POV-Ray : Newsgroups : povray.binaries.images : is radiosity (MP) really necessary? [tot~80KB Jpg] Server Time
18 May 2026 03:50:25 EDT (-0400)
  is radiosity (MP) really necessary? [tot~80KB Jpg] (Message 11 to 13 of 13)
Subject: Re: is radiosity (MP) really necessary? [tot~80KB Jpg]
Date: 6 Sep 2000 11:39:13
Message: <39b66521@news.povray.org>
"Xplo Eristotle" <inq### [at] unforgettablecom> wrote in message
news:39B5787A.641CC3B5@unforgettable.com...
| Set the sky ambient to 1 and diffuse to 0.
Well, you are saying the opposite there from my experiences with the MegaPov
kind.  Perhaps you are talking of official POV-Ray though.
| >          count 100 // or 50 // may be too low
| Unless hyper-accurate shadowing is a necessity, and I don't see why it
| would be for this scene, error_bound will be just fine between 0.6 and
| 1. Count 50 is plenty; a high count is best when you have small, bright
| objects, or a very "noisy" scene, but you have a relatively simple one
| with an entire lit hemisphere. You could even go down to 30. Set the
| low_error_factor to 1, you're not going to need it (in my testing, it's
| pretty useless). Recursion_limit 1 is plenty, I wouldn't mess with the
| minimum_reuse, and brightness could go as high as 1.667 or so.
| You could even set pretrace_start to .01 if you want to shave an extra
| several seconds off; I haven't found that multiple passes help, provided
| that the one pass you DO use is fine enough.
| Try that and see how it goes. :)
Yep, I'll check another render out using your advice.  What I did was to use
the recent radiosity settings Mike Hough and others had been using for those
smoothed shadowed hemispherically lit Arnold-like things, figuring if it was
good enough for that....
The main point I wanted to make is how a radiosity rendering could
potentially be worthless compared to a much speedier rendering.  I mean 16
times slower than a comparable radiosity render (5.25 hours vs. 1/3 hour!)
with recursion at 1 is no doubt all in vain.  It's sure to vary greatly
scene to scene but I think people should be made aware.  The general rule of
small test renders always applies.
Thanks for the helpful hints.
Date: 6 Sep 2000 11:44:21
Message: <39b66655@news.povray.org>
"GrimDude" <gri### [at] netzerocom> wrote in message
news:39b55893@news.povray.org...
| Doh! Nevermind. I went back and read everything you wrote.
The reason for the sky not being a sky_sphere is for when the media is used,
that's where the needed finish comes into play otherwise I wouldn't be using
a regular sphere at all.
| I think what is going on is you have adjusted the scene for similarity
(re:
| rad/no rad). MP rad really kicks in when you have no ambient components.
| Sky_spheres, of course, influence the scene none-the-less (in my
experiments
| anyway), but everything else should be defined as ambient 0, unless you
want
| them to glow/radiate. Adding ambient_light really messes with things.
You guessed that right.  It's all so the two look about the same, excepting
for what I was trying to get the radiosity to enhance.
| You are, of course, free to use artistic interpretation at your own whims!
| :) I'm always playing with such things.
No end in sight to that here also.
Date: 6 Sep 2000 17:04:23
Message: <39B6B206.BBDB48C9@unforgettable.com>
Nope, I'm talking about MegaPOV. With those settings, the sky SHOULD
give off radiosity but not receive any, which is what it ought to do.
(In real life, the sky probably DOES pick up some ground radiosity, but
I doubt it makes a lot of difference.)
I posted the first one of those. ;)
Well, that's true of almost anything: antialiasing, photons, area_light
settings, isosurface accuracy, et al.
-Xplo
