news.povray.org>
"gemelli david" <d.g### [at] xlstudiocom> wrote in message
news:3A62BC0D.C65F3E08@xlstudio.com...
> of the word).
Carapace?
Andy Cocker
listen to my music at:
www.mp3.com/lunarland
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
 - Steven Wright.
Date: 15 Jan 2001 14:57:53
Message: <MPG.14cd63273a94a708989869@news.povray.org>
> > of the word).
Or possibly Carapace.
I assume you're aiming for something like the wing cases off an
iridescent beetle?  If so, good luck, and I hope you get the results
you're after, because I've never really managed to get a good
approximation using the iridescence feature of POV 3.1.
Bye for now,
     Jamie.
Date: 15 Jan 2001 16:29:26
Message: <chrishuff-D41868.16304615012001@news.povray.org>
In article <MPG.14cd63273a94a708989869@news.povray.org>,
Carapace is another word for it, but I've mostly seen it used to refer
to creatures like crabs or lobsters. I'm not an entomologist, though...
Date: 16 Jan 2001 15:54:02
Message: <MPG.14cec062c79e7a4c98986c@news.povray.org>
To be specific, the carapace is 'the shieldlike exoskeletal plate that
covers at least part of the anterior dorsal surface of many arthropods.'
Do you think using words like that will get people looking at me funny?
<grin>
I suggested it because the iridescent effect he seems to be aiming for is
usually most visible on the abdomens of beetles, some cockroaches, etc.
(i.e. the anterior dorsal surface :)
Ths ends the invertebrate biology lesson for the day <grin>
Bye for now,
     Jamie.
