POV-Ray : Newsgroups : povray.binaries.images : Little Pod Server Time
29 Dec 2025 02:20:05 EST (-0500)
  Little Pod (Message 1 to 7 of 7)
Subject: Little Pod
Date: 30 Aug 2000 11:45:14
Message: <39AD2C5D.1120F619@istar.ca>
A little something I've been working on when I get frustrated with my
cloud efforts.
Modelled in Rhino and Moray, renderer time of about 3 minutes. Someone
more comfortable with blobs could probably create the thing in pure POV.
I rather like it.
Simon
Download 'littlepodiso.jpg' (51 KB)
Preview of image 'littlepodiso.jpg'
Subject: Re: Little Pod
Date: 30 Aug 2000 11:54:09
Message: <39AD2E59.A778861@aetec.ee>
> cloud efforts.
Another photo? :o)
> I rather like it.
Ditto here. Esp. texturing, seems quite realistic, although IMO in a
smaller scale would be even better (but then those dents and bumps will
probably be lost).
Date: 30 Aug 2000 12:24:30
Message: <39ad353e@news.povray.org>
superb textures could you tell us a little about how you go about creating
them?
Mick
"Simon de Vet" <sde### [at] istarca> wrote in message
news:39AD2C5D.1120F619@istar.ca...
> cloud efforts.
> I rather like it.
> Simon
Date: 30 Aug 2000 12:48:24
Message: <39AD3B33.6AA0E164@istar.ca>
> them?
Considering the reaction I got to my last use of imagemaps, I'm a little scared
to :)
The jetengines are cylindrically image and bump mapped, with a texture I found
at http://v2.scifi-art.com/asp/
The finish makes them look good:
   finish
      ambient 0.0
      phong 0.417233
      phong_size 7.946667
      specular 0.064733
      irid
         0.1
         thickness 0.1
         turbulence <1.0, 1.0, 1.0>
The inner engine cones are essentially the same texture, only with a nearly
uniform pigment (slight variation in granite), slight normal (again, granite),
and reflection.
The main ship hull is more complex. It is a bozo texture map, made of two
different layered textures. The first is the same imagemap as the engines,
overlayed with yellow and black stripes, from a radial pigment. It also uses the
same bump map. This texture has the finish:
   finish
      ambient 0.0
      brilliance 2.0
      phong 0.3453
      specular 0.294933
      irid
         0.15
         thickness 0.2
The other texture in the bozo texturemap is idential, except for dirtier looking
yellows, and lower phong/specular values. I find that this technique works very
well for metals, giving it the appearance of use.
The window is:
   material  // Blue Window
      texture
         pigment
            color rgb <0.217, 0.235468, 0.3038>
         normal
            bozo , 0.05
            scale  0.3
         finish
            ambient 0.0
            brilliance 3.0
            phong 0.8417
            phong_size 48.343333
            specular 0.431633
            roughness 0.030067
            metallic 0.2
            reflection 0.2
            irid
               0.1
               thickness 0.2
And that's basically it! If there is anything to be learned from all this, it's
that brilliance makes for good metals, variable finishes make things look used,
and iridescence is always handy.
Simon
Date: 30 Aug 2000 14:30:47
Message: <39ad52d7@news.povray.org>
Well all I can say is that your textures are a vast improvement on those in
that site. If image maps work use em that's what I say! (but not fer clouds)
Mick
news:39AD3B33.6AA0E164@istar.ca...
creating
> > them?
scared
> to :)
found
>    finish
>       ambient 0.0
>       phong 0.417233
>       phong_size 7.946667
>       specular 0.064733
>       irid
>          0.1
>          thickness 0.1
nearly
granite),
> and reflection.
uses the
>    finish
>       ambient 0.0
>       brilliance 2.0
>       phong 0.3453
>       specular 0.294933
>       irid
>          0.15
>          thickness 0.2
looking
very
> The window is:
>       texture
>          pigment
>          normal
>             bozo , 0.05
>             scale  0.3
>          finish
>             ambient 0.0
>             brilliance 3.0
>             phong 0.8417
>             specular 0.431633
>             roughness 0.030067
>             metallic 0.2
>             reflection 0.2
>             irid
>                0.1
>                thickness 0.2
it's
used,
> Simon
Date: 30 Aug 2000 21:21:25
Message: <39adb315@news.povray.org>
Nice texturing! Can we see an anim of this little fella flyin' around? :)
Date: 31 Aug 2000 14:04:10
Message: <slrn8qt035.tih.steve@zero-pps.localdomain>
This looks good, and it would be a candidate to be
blobified.
  4:16pm  up 9 days, 20:34,  2 users,  load average: 2.10, 2.15, 1.99
