POV-Ray : Newsgroups : povray.binaries.images : Certainly NOT an iso-image (62KB) Server Time: 19 Feb 2019 23:22:27 GMT
  Certainly NOT an iso-image (62KB) (Message 1 to 10 of 10)
Subject: Certainly NOT an iso-image (62KB)
Date: 16 Dec 2000 04:04:49
Message: <3A3AE912.8DDE13B@online.no>
I just browsed through my older renderings
and found this one that I did one year ago.
Seeing this image reminds me of those days
when I could render an image and actually
WATCH while the image was being rendered.
So now I'm very tempted to leave the isos
for a while and do some CSG-images.
They used to render faster than 1 pps !
When I made this image I had just finished
an attempt to make a 3D model of a nearby
company's logo. And then I wanted to see
how it looked if I laid it down on it's
side and spread several copies of it
around in a circle. I liked it.
What do you think of this image?
One thing bugs me though: The fact that
now I'm sitting here wondering if this
image could have been done with a couple
of iso-surfaces (@ 1E-6 pps on my P100 :)
Hmmm... Maybe I'm a little bit mad...
Tor Olav
mailto:tor### [at] hotmailcom
Download 'oddmunck02_.jpg' (63 KB)
Preview of image 'oddmunck02_.jpg'
Subject: Re: Certainly NOT an iso-image (62KB)
Date: 16 Dec 2000 08:20:19
Message: <3A3B25C3.8CE15EA0@gmx.de>
I know that feeling, everything above one hour per line can be *really*
boring.  For example if you come back after half an hour, look at the
screen and recognize from the picture, that it's still working on the same
line.  In addition if you use radiosity you cannot interrupt and later
continue the render that easily.
IMO it should be possible to do it with *one* isosurface although it would
really be a long function.  But if it parses at all, i doubt it would
render that slow.
Date: 16 Dec 2000 17:48:17
Message: <chrishuff-E9245F.12491816122000@news.povray.org>
In article <3A3B25C3.8CE15EA0@gmx.de>, Christoph Hormann
If you use MegaPOV(which you must be, since you are using isosurfaces),
that is no longer true. You can tell it to save the radiosity info to a
file and load that when you continue.
Christopher James Huff
Personal: chrishuff@mac.com, http://homepage.mac.com/chrishuff/
Date: 16 Dec 2000 18:47:26
Message: <3A3BB8C0.1D390C1A@gmx.de>
I know, but it does not work perfectly.  If i use '+c' and 'load_file' in
the radiosity block, i often get artefacts.
Date: 17 Dec 2000 00:36:49
Message: <3A3C09D6.8998B696@online.no>
I haven't dared to try radiosity yet.
I'm afraid that I will get addicted to that too,
and then I'll become even more frustrated because
of my slow PC.    :(
But wouldn't one be needed for each texture ?
(I.e. 2 for this image)
Or is there some smart way to control the
texture "directly" within the iso-surface ?
> render that slow.
But it would FEEL that slow !  :)
Btw.: Wouldn't it be a good idea to have POV
changing from pps to spp (seconds per pixel)
when the rendering drops below 1 pps ?
Thanks for commenting.
Best regards,
Tor Olav
Date: 17 Dec 2000 04:34:08
Message: <3A3C416C.AA85DB9@faricy.net>
Guess we need freeze files. They'd only be a few hundred megs...
Date: 17 Dec 2000 05:07:35
Message: <3A3C4B0E.58E52CF7@pacbell.net>
On my old system there were times I thought it was more like ppm(onth) !
Date: 17 Dec 2000 05:43:40
Message: <3a3c528c$1@news.povray.org>
    Seriously.
    I don't know how many times I have sat around timing the refresh of
lines so that I could calculate seconds per pixel and from that estimate the
remaining time needed for a render (and decide if I wanted to continue).
    ps. What was that logo before the rotation? Looks like a 'B' and an
arrow, but what was it for?
Date: 18 Dec 2000 01:03:45
Message: <3A3D619F.5962EB34@online.no>
>     Seriously.
Me too. I would like to have a option in POV to
have it do this estimation for me.
It's actually an "m" with an arrow sticking up from
its middle. Their name is Munck Cranes (and their main
product is overhead cranes).
You can see a small version of the logo here:
http://www.munckcranes.com/
Best regards,
Tor Olav
Date: 18 Dec 2000 01:08:47
Message: <3A3D62D1.37E18D13@online.no>
Yes that would probably be a proper measure
for the rendering of some of the iso images
I'm fantasizing about :)
1 ppm would equal about 4E-7 pps ...
Tor Olav
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
