POV-Ray : Newsgroups : povray.binaries.images : Final(?) WBD Logo (101 KB) Server Time
14 Jun 2026 07:45:48 EDT (-0400)
  Final(?) WBD Logo (101 KB) (Message 1 to 10 of 13)
Subject: Final(?) WBD Logo (101 KB)
Date: 17 Oct 2000 09:31:28
Message: <39ec54b0@news.povray.org>
Well, here's what I ended up with.  The background is just something I stuck
there to replace the previous white one.  Suggestions are always welcome!
Cris
Download 'wbd_logo_17.jpg' (102 KB)
Preview of image 'wbd_logo_17.jpg'
Subject: Re: Final(?) WBD Logo (101 KB)
Date: 17 Oct 2000 11:02:09
Message: <39EC69F1.C510B057@schunter.etc.tu-bs.de>
It looks really good, but some suggestions for the shadows:
- the text outside could have some shadow to fit better into the composition
- the shadows on the logo are not very consistent, while the rim of the plate
has a very dark shadow on the upper left, the shadows the WBD-logo with the
photo and the triangles are casting on the plate are much brighter.  That's
probably because you did not use the same ambient finish for the different
textures.
Date: 17 Oct 2000 11:58:26
Message: <39ec7722@news.povray.org>
I agree that the letters need shadows.  I will add these when I prepare the
image for placement on the web site that it was designed for.
You lost me on the other shadow suggestion.  The upper left shadow on which
plate, the larger one or the small one?  What do you mean by "brighter
shadow"?  The blue background on the smaller disk is darker at the top
because it is a gradient.  The smaller disk doesn't cast a shadow because I
think the image is cleaner without it.  There are two lights casting
shadows, one light is not as bright as the other.  I realize the shadows are
kinda harsh, but I think that adds some impact to the logo.  Or maybe not?
Cris
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39EC69F1.C510B057@schunter.etc.tu-bs.de...
stuck
welcome!
composition
plate
the
That's
> textures.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 17 Oct 2000 12:11:21
Message: <39EC7A2A.A7FABF38@schunter.etc.tu-bs.de>
Sorry if i was not clear enough, with the dark shadow i meant the shadow the
outer rim of the plate is casting on the plate near the word 'wright'.  With the
lighter shadows i meant the shadows the stuff above the plate is casting on the
plate at the opposite side (lower right, near the T of District)
Date: 17 Oct 2000 13:24:14
Message: <39ec8b3e@news.povray.org>
I think I see what you're talking about.  The rim is lit more harshly at the
top and top-left and as a result casts a darker shadow.  There are six
lights sources around the logo, and the brightest one is causing this.
Unfortunately, that same light is also keeping the plate's surface bumps
from getting washed out.  Getting the lighting correct has been the toughest
part of this project because of all the bevels and layers.  :-(
Cris
message news:39EC7A2A.A7FABF38@schunter.etc.tu-bs.de...
the
which
because I
are
not?
the
With the
on the
> Christoph
Date: 17 Oct 2000 14:05:41
Message: <39EC94F4.A18B80E8@schunter.etc.tu-bs.de>
> Cris
You already mentioned you are using a lot of lights when you posted your first
version, but in my opinion it's quite possible to achieve realistic results with
only few light sources.  Some things important for that:
- light source not near the camera
- light source far enough away
- area lights for soft shadows
- brilliance and roughness in the finish statement are most important for the
diffuse and specualar components
There is nothing against many light sources in general, apart form slower
rendering, but managing a lot of light sources when adding modification can be
quite difficult (as you also mentioned) and does not neccessarily lead to better
results.
Date: 17 Oct 2000 15:59:06
Message: <39ecaf8a@news.povray.org>
My scene is approximately 8 units across from compas point to compass point
and about .75 units tall.  My lights are away from the camera and all fall
within a 20-30 unit radius of the logo.  Are these lights way too close?  I
have turned the intensity down for all but one of them - will this
compensate properly for lights that are too close?
message news:39EC94F4.A18B80E8@schunter.etc.tu-bs.de...
the
toughest
> > Cris
first
results with
the
can be
better
> results.
> Christoph
Date: 17 Oct 2000 16:32:43
Message: <39ECB76C.50F8F078@schunter.etc.tu-bs.de>
Probably not, I meant, that the main light should hit the object at similar
angles on all ends.
Additional low intensity lights sometimes tend to wash out the scene and produce
unwanted 'ghost shadows' and additional highlights.
Date: 17 Oct 2000 20:50:47
Message: <39ecf3e7@news.povray.org>
I like it alot. Good Job!
C.J. - POV User
POV Ray Study Gallery
www.crosswinds.net/~povstudy
hou### [at] yahoocom
Cris Williams <wil### [at] udriudaytonedu> wrote in message
news:39ec54b0@news.povray.org...
stuck
> Cris
Date: 17 Oct 2000 21:14:52
Message: <39ecf98c$1@news.povray.org>
Thanks!
"C.J. - POV User" <hou### [at] yahoocom> wrote in message
news:39ecf3e7@news.povray.org...
> C.J. - POV User
> stuck
welcome!
> > Cris
