POV-Ray : Newsgroups : povray.binaries.images : Lego castle by torchlight (123k) Server Time
5 May 2026 08:10:51 EDT (-0400)
  Lego castle by torchlight (123k) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Lego castle by torchlight (123k)
Date: 9 Nov 2000 09:36:21
Message: <3A0AB665.4DC1558A@schunter.etc.tu-bs.de>
David Fontaine wrote:
> I'm fairly satisfied with this :)
> Each torch is a column of three (for small "stick") or six (for large
> "lantern") point lights with a yellowish tint. If you look closely (at
> least on the PNG version) the banding is evident, but it blends pretty
> well. Because of the number of lights (42) and the high aa (0.1, even
> 0.2 left nasty artifacts on the daylight version if you look closely) it
> took a long time to render...
> Render time 1d 07h 29m 04s (31:29:04)
> Peak memory 55 873 443
The lighting looks nice but not very lego-like(tm)
How about a second version with bright sky, radiosity, some reflection ?
Ok, you should then leave out the 42 light sources to get it rendered within one
week ;-)
Date: 9 Nov 2000 11:09:58
Message: <3A0ACC56.45D0EBC1@spiritone.com>
With this lighting I am reminded of a quake map. Very cool.
Josh
> This is a very black-level sensitive image, so if you can't make out
> details in the dimly lit areas turn off the room lights or shield your
> monitor, trust me it looks a lot better!
eng### [at] spiritonecom
Date: 9 Nov 2000 20:45:01
Message: <3A0B52CC.7ECC7DD3@online.no>
This image makes me want to construct with
Lego again !
But isn't there a tiny detail missing ?
The word "Lego" on every little "cylinder".
Nice idea to use a wide angled camera here.
This combined with the dim light spots
shows the Lego bricks(?) in a way that I
have never seen them before.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 9 Nov 2000 22:45:47
Message: <3A0B6F13.B0BA9631@faricy.net>
Chris Huff wrote:
> > > Not a problem on a Mac. ;)
> > I hardly see how glare and black-level can be platform dependent...
> Macs have a different gamma(around 1.8), so the darker areas show up as
> brighter on Macs. I could see nearly every detail in even the darkest
> areas on my system(though it retains the dimly-lit look).
Wouldn't it get washed out?
Date: 9 Nov 2000 22:48:09
Message: <3A0B6FA0.AA512A24@faricy.net>
Thanks
That was the first version :) (minus radiosity)
> week ;-)
Heheh
Date: 9 Nov 2000 22:52:45
Message: <3A0B70B3.63532280@faricy.net>
> Lego again !
I've tried it, it's not worth the increase in aa, render time or
memory...
Besides, not all the Lego pieces are copyrighted, so if I make something
out of noncopyrighted pieces I'm free from the long arm of Lego. ;)
There were two reasons I wanted to use ultra_wide_angle; one because I
wanted to place the camera inside the castle but still show it off, and
two because increased angle exaggerates perspective and puts you to
scale with the castle more.
Date: 10 Nov 2000 01:47:45
Message: <3A0B9B33.973E6D4E@unforgettable.com>
Looked pretty good to me.
The pure blacks stay black, and the brighter areas don't change a whole
lot, so it really just serves to bring out the detail in the shadows.
-Xplo
Date: 10 Nov 2000 18:27:12
Message: <chrishuff-DE8FC1.18271810112000@news.povray.org>
In article <3A0B6F13.B0BA9631@faricy.net>, David Fontaine
No, black stays black, and white stays white, only the values in between
are different. Sometimes lighter images created on PC's appear washed
out, but this one looks good.
Christopher James Huff
Date: 10 Nov 2000 21:34:20
Message: <13.349T1043T10983776PeterC@nym.alias.net>
Wicked cool.
Date: 10 Nov 2000 23:55:41
Message: <3A0CD0F5.B987E4D4@faricy.net>
Pete wrote:
> Wicked cool.
