POV-Ray : Newsgroups : povray.binaries.images : Help! Why is my media so dark? (about 3 kb) Server Time
28 Jun 2026 20:43:01 EDT (-0400)
  Help! Why is my media so dark? (about 3 kb) (Message 1 to 6 of 6)
Subject: Help! Why is my media so dark? (about 3 kb)
Date: 30 Sep 2000 18:16:33
Message: <39d66641@news.povray.org>
have a look at the attached picture please.
That media you can see there is supposed to be white. In fact it is white,
when I remove the clouds from the scene, which are generated by Samuel
Benges layered planes code. I thought it could be just a shadow of the
clouds, but it remains dark, even if it is lit by a shadowless light_source
at the camera position or by radiosity.
I set max_trace_level up to 700 but it does not change anything. Some code
at the end of this post (hope it's okay to post it here, 'cause no one will
probably ever search for it again).
So, what is going on here? I hope it is not a to silly error of mine :-).
Thanks in advance,
Marc-Hendrik
My media-box:
box {<-6,0,-2>, <8, 3,0>
     hollow on
     pigment {rgbf 1}
     interior{
        media{
           scattering{1,0.002}
           density{ gradient y
              color_map{
                 [0.4 rgbt 1]
                 [0.5 rgb 500]
                 [0.6 rgbt 1]
              translate <2,-2.6,0>
              rotate z*-15
              turbulence 0.3
              scale 6
              translate <3,-0.5,0>
           method 1
           intervals 1
           samples 10, 10
           confidence 0.999999
           variance 1.0/1024
The clouds by SamuelT (not much modified):
// Clouds from Samuel Benge
#declare Clouds=function "ridgedMF",<1,2.25,7,-1,1>
#declare Y=0;
#declare Ivals=5; //Number of cloud planes
#while(Y<1)
//plane{y,100+(Y*20) clipped_by{box{<-1000,0,-1000>,<1000,200,1000>}}
polygon{5,<-3000,-3000>,<-3000,3000>,<3000,3000>,<3000,-3000>,<-3000,-3000>
  rotate x*90 translate y*100+(Y*20)
  pigment{function Clouds(x,y,z)/3.8+noise3d(x/20,y/20,z/20)/3.5+(z/20)
   scale<300,150,300> phase -.5
   color_map{[.25 rgbf 1][.4 rgbt<1/1.5, 1/1.5, 1/1.5, .01>]}
  finish{diffuse 1.5 ambient .25 }
  hollow double_illuminate
#declare Y=Y+1/Ivals;
Download 's1.jpeg.jpg' (3 KB)
Preview of image 's1.jpeg.jpg'
Subject: Re: Help! Why is my media so dark? (about 3 kb)
Date: 1 Oct 2000 02:44:20
Message: <39d6dd44@news.povray.org>
It does fine, no problem with it.  Except for graininess using the method 1
kind.  I changed it to method 2 with samples 2,2 and it's both fast and
smooth; default max_trace_level.  I have no idea then why you get a dark
media there.  MegaPov 0.5a being used?
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:39d66641@news.povray.org...
Date: 1 Oct 2000 04:14:02
Message: <39d6f24a@news.povray.org>
Hu?
Yes, MP 0.5a. Hm, ambient_light is set to zero. Does that make any
difference?
BTW: It's not supposed to be smooth :-)
Marc-Hendrik
Bob Hughes schrieb in Nachricht <39d6dd44@news.povray.org>...
>Bob
white,
Subject: Re: Help! Why is my media so dark? (+ about 18 kb)
Date: 1 Oct 2000 04:41:47
Message: <39d6f8cb@news.povray.org>
news:39d6f24a@news.povray.org...
| difference?
No matter.  I get a granular white media object.  So it's not any of that
part of the scene file you posted here.  I even put the whole thing into a
large (hollow) box.
What is the light_source, where at.  Above the clouds?  Well I tried that
too though.
Strange that it's not working then but must be another factor.
Attached is what I get here, the samples are 2,2 but doesn't change color
using any samples that I can tell.
Download 'mediatestpuff.jpg' (14 KB)
Preview of image 'mediatestpuff.jpg'
Date: 1 Oct 2000 07:20:58
Message: <39d71e1a@news.povray.org>
Now this is odd.
I'll post a whole scene file to p.t.s-f. It leads to black media for me.
Please try it.
The light_source is indeed above the clouds, but it doesn't matter, 'cause
the media remains black with other lighting.
Marc-Hendrik
Bob Hughes schrieb in Nachricht <39d6f8cb@news.povray.org>...
>large (hollow) box.
>too though.
>Bob
Date: 1 Oct 2000 10:32:52
Message: <39d74b14@news.povray.org>
Please see my reply to your scene file posted at p.t.s-f.
