POV-Ray : Newsgroups : povray.binaries.images : Drying fisher net Server Time
14 Jun 2026 00:15:36 EDT (-0400)
  Drying fisher net (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Drying fisher net
Date: 14 Nov 2000 08:35:18
Message: <3A113F96.5C5D5B96@schunter.etc.tu-bs.de>
Chris Huff wrote:
> Or just render an image from above the scene and use the depth
> post_process...
Or a gradient pigment with black/white color_map and
finish { ambient 1 diffuse 0 ) combined with an orthographic camera.
Date: 14 Nov 2000 08:44:02
Message: <3a1141a2@news.povray.org>
Pretty. From what you're saying about increasing resolution, it sounds like
you're not using the Provot method, but rather the Elias method... The
latter is slower and the first doesn't need increases in resolution to lower
stiffness. You merely change a variable or two.
Date: 14 Nov 2000 09:23:09
Message: <3A114ACC.A046094E@tapasmail.net>
Christoph Hormann wrote:
> > post_process...
	Well, obviously there's no lack of solutions to generate the height
field, now if implementing it in a fast and efficient way was as easy
	Just a note though: the problem with this hf approach is that the cloth
cannot fold under the objects (as it does in both examples I've
posted...)
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 14 Nov 2000 09:27:11
Message: <3A114BBC.1E996031@tapasmail.net>
	AFAIK, neither. I developped the method from scratch along with the
program... There *is* a parameter that control stiffness, but no matter
how small you set it, the cloth can only fold at intersections so if the
intersections are too far appart (eg low resolution), the result will
appear stiff.
Date: 14 Nov 2000 14:32:21
Message: <3A119366.B59989A6@skynet.be>
> posted...)
Or use the "object" pattern to do a 3D scan of objects, in some kind
of voxels approach.
Fabien.
Date: 14 Nov 2000 17:17:30
Message: <chrishuff-4710C4.17174314112000@news.povray.org>
In article <3A113F96.5C5D5B96@schunter.etc.tu-bs.de>,
Or give everything a plain white pigment with ambient 1 diffuse 0, and
use a black fog...or make everything black and use a white fog...
Christopher James Huff
Date: 14 Nov 2000 22:40:27
Message: <3A1205FD.BAC0042D@hotmail.com>
I s'pose U know about
http://developer.intel.com/software/idap/games/clothsample/index.htm
Bye
Pabs
Date: 15 Nov 2000 04:24:51
Message: <3A125663.5862D96B@tapasmail.net>
	Yes, I saw it after I already had something working. Actually the basic
idea is the same, but my physical model has evolved quite a bit from
there...
Date: 15 Nov 2000 10:15:05
Message: <slrn9158j9.cbc.steve@zero-pps.localdomain>
Wow, thats so awesome.  Pity it wasn't ready for the Sea round
of the IRTC.
  2:12pm  up 35 days, 16:35,  2 users,  load average: 2.01, 2.08, 2.05
Date: 15 Nov 2000 12:10:59
Message: <3A12C3A3.B1E5818A@tapasmail.net>
> of the IRTC.
	Eh! It wasn't even started by the end of the sea round! ;))
