POV-Ray : Newsgroups : povray.binaries.images : My 1st Image - In Progress (66kb) Server Time
17 May 2026 20:18:35 EDT (-0400)
  My 1st Image - In Progress (66kb) (Message 1 to 10 of 12)
Subject: My 1st Image - In Progress (66kb)
Date: 12 Oct 2000 12:41:49
Message: <39e5e9cd@news.povray.org>
I have attached my first attempt at raytracing and would appreciate any
suggestions that you might have.  It's not finished yet as there are a few
obvious fixes to make.  I need to move the ends of the red, white and blue
rings back so they aren't so close to the big "WBD" and I need to adjust the
MVC and BSA lettering on the bottom.  I will also be adding some lettering
around the outside of the logo once I figure out how.  :-)
This logo will be replacing a logo I did in PSP 6.  The old logo can be seen
at www.wbd-bsa.org.  I would like to make the new logo as realistic as
possible.  The scene was modeled in Moray except for the beveled "WBD",
which was done using Elefont and then imported into Moray as a UDO.  I am
using 6 point lights to illuminate the scene, but only I have only 2 of them
casting shadows because otherwise the "casting" texture on the logo gets
completely washed out.  Please be brutally honest with your opinions and
suggestions - you won't hurt my feelings!
Thanks,
Cris
Download 'wbd_logo_12.jpg' (66 KB)
Preview of image 'wbd_logo_12.jpg'
Subject: Re: My 1st Image - In Progress (66kb)
Date: 12 Oct 2000 14:14:58
Message: <39e5ffa2@news.povray.org>
I think it looks great!
As for letters around the outside of the image, try something along these
lines...
#declare W=
text{
    ttf "timrom.ttf" "W" .2, 0
    pigment { Red }
    // Translate the letter so it centers as close as you can to <0,0,0>
    translate<-.5,-.25,0>
#declare R=
text{
    ttf "timrom.ttf" "r" .2, 0
    pigment { Red }
// Then translate the letter object and rotate into place
object { W translate y*3 rotate z*-45 }
object { R translate y*3 rotate z*-40 }
etc....
This should give you what you are looking for....
C.J. - POV User
www.crosswinds.net/~povstudy
Cris Williams <wil### [at] udriudaytonedu> wrote in message
news:39e5e9cd@news.povray.org...
the
seen
them
> Thanks,
> Cris
Date: 12 Oct 2000 14:25:56
Message: <39E60235.4A1F22B0@netscape.net>
Actually I will have the string "Wright Brothers District" following a circular
path around the outside of the image the same way as the old logo at
www.wbd-bsa.org was done.  I plan to have the word "District" follow a circular
path, too.
Cris
(BTW - Although I run the web site for the Boy Scouts Wright Brothers District,
I don't get paid to do it, I was volunteered!)  ;-)
> lines...
> #declare W=
> text{
>     pigment { Red }
> #declare R=
> text{
>     pigment { Red }
> etc....
> Regards,
> C.J. - POV User
> the
> seen
> them
> > Thanks,
> > Cris
Date: 12 Oct 2000 14:48:36
Message: <MPG.145010bc44445f21989807@news.povray.org>
On Thu, 12 Oct 2000 12:41:13 -0400, Cris Williams wrote...
I was thinking about the lettering thing, and rather than creating each
group of three letters as a string, try creating one placeholder letter,
and using Edit->Duplicate and the orbit and rotate options to get the
lettering truly concentric.
I don't think that made much sense, did it?  <sigh> I know what I mean,
and I could do it in about 5 minutes (time for fiddling and tweaking of
settings.).  The only drawback could be that it may render slower for
using 6 text objects rather than 2 (I could be wrong about that though)
(Oh, and Followup set to moray.win)
Well, since I do my mail offline, I haven't had a chance to look at the
site you mentioned, but I like it, it's simple and clean.  And I like
simple and clean :)
Bye for now,
     Jamie.
Date: 12 Oct 2000 14:51:26
Message: <39E6082E.204F96E6@schunter.etc.tu-bs.de>
It looks good, although i don't believe it's your first Povray pict (sorry :-)
I would probably change the lighting, because there are steps in the shadows
because of the 2 point lights casting shadows.  You could try to use just one
light source and make it an area light for soft shadows.
I don't really understand what you need the additional 4 shadowless light
sources for (please explain).
Date: 12 Oct 2000 15:37:18
Message: <39E612E6.9A3AFCC5@netscape.net>
Thank you!  But it really is the first one.
The multiple light sources grew out of my total inexperience with using light
sources and my efforts to get highlights and shadows in the right places without
obscurring the normal.  I am definitely not happy with the lighting yet.  I
especially don't like the way the shadow from the "WBD" falls on the SW compass
point and the lack of contrast in that area.  I used some shadowless lights
because all of the shadows were making the surfaces too "busy" looking.  If you
look closely you'll notice the smaller disk with the blue gradiant doesn't cast a
shadow either.
Cris
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 12 Oct 2000 17:33:50
Message: <39E62E3F.528EE5E8@schunter.etc.tu-bs.de>
You can do quite a lot about specular highlights with changing roughness, same
for diffuse and brilliance.
Date: 12 Oct 2000 18:30:41
Message: <39e63b91$1@news.povray.org>
I like it a lot - very nice
some problem with the BSA at the bottom ... the veritcal bar in the B is
barely visible.
"Cris Williams" <wil### [at] udriudaytonedu> wrote in message
the
seen
them
> Thanks,
> Cris
Date: 12 Oct 2000 22:14:58
Message: <slrn8ucr41.7ad.steve@zero-pps.localdomain>
That's really nice work for a first render.  Welcome aboard.
  1:33am  up 2 days,  2:59,  2 users,  load average: 1.31, 1.87, 1.70
Date: 13 Oct 2000 10:20:27
Message: <39e71a2b$1@news.povray.org>
Cris,
The example I gave will give you a circular path. When you get to spelling
district, translate it by a negative Y.
C.J.
Cris Williams <wor### [at] netscapenet> wrote in message
news:39E60235.4A1F22B0@netscape.net...
circular
circular
> path, too.
> Cris
District,
these
> > lines...
> > #declare W=
> > text{
> >     pigment { Red }
> > #declare R=
> > text{
> >     pigment { Red }
> > etc....
> > Regards,
> > C.J. - POV User
any
few
blue
adjust
> > the
lettering
be
> > seen
"WBD",
am
of
> > them
gets
and
> > > Thanks,
> > > Cris
