POV-Ray : Newsgroups : povray.binaries.images : Kitchen Visualization Problem Server Time
29 Jun 2026 05:07:05 EDT (-0400)
  Kitchen Visualization Problem (Message 1 to 7 of 7)
Subject: Kitchen Visualization Problem
Date: 16 Aug 2000 10:30:18
Message: <399aa57a@news.povray.org>
Hey All,
I tried rendering my kitchen visualization with some really neat-o radiosity
settings, but all my bump maps got completely washed out. Is there a way in
POV-Ray or MegaPov to use my map to modify the actual geometry and not just
the normals? Height-fields would do it, I suppose, but I like the repeating
pattern of bump-maps. I was reading something about isosurfaces and
bump-maps in earlier threads, but I don't know how isosurfaces work; anyone
know a good explanation or tutorial?
Thanks,
D.J.
Subject: Re: Kitchen Visualization Problem
Date: 16 Aug 2000 11:48:07
Message: <399AB7DA.7FE52587@schunter.etc.tu-bs.de>
"D.J. Brown" wrote:
> Hey All,
> Thanks,
> D.J.
Have you tried "normal on" in the radiosity block ?
If that does not help, you can add bumpiness to all isosurfaces, see the megapov
sample files for details.  It should not be a problem to define a wall, etc. as
isosurface, it's only much slower :-)
Date: 16 Aug 2000 11:52:31
Message: <chrishuff-4EAD1F.10534516082000@news.povray.org>
In article <399aa57a@news.povray.org>, "D.J. Brown"
> radiosity settings, but all my bump maps got completely washed out.
This is because by default radiosity ignores perturbations to the object
normal. In MegaPOV, you can tell it to take normal patterns into
account(including bump_maps): just add "normal on" to the radiosity {}
block in global_settings.
> Is there a way in POV-Ray or MegaPov to use my map to modify the
> actual geometry and not just the normals?
Not directly, you would have to make a function representing your object
an use an isosurface.
> anyone know a good explanation or tutorial?
There are a couple isosurface tutorials:
http://www.hamiltonite.pwp.blueyonder.co.uk/
        raytracing/STBenge/stbenge.html
http://www.econym.demon.co.uk/isotut/
Christopher James Huff
Personal: e-mail chr### [at] maccom, Web page http://homepage.mac.com/chrishuff/
TAG: e-mail chr### [at] tagpovrayorg, Web page http://tag.povray.org/
Date: 16 Aug 2000 12:58:44
Message: <399ac844@news.povray.org>
Wouldn't you know... I decided that I should convert them all to
height-fields and I spent the past hour redoing my architecture when all I
needed to do was put "normal on" in the radiosity block. Then again... I
guess I haven't lost any time since I would've checked the newsgroup at the
same time and been just as far along. Thanks for the plethora of info.
Let me see if I have this correct on iso-surfaces... Basically, it evaluates
a function at points x, y, z inside my bounding region and creates a surface
point with that if my function evaluates at or above a certain threshold? Or
does it create a mesh like the height-field does? Or does it simply refer to
the provided function every time it calculates a point... creating a
pseudo-infinitely detailed surface?
Thanks in advance for any help,
D.J.
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-4EAD1F.10534516082000@news.povray.org...
Date: 16 Aug 2000 14:12:59
Message: <chrishuff-915E10.13141216082000@news.povray.org>
In article <399ac844@news.povray.org>, "D.J. Brown"
> all I needed to do was put "normal on" in the radiosity block. Then
> again... I guess I haven't lost any time since I would've checked the
> newsgroup at the same time and been just as far along. Thanks for the
> plethora of info.
Ouch...I hope you saved the original scene file first.
> evaluates a function at points x, y, z inside my bounding region and
> creates a surface point with that if my function evaluates at or
> above a certain threshold? Or does it create a mesh like the
> height-field does? Or does it simply refer to the provided function
> every time it calculates a point... creating a pseudo-infinitely
> detailed surface?
It uses the provided function every time it needs to calculate a point.
By default, points with a value higher than the threshold are inside the
surface, lower values are outside, and the algorithm "searches" along
the ray for the intersection points. It is not tesselated to triangles,
it is a surface just like a sphere or cone primitive, though the solving
method is very different from any other primitive in the official
version.
Date: 16 Aug 2000 14:57:35
Message: <399ae41f@news.povray.org>
Backupsss? Backupsss? We don't need no stinkin' backupsss! Actually, based
on the isosurphace information you led me to I wrote a macro for applying
displacement mapping to the surface of my walls. It's looking really nice
(even a decently realistic render with the render quality set at 4). I just
have to figure out how to round off the edges now... Very sharp and deadly
walls in this place.
Thanks!
news:chrishuff-915E10.13141216082000@news.povray.org...
> > plethora of info.
> > detailed surface?
> version.
Date: 16 Aug 2000 23:22:10
Message: <399B6B67.2197A1F0@osu.edu>
"D.J. Brown" wrote:
> I just
> Thanks!
We like our walls the same as we like our blue screens... deadly.
