POV-Ray : Newsgroups : povray.binaries.images : Comments and suggestions requested Server Time
13 Jun 2026 14:33:50 EDT (-0400)
  Comments and suggestions requested (Message 1 to 9 of 9)
Subject: Comments and suggestions requested
Date: 11 Dec 2000 04:20:46
Message: <3A349B9D.E28CAF69@optusnet.com.au>
...also can I get some ideas for a realistic sandstone texture to apply
to the bricks
Leitha
[Image]
Download 'us-ascii' (1 KB) Download 'd:\temp\nsmail5p.jpeg.jpg' (18 KB)
Preview of image 'd:\temp\nsmail5p.jpeg.jpg'
Subject: Re: Comments and suggestions requested
Date: 11 Dec 2000 05:10:47
Message: <3a34a827@news.povray.org>
"Leitha & Mark Hyde" <mal### [at] optusnetcomau> wrote in message
news:3A349B9D.E28CAF69@optusnet.com.au...
> to the bricks
I'm seeing coincident surfaces in the window, and doorway too, I believe.
Better scale those cutout boxes slightly upward in the facing direction,
translate slightly too if a side is on a zero plane.
Sandstone could be done by using a very small scale granite normal but it
wouldn't show up on a unlit side.  So a texture layer of granite pigment and
normal both over the one you have now would be better.  Just use a small enough
scale.
There's probably a sandstone in the stones.inc file already but not everything
is labeled enough I think.
Bob H.
I added a sandstone into that file (just looked) but since I changed much of
the naming scheme I'll just put a stand-alone one here for an example:
sphere {0,3
texture {pigment {rgb <1.2,.9,.4>}
 finish {diffuse .9 specular .1 roughness .1}
pigment
 {granite
  turbulence 0.4
  color_map
   {[0.0, 0.1   color rgbf <0.8, 0.5, 0.4, 0.0>
                color rgbf <0.8, 0.6, 0.5, 0.6>]
    [0.1, 0.3   color rgbf <0.8, 0.6, 0.5, 0.5>
                color rgbf <0.9, 0.5, 0.35, 0.3>]
    [0.3, 0.5   color rgbf <0.9, 0.5, 0.35, 0.1>
                color rgbf <0.85, 0.7, 0.4, 0.0>]
    [0.5, 0.7   color rgbf <0.85, 0.7, 0.4, 0.0>
                color rgbf <0.8, 0.75, 0.5, 0.2>]
    [0.7, 1.0   color rgbf <0.8, 0.75, 0.5, 0.3>
                color rgbf <0.8, 0.5, 0.4, 0.0>]
 normal {granite .5 turbulence 0.4}
 finish {diffuse .7 specular .1 roughness .1 crand 0.1} // use zero if
animating
  scale .8
Date: 11 Dec 2000 10:01:17
Message: <3A34EC30.48FBFD8D@gmx.de>
> to the bricks
In addition to what Bob suggested i would also add a brick normal to
emphasize the structure of the walls.  You could also build the walls from
single stones, but it would be slower and more difficult.
I wonder about the green lines at the top of the walls.  They seem to be
slightly sloped but i can't imagine why.
Date: 11 Dec 2000 14:52:01
Message: <3A353061.AA65D3F5@ij.net>
> apply to the bricks
	Sandstone comes in many types. Be certain to have a picture of the kind
you want while working.
If Palestinian attacks are child sacrifice they
are sacrifices to the Israeli Gods.
	-- The Iron Webmaster, 313
Date: 11 Dec 2000 15:41:01
Message: <slrn93aetf.gql.steve@zero-pps.localdomain>
>to the bricks
It all looks very sharp and angular, you really need some soft edges in
there or even area lights to soften it up a bit.
  8:11pm  up 61 days, 22:36,  3 users,  load average: 1.13, 1.04, 1.01
Date: 11 Dec 2000 20:32:03
Message: <3A357F46.465329C@optusnet.com.au>
The green lines are part of a sloped roof (the buillding is moddeled on a real
building which is used as a church)
Leitha
Date: 11 Dec 2000 20:34:20
Message: <3A357FD1.C2192066@optusnet.com.au>
It already has 2 (2x2 arrays)
Leitha
Date: 12 Dec 2000 02:31:59
Message: <3A35D467.90F4D58A@gmx.de>
But then something went wrong with the left part.
Date: 12 Dec 2000 18:02:28
Message: <3A36ADB7.1B7B78C1@optusnet.com.au>
It's something that is causing problems in trying to get the rotation exactly right
btw sorry about the spelling mistake in my previous post.
Leitha
