POV-Ray : Newsgroups : povray.binaries.images : Glows Server Time
5 May 2026 13:41:06 EDT (-0400)
  Glows (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Glows
Date: 28 Sep 2000 12:59:49
Message: <39d37905$1@news.povray.org>
"ian" <ian### [at] aolcom> wrote :
> Would it be possible to see the source for this?
> Mainly I'm interested in the Emergency lights w/glow.
    There is nothing to the light fixture, just some cylinders and torii. It
would take me longer to clean it up than for you to write it. The glow is :
 glow {
 location < -8.0, 0.0, ZEE >
 size 2.5
 color < 1.0, 0.0, 0.0 >
 fade_power 2
 type 0
with a light source :
light_source { < -8.0, 0.0, ZEE >
               color rgb < 2.0, 0.6, 0.6 >
               fade_distance 50
               fade_power 2 }
        ... again, nothing special.
Subject: Re: Glows
Date: 28 Sep 2000 13:31:30
Message: <39d38072@news.povray.org>
I appreciate it. :)
I've not used Plus before, so this example will help very much.
ian
Bill DeWitt wrote in message <39d37905$1@news.povray.org>...
It
Subject: Re: Glows
Date: 28 Sep 2000 14:40:02
Message: <MPG.143da0e3a775c45f9897f2@news.povray.org>
On Wed, 27 Sep 2000 13:56:20 -0700, ryan constantine wrote...
> i haven't played much with glows yet.  can the shape be manipulated?
Unfortunately not, individual glows can only be spherical at the moment.
But if you string enough small, dim glows together, you can get
approximations of other shapes.
>  it
> looks like your e-lights are oblong like they should be.  your main
> light looks like it has a bulge in the middle.  is there a looks_like
> for glows?
Nope, not as far as I know.
>  or maybe a feature called shape_of would be cool. nice pic
> by the way.  is the moire pattern on the far wall jpeg's fault?  do you
> plan on developing the scene further?  i think you should.  i like it so
> far and see a lot of potential.
As far as I understand it (I.e. not really that well) the glow is a
rendering shortcut which calculates the brightness of a hypothetical glow
point based on how close to the light source the ray passes.
I suspect that someone else (I.e. Chris Huff) could explain this far
better than I can or have.
Bye for now,
     Jamie.
Subject: Re: Glows
Date: 30 Sep 2000 17:01:33
Message: <39d654ad@news.povray.org>
"ryan constantine" <rco### [at] yahoocom> wrote :
>   do you
    OK, so I did change things a little and I might end up making a scene
from it. The fluorescents need some work and a few more basic parts, but I
think it is possible to make some good ones with glows.
Download 'Test Glow 08.jpg' (48 KB)
Preview of image 'Test Glow 08.jpg'
Subject: Re: Glows
Date: 30 Sep 2000 21:48:36
Message: <slrn8td57u.5uj.steve@zero-pps.localdomain>
>>   do you
Like you say the flourescents seem to fuse in the middle.  And maybe a good
idea to use a wall mactro, those lumps overlap mortar/block.  I seem to
remember Bob (or was it Grim), who did some real good concreet block quite
a while ago that would look great in here.
Those emergency lights do look good.
  2:26am  up 2 days,  4:46,  3 users,  load average: 2.15, 2.23, 2.13
Subject: Re: Glows
Date: 1 Oct 2000 04:47:56
Message: <o8udtsg3nircf5rfrmivodg60708fk1ffm@4ax.com>
On Sat, 30 Sep 2000 17:01:10 -0400, "Bill DeWitt"
May I recommend using radiosity only to light your scene? Those
shadows are way off with such a blurred glow, methinks.
Peter Popov ICQ : 15002700
Subject: Re: Glows
Date: 1 Oct 2000 08:59:04
Message: <39d73518@news.povray.org>
    I have done a couple of tests of that, but until I really get somewhere
with the scene, I don't think I will be rendering many radiosity tests...
Maybe there are some adjustments I could do, but 20 min without and 7.5 hrs
with....?
Subject: Re: Glows
Date: 1 Oct 2000 18:10:25
Message: <jcdftscp4evq9549o6p7sba5pu4h66v8nb@4ax.com>
On Sun, 1 Oct 2000 08:59:07 -0400, "Bill DeWitt"
>with....?
Holy pieces o' cow!!!
Subject: Re: Glows
Date: 1 Oct 2000 18:37:49
Message: <39d7bcbd@news.povray.org>
    After removing the other lights, bounding (radius) the glows and
reducing the number of them plus a few adjustments to radiosity, it sped up
significantly. But it looks like pieces of cow waste now... what am I doing
wrong?
Download 'Test Glow r 12.jpg' (20 KB)
Preview of image 'Test Glow r 12.jpg'
Subject: Re: Glows
Date: 2 Oct 2000 03:27:26
Message: <39d838de$1@news.povray.org>
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:39d7bcbd@news.povray.org...
up
doing
| wrong?
This loses a lot without the lighting.
A low error_bound is probably needed, say about 0.2 or so.
Did you see what Xplo Eristotle had tried for radiosity settings?  Posted
here recently; seemed to do well both for time and quality from what I saw
of it.
Your fluorescent lights show a great example of the use of glows.
