POV-Ray : Newsgroups : povray.binaries.images : Minus Values in Assumed_Gamma = Strange :) Server Time
4 Mar 2026 15:21:19 EST (-0500)
  Minus Values in Assumed_Gamma = Strange :) (Message 1 to 10 of 19)
Subject: Minus Values in Assumed_Gamma = Strange :)
Date: 12 Nov 2000 02:37:54
Message: <3A0E4914.9E48C88E@pacbell.net>
Got a wild hair tonight and tried a negative value in the
assumed_gamma global setting. Interesting effect. The first
image is how it would normaly appear using assumed gamma 2.2.
The second is assumed gamma -1.0. There must be an application
for this but at the moment I can't think of one....
Download 'plus-22.jpg' (8 KB) Download 'minus-1.jpg' (24 KB)
Preview of image 'plus-22.jpg'
Preview of image 'minus-1.jpg'
Subject: Re: Minus Values in Assumed_Gamma = Strange :)
Date: 12 Nov 2000 10:09:43
Message: <3a0eb2b7@news.povray.org>
Maybe, if you are going to print some blacklight images....
Grim
Date: 12 Nov 2000 11:14:14
Message: <3a0ec1d6@news.povray.org>
I assume it won't work with AA ...
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Ken <tyl### [at] pacbellnet> schrieb in im Newsbeitrag:
3A0E4914.9E48C88E@pacbell.net...
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and
Raytracing Links:
> http://home.pacbell.net/tylereng/index.html
http://www.povray.org/links/
Date: 12 Nov 2000 12:00:56
Message: <chrishuff-EC1E14.12010512112000@news.povray.org>
In article <3a0ec1d6@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
Gamma correction has nothing to do with antialiasing...
Christopher James Huff
Date: 12 Nov 2000 12:21:49
Message: <3a0ed1ad@news.povray.org>
I don't know the source of POV, but
Looking at the picture I think the effect comes from some
clipping-effects of the different rgb-values or some
non-continueities (you know what I mean) of the Gamma-function
with negative values ... (How is gamma defined for negative
values ???)
I think, the question is: When is it applied? Before or after AA
Chris Huff <chr### [at] maccom> schrieb in im Newsbeitrag:
chrishuff-EC1E14.12010512112000@news.povray.org...
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 12 Nov 2000 13:26:08
Message: <chrishuff-7E9319.13261612112000@news.povray.org>
In article <3a0ed1ad@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
I think the gamma correction uses a continuous, non periodic function,
probably just a simple polynomial. The results you see are probably from
the color values being clipped and otherwise messed up by the function.
> I think, the question is: When is it applied? Before or after AA??
Gamma correction would have to be applied to the final result of
computing a pixel, correcting each sample wouldn't give the right
result. Antialiasing has little effect on the image, it mostly makes a
small difference in edges, so the change would be minor.
Date: 12 Nov 2000 15:21:44
Message: <3a0efbd8@news.povray.org>
chrishuff-7E9319.13261612112000@news.povray.org...
Gamma-function
function,
probably from
function.
AA??
of
right
makes a
So this is what I originaly ment ... If you use the
gamma-correction(with negativ values) on an antialiased image ,
you don't have any longer the effect of antialiasing. The GC
could produce again (unexpected) stairsteps.
But: AFAIK Gamma is only defined for values > 0 ...
So does it make sense to ask if the current model is correct ???
Of course, we often have other functions in POV, working with
unrealistic values (negative pigments or lights ...[New question:
what is with negative IOR ???]), but they are or could be quite
predictable, but what do you expect from a negative gamma value
??? How would define the result ???
BTW: has someone here have the code for the gamma function ???
Date: 12 Nov 2000 16:37:00
Message: <slrn90u2bu.uk.steve@zero-pps.localdomain>
On Sat, 11 Nov 2000 23:39:00 -0800, Ken wrote:
>This is a multi-part message in MIME format.
>--------------B99E23FC96263D03210CBB0B
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
Just tried this on one of my own files, it's like all those 1970s
pop videos have come back to get me.
  6:40pm  up 32 days, 21:02,  2 users,  load average: 1.06, 1.10, 1.04
Date: 12 Nov 2000 17:48:27
Message: <chrishuff-0B5574.17483712112000@news.povray.org>
In article <3a0efbd8@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
You would still have the effect of antialiasing, though there will be
additional "jaggies" from the gamma function itself.
Define it as whatever you get when you feed negative input to the gamma
function. :-)
Negative ior may not be unrealistic. The ior of a bubble of air in water
is lower than the ior of water, it just makes the light bend the other
way. An ior of 1 usually means no effect, because POV sets the ior of
"space" to 1. It is the change in ior that causes light to bend...
I said it was probably simple. :-)
The variable opts.GammaFactor is set to assumed_gamma/DisplayGamma in
parse.c.
render.c:
static void gamma_correct(COLOUR Colour)
  if (opts.Options & GAMMA_CORRECT)
    Colour[RED]   = pow(Colour[RED],  opts.GammaFactor);
    Colour[GREEN] = pow(Colour[GREEN],opts.GammaFactor);
    Colour[BLUE]  = pow(Colour[BLUE], opts.GammaFactor);
And as far as I can tell, Clip_Colour() is always called on the color
before this, then the gamma function is called, then the result is added
to the pixel before averaging of values. I'm not sure if the last part
is correct, I noticed that focal blur was changed so individual samples
weren't corrected.
Date: 12 Nov 2000 19:43:41
Message: <slrn90u8im.1km.steve@zero-pps.localdomain>
Don't think I understand most of your questions but this should
answer some.  The attached image was gamma corrected in a graphics
package, to -1.6, and I get exactly the same results as using
negative gamma in pov.
Download 'neggam.jpg' (29 KB)
Preview of image 'neggam.jpg'
