POV-Ray : Newsgroups : povray.binaries.images : Drying fisher net Server Time
30 Mar 2026 11:41:26 EDT (-0400)
  Drying fisher net (Message 1 to 10 of 18)
Subject: Drying fisher net
Date: 14 Nov 2000 04:47:02
Message: <3A110A14.E388E108@tapasmail.net>
Another example of my cloth simulator...
	Two notes:
* it's probably still a bit stiff but to get something better, I'd have
to increase the resolution with the corresponding increase in time :-(
* the simulator doesn't stop when nothing moves, but rather after a
certain number of simulation steps. I think in this case it hadn't
finished which is why the net seems to hang in mid-air on the right...
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Download 'net.jpg' (28 KB)
Preview of image 'net.jpg'
Subject: Re: Drying fisher net
Date: 14 Nov 2000 05:25:06
Message: <3a111302@news.povray.org>
That is very impressive, what are you doing the simulating with??
Kitty5 WebDesign - http://www.kitty5.com
TEL - +44 (01625) 266358 : FAX +44 (01625) 611913
PGP Public Key
Date: 14 Nov 2000 05:31:17
Message: <3A111473.C81D41EB@schunter.etc.tu-bs.de>
>         Two notes:
That looks neat, still a mesh ?
You seem to be right about the unfinished calculation on the right side,
although it's also a difficult case in real world.  If i understand things
right it's probably not that problematic to add some kind of 'unfinished
warning' to the program.
If it's an external program, i wonder what kind of shapes it can handle
for draping the cloth onto.
Date: 14 Nov 2000 05:47:14
Message: <3A111832.CFFB781@tapasmail.net>
	I wrote a C++ program to do the simulation
Date: 14 Nov 2000 05:52:51
Message: <3A111982.3913BC15@tapasmail.net>
	Still a mesh, with a combination of two gradients as a pigment to give
the illusion of a net
	Right, I'll probably do this
	Right now, it can handle any number of cylinders in any position, any
number of boxes whose sides are parallel to the axis and an horizontal
plane at any given altitude. It's not very difficult to add new shapes,
but those are all I need for the moment...
Date: 14 Nov 2000 06:08:29
Message: <3A111D2E.8566C17F@schunter.etc.tu-bs.de>
A 'heightfield' would probably be useful, one could generate it from any
complicated shape with povray and it would work in nearly all cases.
Date: 14 Nov 2000 06:41:35
Message: <3A112510.9DB97405@skynet.be>
An idea : using the "trace" function to "scan" the geometry below the
cloth piece, and use the resulting height data into your utility...
Fabien.
Date: 14 Nov 2000 06:49:09
Message: <chrishuff-CE34BA.06492114112000@news.povray.org>
In article <3A112510.9DB97405@skynet.be>, Fabien Mosen
Or just render an image from above the scene and use the depth
post_process...
Christopher James Huff
Date: 14 Nov 2000 08:35:18
Message: <3A113F96.5C5D5B96@schunter.etc.tu-bs.de>
> post_process...
Or a gradient pigment with black/white color_map and
finish { ambient 1 diffuse 0 ) combined with an orthographic camera.
Date: 14 Nov 2000 08:44:02
Message: <3a1141a2@news.povray.org>
Pretty. From what you're saying about increasing resolution, it sounds like
you're not using the Provot method, but rather the Elias method... The
latter is slower and the first doesn't need increases in resolution to lower
stiffness. You merely change a variable or two.
