POV-Ray : Newsgroups : povray.binaries.images : Cracked Sphere (~41kbbu) Server Time
5 May 2026 16:52:49 EDT (-0400)
  Cracked Sphere (~41kbbu) (Message 11 to 13 of 13)
Subject: Re: Cracked Sphere (~41kbbu)
Date: 14 Sep 2000 17:36:24
Message: <chrishuff-97AFF5.16381914092000@news.povray.org>
In article <39C0E9D3.C9E82E0F@insectes.net>, Libellule
<lib### [at] insectesnet> wrote:
> I tried differencing that from another sphere to get the other half
> (and also scaling that sphere by 0.999 to not have coincident
> surface), but it seems the isosurface is randomized somewhat at each
> call (I guess this is because the isosurface has agate in it?)
It might just be the ordinary inaccuracies in the solving algorithm. You
might try differencing a thinner, sheet-like isosurface from a single
sphere instead. Or making a hollow isosurface like a single, infinitely
thin sheet, and clipping it to fit inside the sphere(kind of a "false
surface" inside the sphere). This last one couldn't simulate a gaping
crack, but it might be useful for hairline cracks in glass.
Hmm, did you say you differenced the difference of a sphere and
isosurface from another sphere? Try just making another difference of
the sphere with the same isosurface(using "sign -1" to flip the "inside"
of the isosurface to the other side) instead...and separate the halves
by a small amount to avoid coincident surface problems, of course.
Christopher James Huff
Date: 15 Sep 2000 09:45:00
Message: <39C2282B.2654497E@insectes.net>
> You're image is nice, but kind of hard to see.  It's because of the
> reflections/refractions of the floor.
Yeah, I don't know why they're showing up at the top half of the sphere, it
looks rather strange
> The pattern is quite nice.  If you render it in a clear pigment with slight
> blue and white tint, it could look like ice.
Maybe I'll try that :o)
Date: 15 Sep 2000 09:48:20
Message: <39C228EF.7D5EB223@insectes.net>
This sounds reasonable, I tried making two identical halves next to each
other, and though they looked very similar, they were visibly not the same.
Maybe I could just decrease the accuracy value (to increase the accuracy ;)
I'll try your sign -1 suggestion as well
