POV-Ray : Newsgroups : povray.binaries.images : projecting an image through glass [~31KB Jpg] Server Time
31 Mar 2026 05:30:29 EDT (-0400)
  projecting an image through glass [~31KB Jpg] (Message 1 to 7 of 7)
Subject: projecting an image through glass [~31KB Jpg]
Date: 18 Aug 2000 07:16:35
Message: <399d1b13@news.povray.org>
I was trying to see how refraction + photons and all that would work out for
projecting images from a light.
Apparently no refraction actually gets used since the image is the same with
or without the glass lens.  Only that photons show up, of course, in the
media air.
Just figured I'd post an image of it while talking about it.  So, I guess
it's a moot thing to try and do image projection in this manner.
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'projectorlight.jpg' (23 KB)
Preview of image 'projectorlight.jpg'
Subject: Re: projecting an image through glass [~31KB Jpg]
Date: 18 Aug 2000 08:22:42
Message: <399D2AB3.ABDB714E@schunter.etc.tu-bs.de>
> media air.
A projector, that works just fine without a lens - you should invent such a
thing for real life :-)
I wonder how sharp the text appears in the media, normally you would expect all
structures to appear in a conic shape expanding from the light source.
Date: 18 Aug 2000 16:49:28
Message: <399DA14A.C6BC0F3B@yahoo.com>
what if you use a cylindrical spotlight with parallel light rays.  the
reason is that in a projector, the bulb is so big in relation to the
film that i'm pretty sure it acts like parallel rays and not a point
source.
> media air.
> Bob
Date: 18 Aug 2000 17:29:05
Message: <399daaa1@news.povray.org>
"ryan constantine" <rco### [at] yahoocom> wrote in message
news:399DA14A.C6BC0F3B@yahoo.com...
| source.
Good idea, I think you're probably right.  Just wouldn't work at all for
this then since the glass doesn't affect it at all unfortunately.  Would be
a great thing if POV-Ray could also do optics simulation.
Date: 18 Aug 2000 19:04:21
Message: <MPG.1407d225cbe0ec20989686@news.povray.org>
In article <399d1b13@news.povray.org>,
per### [at] aolcom?subject=PoV-News says...
Not that I understand the subject of this post, Bob, but why are the
enclosed spaces in the several characters white?
Regards,  Sander
Date: 19 Aug 2000 06:09:58
Message: <399e5cf6@news.povray.org>
"Sander" <san### [at] stolscom> wrote in message
news:MPG.1407d225cbe0ec20989686@news.povray.org...
Because of a quick test image for trying this with.  I should have put the
gradient fill down first, the text went in first.  Thought that would be
fine though, until I saw the white with filter 1 made it clear, hadn't
thought of that.  Only reason it turns white again is because it's shown on
a white wall.
Understanding the subject is easy.  All I was trying to do is see how
refraction through glass would effect the light shining into it.  The
photons show it refracting in the media, but near as I can tell there isn't
any change of the actual light source rays  :-(
This leads me to believe that were I to somehow turn off the image map
itself yet leave the photons there would be a refracted projection there.
For instance, removing the white wall and shine it into media air alone.
Date: 21 Aug 2000 22:39:14
Message: <chrishuff-7F20C1.21403521082000@news.povray.org>
In article <399e5cf6@news.povray.org>, "Bob Hughes"
> isn't any change of the actual light source rays  :-(
Maybe if you reflected the beam off a mirror before going through the
image and lens...or maybe not. Hmm.
Christopher James Huff
