POV-Ray : Newsgroups : povray.binaries.images : glow sample image, 4 types Server Time
17 Jul 2026 02:02:07 EDT (-0400)
  glow sample image, 4 types (Message 1 to 5 of 5)
Subject: glow sample image, 4 types
Date: 11 Sep 2000 23:52:23
Message: <39bda877@news.povray.org>
This is not a finished picture at all, just a sample exercise to show off
the different glows' properties.
Some information on the picture and some thoughts on glow:
o  There are 100 glows in the images, all images were rendered 320x240 no
AA.
o  Glow types 2 & 3 color statements were increased 10 fold, due to their
limited interaction.
o  The radii used were complimentary to their visible glow.
o  There are obvious speed concerns.
o  I think each glow has its own usefulness.
o  I feel type 1 works best for this image; type 1 has a blobby/plasma feel
to it.
o  type 0 is close to type 1, but the glows act more individually [stars].
o  type 2 is fast and has a unique clumpiness, almost cloudy.
o  type 3 is a fast way to approximate the look of 0 & 1.
quick conversion from 0.3 to 0.3.1
glow { FLOAT_AMOUNT color VECTOR ... }
-- changes to --
glow { color FLOAT_AMOUNT*VECTOR ... }
Don't forget, I think 'turbulence' changed as well, and I'd also suggest
against using 'size' at all (it's hazardous to your sanity).
Also! Read the docs! Have fun! Experiment! These things animate wonderfully.
Jeff
Download 'glow_sample.jpg' (25 KB)
Preview of image 'glow_sample.jpg'
Subject: Re: glow sample image, 4 types
Date: 12 Sep 2000 00:23:34
Message: <39bdafc6@news.povray.org>
"Jetlag" <bga### [at] microsoftcom> wrote in message
news:39bda877@news.povray.org...
> -- changes to --
I'm not getting the new syntax, can you post a sample? I keep getting "float
expected, end of file found instead".
Date: 12 Sep 2000 00:41:09
Message: <39bdb3e5@news.povray.org>
"float
I think the *simplest* example would be:
glow { }
you should throw these in for good measure:
camera { location z*-10 }
box { 0,0 }
I believe 'glow { }' implies:
glow { color 1 location 0 type 0 size 1 }
An example of a 0.3->0.3.1 conversion would be:
glow { 2 color <.2,.3,.1> location <0,1,2> glow_type 0 }
--to--
glow { color <.4,.6,.2> location <0,1,2> type 0 }
You say it says "float expected"? Could you post the glow statement that
produces that? Oh, and make sure you're running the version you think you
are [check 'Help | About' or the console]. (I often have different versions
running at the same time and confuse myself regularly.)
Date: 12 Sep 2000 17:59:24
Message: <39BEA6E3.F2F0135A@totalise.co.uk>
I get a similar error "object or directive expected
but end of file found instead" if I don't put a box{0,0} after the
glows.... see my post in p.u.p.
Keith
> "float
> glow { }
> box { 0,0 }
> --to--
Date: 12 Sep 2000 18:24:21
Message: <39bead15@news.povray.org>
"Keith Hull" <kei### [at] totalisecouk> wrote in message
news:39BEA6E3.F2F0135A@totalise.co.uk...
    That fixes it, thanks.
