POV-Ray : Newsgroups : povray.binaries.images : Dragonfly revisited 39k Server Time
18 May 2026 07:38:25 EDT (-0400)
  Dragonfly revisited 39k (Message 1 to 10 of 14)
Subject: Dragonfly revisited 39k
Date: 23 Aug 2000 17:58:58
Message: <39a44922@news.povray.org>
I like glass objects but I don't usualy have the patience to finish
them. This Dragonfly started over 2 years ago and was resurrected when
I tried megapov and photons.
<moan>
Wanted a yellow tail but caustics were too weak. Did not want a white
plane but anything else hides the caustics again :(
Still too many black pixels, even with max_trace_level 85, but AA 0.01
gets rid of most of them at this resolution. ADC_bailout does'nt help
much even at 0.05
</moan>
DOS MegaPov 0.4, Celery 500, 128M ram and took 72 minuits.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
"...but I've never seen an elephant fly" tra-la-la (From Dumbo?)
Download 'Dragonfly.jpg' (39 KB)
Preview of image 'Dragonfly.jpg'
Subject: Re: Dragonfly revisited 39k
Date: 23 Aug 2000 18:34:43
Message: <39A45056.32E778EF@online.no>
> <moan>
> much even at 0.05
> </moan>
Nice !
I like the red glass a lot. What's the code for it ?
And how are the wings done ?
There seems to be some problems with the attachment of the
rear wings to the body.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 23 Aug 2000 18:48:41
Message: <39A452A7.69C25495@faricy.net>
Phantastic! :-)
David Fontaine   <dav### [at] faricynet>   ICQ 55354965
Please visit my website:  http://davidf.faricy.net/
Date: 24 Aug 2000 07:36:59
Message: <39a508db$1@news.povray.org>
Looks like that gummy jelly stuff, yummy
Kitty5 WebDesign - http://www.kitty5.com
TEL - +44 (01625) 266358 : FAX +44 (01625) 611913
PGP Public Key
http://pgpkeys.mit.edu:11371/pks/lookup?op=get&search=0x55116DCC
Date: 26 Aug 2000 06:46:05
Message: <39a79fed@news.povray.org>
I posted 3 replies to this thread on 25/8 but can not see them here.
Can anyone else see them please?
Alf
Alf Peake <alf### [at] peake42freeservecouk> wrote in message
news:39a44922@news.povray.org...
when
> <moan>
white
0.01
help
> much even at 0.05
> </moan>
> Alf
Date: 26 Aug 2000 07:07:45
Message: <39A7A492.E95604C2@mindspring.com>
> Alf
I can't see them either, Alf.
Kevin Jackson-Mead
http://www.mindspring.com/~jacksonmead
Date: 26 Aug 2000 10:22:00
Message: <slrn8qfiq5.cn7.steve@zero-pps.localdomain>
Can't see any of your replies.  Maybe the browser crashed before you
posted or something.
  2:36pm  up 4 days, 18:54,  2 users,  load average: 1.07, 1.51, 1.55
Date: 26 Aug 2000 15:39:54
Message: <39a81d0a@news.povray.org>
(3rd repost, seems I can only reply to my original post)
Subject: ReDragonfly revisited 39k
Date: 25 August 2000 20:54
Tor Olav Kristensen <tto### [at] onlineno> wrote in message
news:39A45056.32E778EF@online.no...
> Nice !
Thank you.
#declare Filtr=0.95; // Used ior 1.45 in final merged objects.
#declare GlassF = finish{ phong 0.4 phong_size 400 diffuse 0.1
reflection 0.05 ambient 0.5 }
Object{ Thorax pigment{ rgbf <1,0.2,0.2,Filtr> } finish{ GlassF } }
// The PNG is wing-shaped crackle, blurred to round-off the outer
edges.
#declare Wing=
difference{ box{ <0,-1,0>, 0.996 }
            height_field{ png "dragonhf.png" smooth translate -y*0.25
inverse }
            height_field{ png "dragonhf.png" smooth scale <1,-1, 1>
translate y*0.25 inverse }
     translate <-0.02,0,-0.95>
     scale <5.5,0.05,1.5> // Front pair. Rear pair will scale this
one.
     rotate <-16,-104,0>
     pigment{ rgbf <0.8,0.9,1,Filtr> } finish{ GlassF }
Yes, its that blob / camera angle thingy again. Same sort of thing
happens with 'lipsoids. I also lose the shadow with some angles.
The jpeg shows a close up, camera over left wings, (leading edge to
the left) all other objects removed, tail would be to the right. The
left 2 sections are opaque, no photons, with camera <0,4,-4> and the
right one is clear with photons and camera <0,5,-3>. Note the right
pair of wings do not connect in this one :(
See also a larger version, 88k,  of the pic I uploaded here in March:
http://www.peake42.freeserve.co.uk/pix1/dragnfly.jpg
Alf
Download 'Detail.jpg' (19 KB)
Preview of image 'Detail.jpg'
Date: 26 Aug 2000 15:39:56
Message: <39a81d0c@news.povray.org>
(Been having trouble replying - seems response headers are screwed)
Date: 25 August 2000 16:20
Should be a macro around to cover this with sugar I guess. What
flavour the blue? :)
Thanks also David F for response.
Alf
Rick [Kitty5] <ric### [at] kitty5com> wrote in message
news:39a508db$1@news.povray.org...
> Rick
> PGP Public Key
Date: 28 Aug 2000 18:16:51
Message: <39AAE38B.A57CEA91@online.no>
> > Nice !
> Thank you.
Thank you!  I'll try that.
> edges.
> #declare Wing=
> inverse }
> one.
>      rotate <-16,-104,0>
Ahh... Height fields !
Thanks again.
I wasn't aware that there were such problems with blobs.
Is it a photons-only error, or can it happen to me in standard POV
as well ?
What are 'lipsoids in POV-ray ?
May I ask how you generate that Fibonacci stuff ?
I have a vague memory of a Golden Ratio between the
number of right turns and the number of left turns (?)
Tor Olav
