POV-Ray : Newsgroups : povray.binaries.images : Re: Previews of Ice Planet stuff Server Time
18 May 2026 04:45:12 EDT (-0400)
  Re: Previews of Ice Planet stuff (Message 12 to 21 of 21)
Subject: Re: Previews of Ice Planet stuff
Date: 29 Aug 2000 23:04:36
Message: <39AC778E.97FB4B89@faricy.net>
Chris Huff wrote:
> I agree...I think it would be an improvement to use {} blocks for while
> loops and other blocks. Or at least have different ending keywords:
> #endif, #endwhile, etc.
> And another thing, it is often difficult to tell if a piece of code is
> creating a variable or modifying it. I have proposed a #set directive
> that is incapable of creating a new variable but would be used to modify
> existing ones, but I seem to be the only person who thinks it is a good
> idea. :-(
We seem to be the only two who think it i a good idea.
David Fontaine   <dav### [at] faricynet>   ICQ 55354965
Please visit my website:  http://davidf.faricy.net/
Date: 29 Aug 2000 23:08:06
Message: <39ac7a96$1@news.povray.org>
news:39A### [at] faricynet...
| Nope, all RMF. Perhaps I didn't use the correct setup. I like the overhang
| though, it serves as a natural shelter for the outpost. I agree the snow
is a
| little saturated, it's just hard to get it to look right on a monitor
because
| they're so dim compared to real blinding glare...
Interesting.  I hadn't seen the RMF get over-hangs without further external
influence.
I figured you were trying for the glare of sunlit snow and ice but the sky
didn't seem to fit.  That's difficult anyway, attempting to mimic a visual
appearance such as glare.  In actuality what you have done there would be
the way to do it though, somewhat darker surroundings.
Date: 29 Aug 2000 23:37:11
Message: <39AC7F32.35A953B2@faricy.net>
> influence.
Umm, there is no sky yet.
Date: 30 Aug 2000 01:25:32
Message: <39ac9acc@news.povray.org>
David Fontaine wrote in message <39AC778E.97FB4B89@faricy.net>...
>> idea. :-(
Better make that three.
Mark
Date: 30 Aug 2000 04:30:56
Message: <39ACC640.F8F9E738@enst.fr>
	Well, four
Date: 30 Aug 2000 10:48:04
Message: <chrishuff-AF5968.09493830082000@news.povray.org>
> 	Well, four
Well, I guess I was wrong!
BTW, I think I just figured out how to implement it, just have to
compile and test it...and another thing I noticed, MegaPOV has
"shortcuts" for declaring, and one of them is the '%' character.(I knew
about the shortcuts before, I just never payed attention to the specific
characters)
I thought the '%' character was already used for a modulus operator...it
seems like this could cause problems. Or maybe I am thinking of it's use
in the isosurface patch...
Christopher James Huff
Date: 30 Aug 2000 11:06:39
Message: <39ad22ff@news.povray.org>
As far as I understand (I think I recall Nathan mentioning it somewhere) the
shortcuts for #declare and #local will not make it into the official POV-Ray
because of problems with other parts of the code.
Kev
Webpage/Pov Gallery:- http://web.libertysurf.co.uk/kevin.ellis
Date: 30 Aug 2000 11:12:10
Message: <1404.276T1427T13914604PeterC@nym.alias.net>
Looks cool.
        I have an idea for an optimization of your lego dome
algorithm.  Have two 2-d arrays, one for the current level of
bricks in the dome, one for the layer above.  Build the dome from
the top down.  The arrays would be used to determine where the
1x1 bricks are going to be placed ... say "1" for a brick and
"0" for no brick.
        Now: for each "1" in the current array that has a "1"
in the array above it, change the "1" to a "0".  This would cause
unseeable 1x1 bricks to not be rendered.  This should save a
lot of memory at the expense of more parsing.
        Another different idea would be to have many long 1xN
bricks, which would go from the left side of the dome to the
right side of the dome.  Consider this ascci art diagram (top down
view of one "slice" of bricks from the dome), where
I represent every other brick with a different asci color,
"X" or "O"
        OOO
    XXXXXXXXXXX
  OOOOOOOOOOOOOOO
 XXXXXXXXXXXXXXXXX
 OOOOOOOOOOOOOOOOO
 XXXXXXXXXXXXXXXXX
  OOOOOOOOOOOOOOO
    XXXXXXXXXXX
        OOO
        That might be both faster in parseing
and memory efficient during render.  The difference in length
between a long brick and the one above it would determine the
placement of pips.
BTW, getting off topic now ... I rendered your neato
faceted twisted torus.  It is a parse monster!  It took a
half hour just to *parse* on my machine!  Wow!
Pete
Date: 30 Aug 2000 15:28:11
Message: <39AD5E11.3E47D963@faricy.net>
That is *exactly* what it does (alternating each layer)! You get the
prize!
Of course, there's no 1x5, 1x7, 1x34, etc, so I have an array for each
length saying what pieces to use,
#declare Beams = array[76][7]
{{1,0,0,0,0,0,0},{2,0,0,0,0,0,0}...{12,10,3,10,12,0,0}...}
Date: 2 Sep 2000 02:57:50
Message: <39B0A2AB.E5291C1E@faricy.net>
Chris Huff wrote:
> As has been mentioned, they would make great quartz crystals...are you
> going to post the source?
Sure, in a bit. If it's not in p.b.s-f in two days, nag me!
