POV-Ray : Newsgroups : povray.binaries.images : Minus Values in Assumed_Gamma = Strange :) Server Time
5 May 2026 09:27:20 EDT (-0400)
  Minus Values in Assumed_Gamma = Strange :) (Message 11 to 19 of 19)
Subject: Re: Minus Values in Assumed_Gamma = Strange :)
Date: 13 Nov 2000 00:39:03
Message: <3A0F8CB2.3C82D2B@yahoo.com>
> Negative ior may not be unrealistic. The ior of a bubble of air in water
> is lower than the ior of water, it just makes the light bend the other
> way. An ior of 1 usually means no effect, because POV sets the ior of
> "space" to 1. It is the change in ior that causes light to bend...
If I can just correct this... space is void and there is no matter, so there is
no IOR, but there is in the air.. the air's IOR is ~1 and so the light passing
from air to space will be refracted with an indice of 1, 0 means no refraction
(ie: passing from space to space), common glass is at 2.2 i think...  And again,
look at the glass on earth, it looks nice, look at it in space and it looks
different, because the IOR passes from 1 to 2.2 and in space from 0 to 2.2...
A negative IOR should simply result in the opposite effect, thus making a
magnifying-glass(?) into a fisheye-lens and making a fisheye-lens into a
magnifier...
Something pretty cool about IOR is when it's animated, ie relative to the clock,
that gives a very nice effect!
Just my two cents! ;)
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Date: 13 Nov 2000 00:42:03
Message: <3A0F8D67.D6E8F50D@yahoo.com>
> Don't think I understand most of your questions but this should
> answer some.  The attached image was gamma corrected in a graphics
> package, to -1.6, and I get exactly the same results as using
> negative gamma in pov.
I don't think I understand the term of "gamma" but I guess this is much like a
inversion of the colors, the image look like a negative (negative? hehe)
Try to open the image with a normal gamma with a photo editor (gimp, photoshop)
and invert the colors and then compare with the negative gamma rendered one...
Simon
Date: 13 Nov 2000 01:15:49
Message: <3A0F8784.AF4A3BE0@pacbell.net>
Jan Walzer wrote:
> I assume it won't work with AA ...
For the record this was rendered with an AA of .01 so I would
say your assumptions are correct.
Date: 13 Nov 2000 02:23:29
Message: <3A0F96FD.77AA764B@kivisalo.net>
Back to shool for you! Vacuum ior=1.0.
http://www.glenbrook.k12.il.us/gbssci/phys/Class/refrn/u14l1d.html
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 13 Nov 2000 02:39:53
Message: <3a0f9ac9@news.povray.org>
Chris Huff wrote in message ...
>In article <3a0efbd8@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
>wrote:
>> [New question:
>> what is with negative IOR
Wrong.  IOR is defined as the *ratio* of the speed of light in a given
material to a reference material (usually, the reference material is a hard
vacuum).  Consequently, the IOR of a bubble of air in water is a value less
than 1 but greater than 0, if water is given an IOR of 1.  If an object has
a negative IOR, it implies that light entering the object will have a
negative velocity -- it will enter the object, stop, turn around, and head
back the other direction!
Mark
Date: 13 Nov 2000 17:04:53
Message: <chrishuff-864B14.17050413112000@news.povray.org>
In article <3a0f9ac9@news.povray.org>, "Mark Wagner"
> given material to a reference material (usually, the reference
> material is a hard vacuum).
Ok, thanks for the info...I wasn't certain about there being a lower
limit to ior. I dimly remember reading about the exact meaning of ior,
but not reliably enough to claim only positive values are allowed.
> If an object has a negative IOR, it implies that light entering the
> object will have a negative velocity -- it will enter the object,
> stop, turn around, and head back the other direction!
Which would probably look like a reflection in most cases...possibly a
useful effect.
Christopher James Huff
Date: 13 Nov 2000 17:11:16
Message: <chrishuff-6CFC2F.17112713112000@news.povray.org>
> so there is no IOR, but there is in the air..
I wasn't talking about outer space(which actually has an ior of 1 as I
recall), I was talking about the "environment" in POV-Ray, which is set
to an ior of 1.
Date: 13 Nov 2000 21:15:04
Message: <3A10AE6F.FA4ACDEE@yahoo.com>
Uh... true!  My mistake, I actually had in mind the difference between air and
vacuum which is  near 0 and so I assumed vacuum's ior was 0, sorry!  Also for
the crown glass at 1.54 ( i actually thought it was about 2.2...)...  But I
learned this 2 years ago in a general physic course...
Thanks for the tips!
Date: 14 Nov 2000 17:52:24
Message: <3a11c228@news.povray.org>
I saw something today that reminded me of your image here. X-Ray images of
distant galaxies.
Grim
