POV-Ray : Newsgroups : povray.binaries.images : The Temple again Server Time
28 Dec 2025 06:20:30 EST (-0500)
  The Temple again (Message 1 to 5 of 5)
Subject: The Temple again
Date: 21 Dec 2000 17:01:12
Message: <3A427EFE.EF38A2EC@rapidnet.com>
 Still needs some detail work, but I did tweak the lighting a bit.
Added a soft light in front of each pillar and added some media.
re-rendered with radiosity and AA . I tried to use an athmospheric
media, but it whited out the scene, I don't know what it is, I must be
doing something wrong, or missing a step. I'll play around with it some
more, I still need to add torches and holders to go with the flames.
 banty
Download 'temple2.jpg' (126 KB)
Preview of image 'temple2.jpg'
Subject: Re: The Temple again
Date: 21 Dec 2000 18:29:49
Message: <3A42917E.35CF0F29@faricy.net>
Are you using fade_power and fade_distance? If not, they can help greatly in
scenes lit like this because real lighting of this sort doesn't go a long way.
Date: 21 Dec 2000 22:23:35
Message: <3A42CADA.B1EADAF6@rapidnet.com>
Yes, I did, fade_distance 5, fade_power 0.25, the light_source intensity is only
0.1875, but it does look better anyway.
> David Fontaine <dav### [at] faricynet> ICQ 55354965
> My raytracing gallery: http://davidf.faricy.net/
Date: 21 Dec 2000 23:06:45
Message: <3A42D261.2A7C5A3C@faricy.net>
Umm... fade power 0.25? I'm not sure what that does, but fade power is normally >=1.
2 is the physically accurate number.
Date: 22 Dec 2000 00:22:44
Message: <3A42E524.1E16DCF7@ij.net>
	Were I commenting on the "jade" texture, the sections are about what
one might find in a 4x1 inch slab of jade. The rest is similarly course.
The handwriting on the wall the wall
may be a forgery.
	-- The Iron Webmaster, 212
