POV-Ray : Newsgroups : povray.binaries.images : Bamboo test 1. Server Time
20 Sep 2025 12:10:02 EDT (-0400)
  Bamboo test 1. (Message 1 to 10 of 14)
Subject: Bamboo test 1.
Date: 10 Dec 2000 06:13:30
Message: <3A336525.B8598F42@worldonline.nl>
Here's my fiirst bamboo-texture test. Any comments/suggestions?
Rob.
Download 'bambootest_01.jpg' (13 KB)
Preview of image 'bambootest_01.jpg'
Subject: Re: Bamboo test 1.
Date: 10 Dec 2000 08:38:21
Message: <3a33874d@news.povray.org>
Rings?
Rob Verweij wrote:
> Rob.
Date: 10 Dec 2000 13:01:46
Message: <slrn936tvh.dlf.steve@zero-pps.localdomain>
That looks great, now all you need is a bamboo shape to go
with it.  You might find some good bamboo objects in one of
the scene files groups, thir textures are never any good but
the sapes are.
It'd be good if you could put your texture in a macro that
recognises the length of an object so that it scales correctly
for bamboo poles of different lengths.
The only reservation I'd have about using such a texture is
that at a distance you probably won't see any of that intricate
detail, but you'd suffer the render time that'd go with it.
Keep us posted.
 12:01pm  up 60 days, 14:25,  3 users,  load average: 1.18, 1.16, 1.06
Date: 10 Dec 2000 13:40:35
Message: <slrn937j9a.e5v.steve@zero-pps.localdomain>
On Sun, 10 Dec 2000 08:37:54 -0500, Greg M. Johnson wrote:
>Rings?
Content-Type: text/plain; charset=x-user-defined
Why?
  6:26pm  up 60 days, 20:51,  3 users,  load average: 1.00, 1.03, 1.16
Date: 10 Dec 2000 13:45:34
Message: <3A33CF1C.86C582BC@worldonline.nl>
Well this particular Bamboo will be in a close-up shot so i need the
detail.
Rob.
> ...The only reservation I'd have about using such a texture is
> Keep us posted.
> Cheers
> Steve
Date: 10 Dec 2000 13:47:32
Message: <3A33CF91.5BD0CCE0@worldonline.nl>
What do you mean? I don't have a "live specimen" of bamboo lying arround
so I did this from memory and as far as I now bamboo has no rings.
Rob.
"Greg M. Johnson" schreef:
> Rings?
> Rob Verweij wrote:
> > Hi,  Here's my fiirst bamboo-texture test. Any comments/suggestions?
> > Rob.
Date: 10 Dec 2000 14:11:32
Message: <chrishuff-64CFC5.14122410122000@news.povray.org>
In article <3A33CF91.5BD0CCE0@worldonline.nl>, Rob Verweij
I think he means the segments...
In case you don't know what *I* am talking about, bamboo is composed of
many segments joined end to end. Your image appears to be a single
segment of bamboo. The joints between segments make visible rings, which
are nothing like the rings in wood.
Christopher James Huff
Date: 11 Dec 2000 01:32:12
Message: <3A3474B9.1A25890E@worldonline.nl>
Yes, I figured he meant that but I couldn't find the right word for it:
segments (duh!) thanks for helping me out.
I have some difficulties on deciding what the best way of "modeling" is for
the segments. Texturing them is easy but "modeling" them isn't (well at least
for me it isn't). I thought I could do it by using a gradient bump map but
that doesn't look realistic. Well back to the drawingboard to figure out a way
to do the segments.
Thanx,
Rob.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 11 Dec 2000 03:58:00
Message: <3a349718@news.povray.org>
One way would be to make them using lathe objects. Or if you are
mathematically inclined you could use isosurfaces.
"Rob Verweij" <rg.### [at] worldonlinenl> wrote in message
news:3A3474B9.1A25890E@worldonline.nl...
for
least
way
> to do the segments.
> Thanx,
> Rob.
arround
Date: 11 Dec 2000 04:02:09
Message: <3a349811$1@news.povray.org>
way
> to do the segments.
After seeing this thread on bamboo I thought I'd try it using some made-up
function in a isosurface.
I got as far as an undulating shape but nothing like actual bamboo so I moved
on to a simple CSG of cylinders and tori and that was better.  Then came the
while loop scaling and translating, no good yet.  And even if I ever get it
about right it would never have the imperfections of real bamboo as I was
hoping for by doing a isosurface of it.
I went so far as to try searching out a equation of such a shape... without any
luck of course.
Bob H.
