POV-Ray : Newsgroups : povray.binaries.images : Re: code for Kevin Wampler's clouds Server Time
29 Dec 2025 04:05:05 EST (-0500)
  Re: code for Kevin Wampler's clouds (Message 1 to 1 of 1)
Subject: Re: code for Kevin Wampler's clouds
Date: 24 Aug 2000 14:44:14
Message: <39a56cfe@news.povray.org>
Sorry about, that thought I'd cancelled the post. You'll find it in p.t.s.f.
Mick
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
news:39a56c67@news.povray.org...
> Here's the code as promised - you'll see I havn't used the Cloud function
> but I've left it in for you to play with.
> I've annotated it as best I can.
> Mick
> #version unofficial MegaPov 0.5;
> #include "colors.inc"
> global_settings
>   assumed_gamma 1.0
>   max_trace_level 255
> #declare Image_Length = 640;
> #declare Image_Height = 480;
> camera
>   location  <0.0, 0, -25.0>
>   direction 1.5*z
>   right Image_Length/Image_Height*x
>   up.6
>   look_at   <0.0, 5,  0.0>
> sky_sphere
>   pigment
>     gradient y turbulence .3 lambda 3
>     color_map { [0.0 color rgb <0,.45,.65>] [1.0 color rgb 1] }
> light_source{<0, 93000000,0> color rgb<1,.9,.775/1.125> rotate z*-45
rotate
> x*30} // change the highlight colour of the clouds
> #declare R = seed(45376);
> #declare Dfoff = 1.5;  file://was 1 higher bulks out clouds
> #declare FS = 1.25; // .5 wispy 2 very solid default 1
> #declare Int_F = 2; // should be 0 or 2 two more solid, rounder
> #declare Cloud_form = function { pigment {
>   blob {
>     sphere { <0,0,0>, 10, FS density_function Int_F, Dfoff }
>     sphere { <1,8,0>, 5, FS density_function Int_F, Dfoff }
>     sphere { <0, 0, 0>, 8, FS density_function Int_F, Dfoff scale <1, .7,
1>
> translate<6, 1, 1>}
>     sphere { <0, 0, 0>, 6, FS density_function Int_F, Dfoff scale <1, .6,
1>
> translate<10, 4, -2> }
>     sphere { <0,0,0>, 13, FS density_function Int_F,Dfoff scale <1, .5,
.6>
> translate<-10, 3, 4> }
>     threshold 0.075 file://varying this produces some interesting
variations
> 0 to .05 to .2
>         // 0 keeps media contained within the sphere?
>     max_density 1//leave
>   color_map {
>     [0 rgb 0]
>     [1 rgb 1]// seems to break up cloud lower more broken up higher more
> solid(no higher than 1.1)
> #declare Cloud_turb = function { pigment {   file://Play with this to get
> best cloud quality
>   granite
>   file://warp{turbulence .25 octaves 3 omega .7 lambda .3}
>   color_map {
>     [0 rgb 0]
>     [.325 rgb .8] // .375generally keep above .325
>     [1 rgb .5] file://play with
>   scale 15 // size of turbulence 10 to 25
> #declare Cloud1 = function { max(0, Cloud_form -.6*(1-Cloud_turb) ) }
> file://#declare Cloud = function { min(Cloud1^.3, .07) } file://gives very
> hard edges and shapes I havn't used
> #declare Cloud_Mass =
> intersection {
>   box { <-20, -15, -20>, <20, 20, 20> } // you can control the shape of
the
> base of the clouds with this
>   blob {
>     sphere { <0,0,0>, 10, 1 }
>     sphere { <1,8,0>, 5, 1 }
>     sphere { <0, 0, 0>, 8, 1 scale <1, .7, 1> translate <6, 1, 1>}
>     sphere { <0, 0, 0>, 6, 1 scale <1, .6, 1> translate <10, 4, -2> }
>     sphere { <0,0,0>, 13, 1 scale <1, .5, .6> translate <-10, 3, 4> }
>     threshold .001
>   texture { pigment { color rgbf 1 }}
>   interior {
>     media {
>       method 2
>       intervals 3  file://3 for final?
>       scattering { 5, color rgb <.14,.15,.14> extinction .6}//
eccentricity
> .2 } file://changes colour of clouds raising extinction Darkens Clouds
>       density {
>         function { Cloud1 }
>         color_map {
>           [0  color rgb 0]
>           [1  color rgb .05]//was 1 lightens the contrast, the bigger the
> number the higher the contrast &
>                file://the darker the base, more dramatic .01 whispy 1 too
> dark 0.05 good .075 darker
>   scale 30
>   hollow
> // Comment out for a single cloud use object{Cloud_Mass translate <0,
1200,
> 2500>}
> #declare Xpos = -5000;
> #declare Zpos = 15000;
> #declare T = 0;
> #while (Zpos>1000)
>    #while(Xpos<5000)
>   object{Cloud_Mass translate <Xpos, 1200, Zpos> rotate y*rand(R)*360}
>    #declare Xpos = Xpos+275;
>    #end
>  #declare Zpos = Zpos-300;
> #end
