POV-Ray : Newsgroups : povray.binaries.images : radiosity inside ! (WIP, Test, Comparative, 15k) Server Time
14 Jun 2026 01:50:46 EDT (-0400)
  radiosity inside ! (WIP, Test, Comparative, 15k) (Message 11 to 13 of 13)
Subject: Re: radiosity inside ! (WIP, Test, Comparative, 15k)
Date: 9 Nov 2000 18:44:58
Message: <chrishuff-9B0C8D.18450309112000@news.povray.org>
In article <3A0### [at] alpharayde>, Paul Blaszczyk
<3d### [at] alpharayde> wrote:
> it is right, that the maximum of recursion_limit is 6?? I've rendered
> a test-scene with several values for recursion_limit...after 6 all
> rendering times (also at 100 and 150) were the same as at 6.
I think that sampling stops when it gets to the point that additional
samples won't make much difference. It could be that with your settings,
recursion levels beyond 6 would make such a small contribution that they
are dropped. Something like the ADC settings.
Christopher James Huff
Date: 12 Nov 2000 01:55:21
Message: <3a0e3ed9$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote...
Yes.  There is an ADC bailout setting specifically for radiosity (separate
from the usual ADC bailout setting).  See the MegaPov docs for more info.
-Nathan
Date: 12 Nov 2000 04:45:25
Message: <3A0E67D5.D2331D79@unforgettable.com>
It doesn't seem to work like the docs suggest, though. I've set it to 1
and had no real difference on a scene except to smooth out the radiosity
a little. In fact, based on my limited experience, I'd suggest leaving
it set at 1 all the time.
-Xplo
